Micro MT tires/wheels? I was thinking about converting a CR24 into a solid axle MT but can't find any tires and wheels that would fit? Does nothing exist? |
Re: Micro MT tires/wheels? A monster truck? Most use model kit tires and or wheels. The CR-24 uses the same 7mm hex as most other micro crawlers so the same combos would work Sent from my LGMP450 using Tapatalk |
Re: Micro MT tires/wheels? You could try using 1/24 monster truck model I believe revel has a couple on Amazon or eBay. Some Lego kits come with large wheels but both require some modding. Sent from my moto g(6) using Tapatalk |
Re: Micro MT tires/wheels? I use these. https://www.xinlehongtoys.com/xinleh...ts-139257.html Sent from my iPhone using Tapatalk |
Re: Micro MT tires/wheels? I used 1/24 MT model wheels on this: https://www.youtube.com/watch?v=SoJweT8G_a0 I took the rubber tire off of a trekker rim I think and glued it into the model rim so it could sit on the 7mm hex. it wasn't a perfect fit but I made it work. they look cool but since it's from a model the tires are basically plastic. they don't flex or anything. they're slightly rubbery so they have decent grip but they don't act like real rc tires. |
