04-27-2019, 07:59 PM | #1 |
Newbie Join Date: Nov 2012 Location: Chili NY
| Rgt 1/24 start of scale
Wife picked me up one for my birthday, I have a 79 f100 model I plan to use as the body. Decided to work on some terrains and share with you all. Also picked up a 4 speed reduction gear box and 10 amp 7.4lipo esc to help. Factory is lacking good throttle response. Sent from my moto g(6) using Tapatalk Last edited by Jkates828; 04-29-2019 at 02:56 PM. |
04-27-2019, 09:10 PM | #2 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
| Re: Rgt 1/24 start of scale
Nice job on the terrain! Looks so real. Wish i was that talented lol Sent from my SM-J327VPP using Tapatalk |
04-27-2019, 10:12 PM | #3 |
Thank you for the nice comment!! Honestly from start to finish it only took about 4 hours of work over a week (drying stages) There is a guy in YouTube that shows how to make "scale terrain" and is it is very cheap/simple. Foam, plaster, primer spray paint, some craft paint, Elmer's glue, and flock. This is the first one I've made... Sent from my moto g(6) using Tapatalk |
04-29-2019, 08:30 AM | #4 |
Quarry Creeper Join Date: Jan 2014 Location: round lake
Looks great!!!Best display ever!!!
05-01-2019, 06:20 AM | #5 |
Some more progress, had my daughter's making some more rocks and started to mock up the Ford. I got some time to change things out, put in a servo I had from a 1/16 carisma, flysky receiver, $9 Amazon esc, and 7.4 1000mah lipo $16 Amazon for 2. All around much better performance, way better power band, next is the gear reduction tranny. Update... Trans. built and installed, made a cover/mount plate used some 2-56 screws. Since this trans is about 3mm wider then stock had to trim down the drive shafts. Today my wpl metal driveshaft set should be in and I'll turn those down this week. Next will be incorporating the longer motor can into this trans, current performance great low end torque maybe to much, there are four different gear ratios so I need to try them all for better speed/to. Also more rocks landscape to come much larger rock range is in the works Last edited by Jkates828; 05-07-2019 at 06:03 AM. |
05-07-2019, 06:25 PM | #6 |
Just finished getting the motor in, shot a vid of it in action, this thing is awesome https://youtu.be/FK1AR8iXlf0 Sent from my moto g(6) using Tapatalk Last edited by Jkates828; 05-08-2019 at 08:00 AM. |
05-08-2019, 08:31 AM | #7 |
Looks like it's have a lot torque.Did you thinker own trans?
05-08-2019, 11:59 AM | #8 |
Newbie Join Date: Aug 2011 Location: Helena
I AM LOOKING INTO GETTING A 1/24, WHAT MAD YOU CHOOSE THIS OVER THE OTHERS? IE BARRAGE BTW THIS IS AN AWESOME BUILD!! |
05-08-2019, 01:52 PM | #9 |
The trans is Tamiya TAM70189 Mini Motor Low Speed Gearbox 4-Speed, had to cut the shaft and drill holes for the driveshaft. Choice reasons was because of cost and availability compared to losi or ecx, got it on Amazon $87 free shipping, and came with 3 lipos. Always loved micros used to do alot of xmods with model body's, stacked fets, neo magnets, lipos. Thanks again for the great comments Sent from my moto g(6) using Tapatalk |
05-26-2019, 02:24 PM | #10 |
It's been slow going "weather has been nice" but made some progress on the body did some dents and rust holes. Need to finish plaster on the larger rock formations, maybe in the next couple of days I'll have paint on it. Also I've been working on my 1:1 getting her ready for another winter. Sent from my moto g(6) using Tapatalk Last edited by Jkates828; 05-28-2019 at 08:08 AM. |
10-28-2020, 05:26 PM | #11 |
It's been awhile but some progress has been made. Also bought a scx24 couple months back very much enjoy it. Still planning to build enough sections to cover a 4'x8' table. Thanks for the Awesome comments!!! Last edited by Jkates828; 11-03-2020 at 06:09 AM. |
10-28-2020, 05:33 PM | #12 |
HiHiHi-Lift! Join Date: Mar 2019 Location: Sacramento
Looking awesome! You might've already figured this out, but the RGT is actually the OEM of the "new" Element Enduro 24. So any upgrades that come out for the Enduro 24 will work on the RGT. I love those tiny little Swampers! |
10-28-2020, 07:34 PM | #13 |
Newbie Join Date: Jun 2020 Location: Uvalde
Not to make you feel bad addie, but OP’s RGT is a V1 spec, the enduro is a V2 spec. That being said, anything suspension and chassis related should still work. I’m need to find those videos for making the terrain. Your first piece looks awesome for a first time, and the rest look awesome too. |
10-28-2020, 07:41 PM | #14 | |
| Re: Rgt 1/24 start of scale Quote:
11-20-2020, 11:13 AM | #15 |
Newbie Join Date: Nov 2020 Location: Poland
@Jkates828 this is VERY nice piece of rock! I was so impressed that I had already started to do mine with my kid as I already had some foam etc. I am wonder what kind of paint did you use for the first layer the blue-gray one? |
11-20-2020, 11:26 AM | #16 |
I use cheap gray primer spray paint for the first layers, nothing special. The other paint is basic craft paints mixed to different shades and dry brushed on. That's awesome having your child involved, while painting trying to get my daughter's to understand less is more was quite a challenge. Thanks for the great comments!!! Sent from my moto g(6) using Tapatalk |
01-14-2021, 07:59 PM | #17 |
Quarry Creeper Join Date: Jan 2005 Location: Denver, CO
JKates, any tips on how you fitted the larger motor into the Tamiya 4-speed trans? Planning to do the same thing to my Panda Hobby Tetra K1.
01-16-2021, 07:59 AM | #18 |
Used a dremel to match the contour of the motor to the trans, but I left the hole just small enough so when you put the trans together it clamps down on the motor. Also the way the trans is built the worm gear holds the motor from moving. I also purchased extra telescoping drive shafts to trim down since the trans was wider then org. Not sure what you would need for the panda. Kind Regards Update Been a whole year, ended up with two scx24's running great, recently been rebuilding RadioShack xmods and had a little turkey day 500 in the basement also wanted to share some scale garage works. Last edited by Jkates828; 12-06-2021 at 12:57 PM. |
12-06-2021, 01:09 PM | #19 |
Also working on a diecast conversion onto a wpl chassis, wpl chassis dump truck and did some painting. |
12-23-2021, 10:00 AM | #20 |
Newbie Join Date: Dec 2021 Location: North Chicago Suburb
Gorgeous landscaping!! I have an RGT Adventurer as well, a big fan of the wheelbase on it.
Rgt 1/24 start of scale - Similar Threads | ||||
Ecx ftx rgt 1/24 scale crawler new rc4wd 1.0" tires! | shenlonco | Scale Videos! | 0 | 03-02-2018 07:12 AM |
How to start a scale garage | Betts818 | Chit Chat | 4 | 05-30-2016 03:41 AM |
want to start a scale project | kawicrazed_125_05 | General Scale Talk | 1 | 03-21-2008 12:51 PM |
where to start a scale truck? | TOYUTAH | Newbie General | 16 | 03-07-2007 07:19 PM |
Best scale chassis to start with? | terrible | Newbie General | 6 | 01-13-2007 07:19 AM |
