06-18-2019, 09:52 AM | #21 |
Rock Stacker Join Date: Jun 2019 Location: Fishers, In.
| Re: Which Orlandoo build?
Yeah, I want one of these as well. So, you can use pretty much any radio with them? Adding the Orlandoo radio, servos, motors and batteries makes this cool little $80 rig get very expensive very fast. If I could use a few things that I have laying around to finish it up that sure would make the decision to buy one a lot easier and lighten the hit on the wallet. |
06-28-2019, 06:41 AM | #22 |
Newbie Join Date: Jun 2019 Location: Andover, United kingdom
I just got the f150. i do wish I had got the jeep as all the parts seem upgradeable but its been crawing pretty well so far, even with the 500rpm motor in it. I also fitted the 2.2g servo but only because I got sent the wrong one (took some extreme fitting). I'm using a taranis qx7s as my tx and its been working great. I've set my throttle on a three position switch so at position 1 I get 20% of my throttle range, position 2 60% and 3 at 100%. I have noticed that it can be useful to have a higher wheel speed for some climbs, while it gives me finer control at the lower speeds if I select the 1st position. For the tiny SMD issue i just used 3mm led's instead and widened the channels that they had to fit in (seemed like the easier option). |
Which Orlandoo build? - Similar Threads | ||||
MAXXMASHER's Orlandoo build! | MAXXMASHER | Micro Scale Rigs | 2 | 06-07-2017 12:35 AM |
Orlandoo Wrangler build #2 | nate94gt | Micro Scale Rigs | 30 | 05-29-2017 02:42 AM |
my Orlandoo hunter build | eypontwion | Micro Scale Rigs | 1 | 08-06-2016 10:26 PM |
