12-21-2018, 10:55 AM | #21 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
| Re: WPL C14 C24 Yota Bumpsteer SOLVED I have yet to run anything but the stock 130 that came in rtr that I have and only ran that about five minutes cause the steering was so horrible, I've watched a ton of videos on these things and the 180 doesn't seem too bad for general trail running and light climbing, decent speed and so forth, the dual motor setup seems slow but very torquey, so I'd say think about how you wanna run it. I've got the dual N30's on the way and my 2spd with 370 came yesterday. The kit coming will have the 180 and I'm gonna order the metal geared trans with the 370 and try them all. I look at this way you can change it out rather quickly anyhow.
12-29-2018, 10:33 AM | #22 |
UPDATE I did a little experiment, I ordered the metal upgrade steering links to see if the bump steer is minimized with these links and it is dramatically. I ordered the style that runs from the servo to the passenger side and it works excellent. I've seen on YouTube that the other upgraded links that still go to drivers side also dramatically reduce it as well. I've removed my Panhard setup to try this and will probably just leave it off. Yes it works but the upgraded links work just as well with less hassle. So you have 3 choices, the stock plastic link is junk it's what causes the bad bump steer. |
12-29-2018, 11:48 AM | #23 | |
| Re: WPL C14 C24 Yota Bumpsteer SOLVED Quote:
12-29-2018, 11:52 AM | #24 |
| Re: WPL C14 C24 Yota Bumpsteer SOLVED Here you go https://rover.ebay.com/rover/0/0/0?m...2F123217890102 I haven't tried this one but seems to work just as well on YouTube, I like the looks of first one better though. https://rover.ebay.com/rover/0/0/0?m...2F352510891740 |
01-02-2019, 12:17 PM | #25 | |
Rock Stacker Join Date: Nov 2018 Location: Fort Lauderdale
Sorry to hear you took off the panhard. That was some awesome work. | |
01-02-2019, 12:32 PM | #26 | |
01-03-2019, 07:41 AM | #27 |
Rock Crawler Join Date: Jan 2011 Location: Groningen, The Netherlands
Tried it. Works! In all its simplicity, it works great. Thnx! Though, the fancy panhard is, from a technical standpoint, much more interesting looking. Will try that with the next kit. Still have the Ural to build, and the second MAN K1 to modify. The JJrc MAN is quite a bit more sturdy in the drive-line apartment than the WPL trucks, I discovered. Larger pitch gears, for starters. Working, fully closed diffs that keep 50000cps diff-fluid pretty good. Shafts and couplers feel sturdier too. Haven’t snapped one yet despite being rather heavy with a Turnigy full lighting and sound kit, plus running it hard with a 180 motor on 2s. Something that killed the WPL C24 spools in a couple of minutes. |
01-03-2019, 08:02 AM | #28 | |
01-18-2019, 01:31 PM | #29 | |
Pebble Pounder Join Date: Jan 2019 Location: Roanoke
01-18-2019, 01:51 PM | #30 |
| Re: WPL C14 C24 Yota Bumpsteer SOLVED That was exactly what I did here in this thread and it works but the upgraded link works just as well without all the fab work and hassle. The only difference is how the servo is sitting.
01-18-2019, 03:36 PM | #31 |
| Re: WPL C14 C24 Yota Bumpsteer SOLVED Yeah I was talking about the servo position. all you really need to do is give it a bit of a trim with a dremel. And you will also have a good mounting point for the servo. You can secure it with screws and m2 lock nut's. No more hot glue is needed. Not sure if it will stop the bump steer though. You would have to ditch the servo arm for one without the 90 degree twist so both holes are facing the same side. I am quite willing to try this method out.
01-18-2019, 03:44 PM | #32 | |
01-18-2019, 04:55 PM | #33 | |
01-18-2019, 05:42 PM | #34 | |
So I probably won't have to print a lot of these Link: https://www.thingiverse.com/thing:3318831 | |
01-18-2019, 06:00 PM | #35 | |
| Re: WPL C14 C24 Yota Bumpsteer SOLVED Quote: | |
01-19-2019, 08:05 AM | #36 |
| Re: WPL C14 C24 Yota Bumpsteer SOLVED |
03-27-2019, 08:45 AM | #37 |
So I found a great fix to eliminate bump-steer on the C-14 and C-24. All you need is some form of fire (trust me) and a longer screw. What you need to do is bend the servo arm straight and put both steering linkages to to top of the steering hubs. Video link: https://youtu.be/9F5L1Wq2dsM?list=PL...LnWs9xs7&t=260 |
WPL C14 C24 Yota Bumpsteer SOLVED - Similar Threads | ||||
WPL C14 | Brake Weight | Micro Scale Rigs | 633 | 01-07-2022 02:57 PM |
A WPL C24 done my way | R.Billy Rob | Micro Scale Rigs | 6 | 12-08-2020 10:17 AM |
Wpl c24 | PileDriver | Micro Scale Rigs | 64 | 07-07-2020 06:36 PM |
WPL C14 build | Dungas | Micro Scale Rigs | 15 | 04-03-2020 09:12 PM |
Wpl c14 video | Tennesseetommy81 | Micro Scale Rigs | 4 | 01-03-2018 04:01 PM |
