Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Nylint Ford Econoline Conversion - Misc. WPL Parts
Old 06-19-2019, 04:35 PM   #21
Default Re: Nylint Ford Econoline Conversion - Misc. WPL Parts
What's next in your driveline? 1:1 transfer case, 2 speed transmission, or straight shaft to rear wheel drive? I have mated 4000kV motor to 2 speed WPL gearbox and it is a bit too fast with no low speed control. I kind of wish you did: your motor->1:10 reduction-> 2 speed -> 4WD and tell us how it drives. But I dont think you have room for that.
JerryIRacer is offline   Reply With Quote
Old 06-20-2019, 07:26 AM   #22
Right now I plan on going into a 1:1 transfer case. I will hopefully have it driving in the next couple of weeks. If it is too fast, I'll move to a 20:1 transfer case.
12MPG is offline   Reply With Quote
Old 07-02-2019, 01:01 PM   #23
Default Cantilever Rear Suspension
I scaled down this design from thingiverse to make a rear cantilever suspension. The shocks are from aliexpress. It works pretty well.
https://www.thingiverse.com/thing:2871329
Nylint Econoline RC (5) by captaininsano1000, on Flickr
Nylint Econoline RC (4) by captaininsano1000, on Flickr
Old 07-02-2019, 01:13 PM   #24
Default Radius Arm Front Suspension
I used a the plastic tie bar from a HG P402 crawler cut in half to make the links for the front suspension. They are super glued to the WPL axles. I would have loved to make them bolt on so I could adjust the pinion angle but there isn't much space in there. The drag link and panhard bar are from aliexpress. The front needs a little but more work. The pumpkin hits the panhard bar at full compression.
Nylint Econoline RC (2) by captaininsano1000, on Flickr
Nylint Econoline RC (3) by captaininsano1000, on Flickr
Old 07-02-2019, 01:15 PM   #25
I am going to wait until all the weight is in the vehicle before dialing out the stink bug stance.
Nylint Econoline RC (1) by captaininsano1000, on Flickr
Old 07-24-2019, 11:14 AM   #26
I used this RC / Water Gun motor with a 10:1 reduction box while waiting for another brushless motor and gear reducer to come in. It resulted in a decent top and the motor didn't stall when I was climbing about a 30 degree incline. It ended up spinning the metal axles inside the plastic end caps that hold the wheels so that will get repaired and I'll go back to testing. I am hoping to have some running video by next week.
https://www.aliexpress.com/item/3296...650c2c25LZcerm
Old 07-30-2019, 08:29 AM   #27
Default Interior
I sectioned the bench seat from the WPL Toyota Pickup and used the Toyota steering wheel for a simple interior.
Pressed Steel RC (2) by captaininsano1000, on Flickr
Pressed Steel RC (1) by captaininsano1000, on Flickr
Old 07-30-2019, 08:31 AM   #28
Default Flex Shots
It has about 1.5" of suspension both front and rear.
Nylint RC Econoline (2) by captaininsano1000, on Flickr
Nylint RC Econoline (1) by captaininsano1000, on Flickr
Old 08-14-2019, 03:58 PM   #29
This runs fine on pavement but I can hear clicking when it gets hung up in the river pebbles outside my house so I am installing metal gears in the axles. The wheel adapter fix in the earlier part of the thread won't work with the metal hubs so I 3D printed some adapters to work with the 5MM hubs and 8MM wheels.
Nylint Hubs (2) by captaininsano1000, on Flickr
Nylint Hubs (1) by captaininsano1000, on Flickr
Nylint Ford Econoline Conversion - Misc. WPL Parts - Similar Threads
Jk to ford conversion 4X4 Freak Axial SCX-10 13 08-14-2014 08:45 PM
Ford Econoline Van 60's jeepjames87 Non Crawler RC's 42 04-07-2013 03:23 PM
1930's Marmon-Herrington Ford conversion? johnnyh66 Scale Comp Rules 12 03-02-2012 11:38 AM
ford nylint haynesn12 General Crawlers 4 01-12-2006 11:51 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
