04-18-2019, 06:38 AM | #1 |
| Idea time
As was mentioned in passing in another thread due to a brain fart of mine. I have a set of “1/16” WPL axles and a couple of “1/24” micro chassis’ laying around. The axles are a 5mm hex but I do have several sets of ‘adaptors’ to 7mm which makes the 1” wheels possible. The WPL tires are about the same as the Scramblers, which are yuuuge. Chassis that are available: 1-OG Losi Micro, 2-Losi Trail Trekker, 3-‘1/18’ Gelande, and 4-1/24 Spectre. Bodies available are the TTrekker and Barrage. Under the Spectre they are aesthetically pleasing. But these axles don’t have a servo mount. I don’t think this 3d chassis would handle a CMS well, especially one large enough to throw these tires around. I do believe there are a few axle mounts for servos available on Thingverse though. Under the ‘1/18’ chassis they kinda work. But once the Barrage body was dropped on they don’t. Not without some major trimming but then the chassis would be exposed. Leaving the rear truggy portion of the body off would be best. Last edited by Brake Weight; 04-18-2019 at 11:59 AM. |
04-19-2019, 08:54 AM | #2 |
| Idea time
Lots of sorting to do but it’s feasible. Looks cartoonish like a Yoder on Rockwells Found some Mini T shocks and used the WPL stock links. Needs proper length shocks and proper links. I’ve got some of the metal axle housings I may try to use with the brass gears. Beefed up it may be a fun basher/bouncer more than a crawler. The YTube videos of these on 3s are impressive at the amount of abuse a beefed WPL drivetrain can take. |
04-27-2019, 07:30 AM | #3 |
| Idea time
Scratch the conventional chassis idea and look at this micro Baumber. The WPL axles would be nearly perfect on this after a good hacking and rebuild. https://www.banggood.com/122-2_4G-4W...p-1434394.html Another one https://www.banggood.com/1PC-MG-A601...p-1391934.html Last edited by Brake Weight; 04-27-2019 at 07:45 AM. |
Idea time - Similar Threads | ||||
House hunting time! (pause the RC time) | johnnyluv | Chit Chat | 7 | 09-21-2018 12:32 PM |
Just introducing myself. Long time racer, first time crawler. | Hinecken | Newbie General | 15 | 01-17-2015 05:19 AM |
maybe now ill spend less time on the lid and more time on the rubber | evan03 | Axial Wraith | 2 | 02-18-2013 08:08 PM |
Time for a rebuild.... Scale truck this time.... | msd44 | New Mexico | 36 | 02-13-2011 10:32 PM |
Its motor time!!And esc time as well,,,,ADVICE PLZ | Speed Metal Army | RC4WD Bully | 11 | 03-15-2010 10:23 PM |
