Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Nylint Ford Econoline Conversion - Misc. WPL Parts
Old 12-17-2018, 09:31 AM   #1
Default Nylint Ford Econoline Conversion - Misc. WPL Parts
I am waiting on a lot of metal pieces to come in for the Tonka RC Jeep Conversion so I started another project.
12MPG is offline   Reply With Quote
Old 12-17-2018, 09:34 AM   #2
Default Re: Nylint Ford Econoline Conversion - Misc. WPL Parts
IMG_8566 by captaininsano1000, on Flickr
The tires are for a HBX 1/18 truck of some sort.
https://www.banggood.com/HBX-118-188...r_warehouse=CN
IMG_8567 by captaininsano1000, on Flickr
Old 12-17-2018, 09:37 AM   #3
The wheels have a 8MM hex so I used a tap and die set to thread the WPL shafts and used 8MM nuts to hold the wheel.
IMG_8593 by captaininsano1000, on Flickr
IMG_8591 by captaininsano1000, on Flickr
Old 12-17-2018, 09:39 AM   #4
To get the right track width, I had to modify the steering knuckles to clear the wheels. The stock one is on the left, the modified one is on the right.
IMG_8599 by captaininsano1000, on Flickr
Old 12-17-2018, 09:41 AM   #5
My original plan was to use WPL leaf springs but I am going to have a lot of these parts left over from another build so I figured I'd use them.
IMG_8649 by captaininsano1000, on Flickr
Old 12-17-2018, 09:46 AM   #6
I am going to use two N20 gearmotors to power the wheels. I should have ordered N30 motors but it is too late now. They are 1000 RPM output motors. I don't know if that is going to be too fast but since these things cost $2.00, it will just reorder if needed.
https://www.aliexpress.com/item/Free...27424c4dZTkKwM
Old 12-17-2018, 10:10 AM   #7
Moderator
JatoTheRipper's Avatar
Very cool project! I can't wait to see it finished and running.
Old 12-17-2018, 11:46 AM   #8
That high of a speed from that small motor will create very little torque. I have the 600rpm ones that Adrian202 tried out, and it is ungodly slow but has a bit more torque. Not to mention all those metal gears are LOUD!
chevyfried is offline   Reply With Quote
Old 12-18-2018, 12:44 PM   #9
I was afraid of that but I was emotionally scarred from another motor I installed on my first Tonka RC conversion that was way to slow and had way more torque than needed. I didn't consider the noise so I guess I'll see how that goes.
Old 12-26-2018, 11:34 AM   #10
I epoxied the nuts to the threaded plastic axles to keep them from unscrewing themselves and true up the wheels as much as possible. One of them has some wobble to it but not a ton.
Old 12-26-2018, 11:36 AM   #11
Default Suspension Partially Done
IMG_8878 by captaininsano1000, on Flickr
IMG_8883 by captaininsano1000, on Flickr
IMG_8881 by captaininsano1000, on Flickr
Old 12-26-2018, 11:43 AM   #12
The shocks I bought are terrible. I bought the shorter ones in the link below. They bind up really easily. I think it has to do with the offset on the upper mount.
https://www.aliexpress.com/item/1set...27424c4d5NxdCO
There are a few minor rubbing issues with the front suspension and the tires but I think it can all be dialed out.
Old 12-26-2018, 11:44 AM   #13
IMG_8875 by captaininsano1000, on Flickr
IMG_8877 by captaininsano1000, on Flickr
Old 12-28-2018, 01:54 PM   #14
Default Servo Mounting
I just made a couple of brackets out of misc. RC pieces. The stock pitman arm will be replaces with a metal link when it arrives from the China.
IMG_8987 by captaininsano1000, on Flickr
IMG_8985 by captaininsano1000, on Flickr
Old 05-13-2019, 11:55 AM   #15
You were indeed correct. This machine is now running and does fine on carpet and hardwood but can't climb anything. I'm going to try to find some bigger motors.
Old 05-15-2019, 07:42 AM   #16
i'm liking this build!
alexleblanc is offline   Reply With Quote
Old 05-15-2019, 09:10 AM   #17
Very cool! Excited to see this one turn out.
FordSpeed is offline   Reply With Quote
Old 05-15-2019, 09:35 AM   #18
This is a cool build , where did you get the body?
Here's my 1:1 I had back in '85, it was a '66
Mike Flea is offline   Reply With Quote
Old 06-19-2019, 01:00 PM   #19
The body is an old Nylint truck that belonged to my dad.
Old 06-19-2019, 01:15 PM   #20
Default Motor Swap
Since my two small N30 motors didn't have enough power, I have worked up a different solution using a motor from Aliexpress bolted to a planetary gearbox.
Motor: FATJAY 2430 5800 KV Brushless motor hooked to a 10:1 planetary gearbox.
https://www.aliexpress.com/item/FATJ...27424c4dropcOJ
I am not sure if this motor/transmission combo will work but I am going to give it a try and see what happens.
Nylint RC Truck (2) by captaininsano1000, on Flickr
Nylint RC Truck (1) by captaininsano1000, on Flickr
Nylint Ford Econoline Conversion - Misc. WPL Parts - Similar Threads
Jk to ford conversion 4X4 Freak Axial SCX-10 13 08-14-2014 07:45 PM
Ford Econoline Van 60's jeepjames87 Non Crawler RC's 42 04-07-2013 02:23 PM
1930's Marmon-Herrington Ford conversion? johnnyh66 Scale Comp Rules 12 03-02-2012 10:38 AM
ford nylint haynesn12 General Crawlers 4 01-12-2006 10:51 PM
