06-08-2019, 03:41 PM | #161 |
| Re: New Axial scx 24 deadbolt
Thanks. Just what I needed.
06-09-2019, 08:41 AM | #162 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
I got my scrambers! They are tall! Sticky too! Sent from your iPhone. |
06-09-2019, 11:23 AM | #163 |
| Re: New Axial scx 24 deadbolt From middle: Rock crushers on RC4WD 1.0 Hbx devastator monster wheel Scrambler unmounted. Scrambler mounted on wide hbx rims. Sent from your iPhone. |
06-09-2019, 11:36 AM | #164 |
| New Axial scx 24 deadbolt I’m in love! These scramblers without foam on these hbx rims is perfect for me. Love the look of these tires on those rims. Sent from your iPhone. Last edited by BIGW0RM; 06-09-2019 at 12:02 PM. |
06-09-2019, 11:40 AM | #165 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
I found the scramblers and MTRs are so soft they need foam to keep the tires from folding over in a bind and side hilling. Sent from my LGMP450 using Tapatalk |
06-09-2019, 12:05 PM | #166 |
| Re: New Axial scx 24 deadbolt |
06-09-2019, 01:45 PM | #167 |
06-11-2019, 11:53 AM | #168 |
Rock Stacker Join Date: Nov 2018 Location: Louisville
Annnnndddddddd I bought one...lol Sent from my SM-G955U using Tapatalk |
06-11-2019, 12:59 PM | #169 |
Rock Stacker Join Date: May 2018 Location: North Carolina
The scramblers look pretty great. Bigworm, what is that bronco body? is that one of the RC4WD 1/18 broncos that just.. wasn't painted? That thing looks awesome.. would love to try to fit it onto the scx24...
06-11-2019, 01:55 PM | #170 | |
| Re: New Axial scx 24 deadbolt Quote:
Yes, thats a RC4WD blackjack I have fully customized. It was green and I painted it satin grey. I was going for gunship grey, but it came out looking primered in pictures...lol. In real life it shows its color much better. I believe the wheel arches line up. But you will need to change the tires and spacing to achieve it. The stock tires and scramblers are WAY to tall for it. You really only want 50mm max tire on the RC4WD body or it looks funny IMO. And I suspect you will need different shock or springs as the body will most certainly bottom the stock SUPER SUPER soft springs. This is a very light weight truck. Lightest one out of all my micros. But anything's possible with desire! You'll see once you get your SCX24. | |
06-11-2019, 02:19 PM | #171 | |
Sent from my LGMP450 using Tapatalk | |
06-13-2019, 02:30 PM | #172 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
Balance charging the stock battery on my Imax B6 AC v2... what amp rate should I be using? I've never balance-charged or stored a battery this small.
06-13-2019, 02:38 PM | #173 |
Same rules for larger lipo. Unless specifically stated I charge at a 1C rate or less.For 1500mah 1.5 amps 3000mah 3.0 amps 500mah. .5amp 350mah .35 but .3, .4, or even .5 if that's the lowest your charger will do works fine. Sent from my LGMP450 using Tapatalk Last edited by spoo76; 06-13-2019 at 02:41 PM. |
06-13-2019, 03:10 PM | #174 |
Thanks so much, spoo76!
06-13-2019, 03:32 PM | #175 |
Yes thank you Spoo76. By far the most helpful and knowledgeable micro member. I just got that charger so that helps me too! Sent from your iPhone. |
06-13-2019, 03:56 PM | #176 |
Glad to help, but I wouldn't say I'm the most knowledgeable by any means lol. I'm just the one here hitting reply haha Sent from my LGMP450 using Tapatalk |
06-13-2019, 05:18 PM | #177 |
I have a feeling the included charger is a fair bit higher than .3 amps (not that it should be). I've noticed that my "good" charger (running at .3 amps) takes maybe 45 minutes while the included charger takes around 25 minutes though I didn't time it. They say it should take 2 hours to charge which makes me wonder if the charger is the wrong spec.
06-13-2019, 05:33 PM | #178 | |
Quarry Creeper Join Date: Aug 2018 Location: Toronto, Canada
06-13-2019, 07:58 PM | #179 |
Newbie Join Date: Jun 2019 Location: Chesapeake
The charger is 1 amp if I do recall. It says right on the bottom what the in and output is. Id check again but mine broke (usb jack pulled right out with the cable) right after the second use so I tossed it. I now charge with my imaxB6 at .4mah as it’s better in the long term to charge at 1c anyway.
06-13-2019, 10:46 PM | #180 |
Just wanted to post up some new pics. I'm running 8-hole rc4wd wheels and mtr's now. Bouncy/ tippy feeling has been greatly reduced. Still needs a lil more weight down low but the new tires/ wheels have been essential to increasing performance. No contact/ neg offset issues whatsoever. Steering servo will have to be addressed soon imo. I also got rid of the portion of the cage that goes over top of the lights. I like the look better without it. Few pics of the action today... no breakage/ no lost parts/ 40+ minutes of run-time. Motor was barely warm to the touch. We left before either rig hit lvc. Last edited by high plains drifter; 06-13-2019 at 10:49 PM. |
New Axial scx 24 deadbolt - Similar Threads | ||||
SCX 10.2 Jeep XJ Body on SCX 10 Deadbolt? | sacsmitty | Axial SCX-10 | 5 | 08-15-2018 12:16 PM |
My new Axial SCX-10 Deadbolt | KA7EII | Axial SCX-10 | 4 | 05-21-2016 09:24 PM |
New scx 10 deadbolt | BigCountry11 | Axial SCX-10 | 8 | 07-25-2014 10:00 AM |
