01-27-2019, 03:09 PM | #1 |
Pebble Pounder Join Date: Jan 2019 Location: Douglas, MA
| ProLine Ambush woes
So I bought a ProLine Ambush for my son right after Christmas and was originally impressed by the little thing but it didn’t last long. It’s under a month old, has only been used in the house or in the garage. I think it’s probably got about 1.5hrs use on it. He was using it today and it started sounding funky... Long story short the pinion gear is stripped. I can’t find any details on it and it’s also discontinued. Does anyone know what size gear it is? I would assume it must be a fairly common size. It’s mangled to the point I can’t really count the teeth on it. I am going to try emailing ProLine also. If I have to buy a complete motor with gear I will. The little things aren’t exactly cheap so I would like to get it going again. I guess he’s going to be getting that TRX4 he’s been asking for sooner than later. Thanks in advance for any help. I am just getting back into RC after about 10 years so I am trying to reacquaint myself with everything. |
01-27-2019, 03:18 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: ProLine Ambush woes
The Proline Ambush pinion and Spur are the same 0.3 mod as all the 1/36, 1/24 Losi micros, ECX Barrage/RGT Adventurer, and a few others. Just make sure to set the mesh properly and everything spins smoothly before reassembling Sent from my LGMP450 using Tapatalk Last edited by spoo76; 03-17-2019 at 08:00 AM. |
01-27-2019, 03:20 PM | #3 |
BTW the pinion is likely 10t or 11t. Could even be 12. I'd just look for a 10t. Use a small dab of CA or super glue to secure the new pinion if the motor shaft isn't splined. Sent from my LGMP450 using Tapatalk |
01-27-2019, 03:42 PM | #4 |
Awesome! Thanks for the quick reply. I am guessing you are right with the 10T. Looks way too small to be much bigger but they can’t be much money so maybe I will just grab a couple of a few different sizes.
03-17-2019, 07:53 AM | #5 |
Newbie Join Date: Mar 2019 Location: Lapeer
Have you found a replacement pinion for this yet. If so which one did you use. I am in the same boat as you right now. Sent from my SM-N960U using Tapatalk Last edited by Jkoutlaw; 04-29-2019 at 06:59 AM. |
04-01-2019, 05:32 AM | #6 |
Newbie Join Date: Mar 2019 Location: Delano
Call pro line they have some parts for the ambush in stock |
ProLine Ambush woes - Similar Threads | ||||
Proline Ambush | RAM2500 | New Mexico | 7 | 01-23-2011 10:05 PM |
