05-30-2019, 03:32 PM | #41 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: SCX24 unboxing pictures Quote:
Sent from my LGMP450 using Tapatalk | |
05-30-2019, 04:23 PM | #42 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
| Re: SCX24 unboxing pictures |
05-30-2019, 04:53 PM | #43 |
Thanks for the feedback spoo76 |
05-30-2019, 06:21 PM | #44 |
So we know the electronics have a auxillary channel 3 with a 3 position switch, and 2 5v ports for LEDS. I was curious about the channel 2 pins and can confirm they work as an ESC bypass/pass through. Plug in an ESC like you would any receiver and it works. Sent from my LGMP450 using Tapatalk |
05-30-2019, 06:26 PM | #45 |
05-30-2019, 06:26 PM | #46 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
Curious what oil wt for the stock shocks or for the Carisma MSA-1E shocks? Also wondering if you would go significantly heavier ( 75wt) with a die-cast body?
05-30-2019, 06:37 PM | #47 |
I believe 25 weight is recommend, I went with 20. As far as Diecast IDK. That's more sprung weight than I'd like lol Sent from my LGMP450 using Tapatalk |
05-30-2019, 06:38 PM | #48 | |
Now that’s just great! Thank you for the information. That’s awesome! Sent from my iPhone using Tapatalk | |
05-30-2019, 07:21 PM | #49 |
Not having this in hand I'm not sure I follow you on the bypass. Is there a spot to plug in between the LED and brake? EDIT: nevermind reading comprehension DOH! Last edited by HumboldtEF; 05-30-2019 at 07:25 PM. |
05-30-2019, 07:27 PM | #50 | |
You can keep the Rx portion of the 2in1 and use your own ESC and be able to run the Tx as well as LEDs. Nice touch, Axial. | |
05-30-2019, 07:32 PM | #51 |
Oh that is nice! I was imagining a different scenario with a BEC (which I doubt these servos really need) but running a different ESC is something I was thinking of, I have a BR mini available. Thanks guys |
06-02-2019, 02:21 AM | #52 |
So since the axles are wide and the width is narrowed with the positive offset wheels I decided to try the wheels and hex on Barrage/RGT, CR-24 axles and it narrowed them to Trekker width. That could be useful for some builds. The wheels are very narrow and don't quit reach the bead of other 1.0 tires, but the tires do fit other 1.0 wheels fine. The scx24 wheels work best in RGT sized tires. Tonight I swapped to Hot racing aluminum wheels for the Losi Micro crawler, with Mil Stone hex weight wideners for the Losi Micro (not Trekker) and RC4WD Goodyear MTRs and it's unstoppable. Sent from my LGMP450 using Tapatalk |
06-03-2019, 09:58 PM | #53 |
So unfortunately like some others I had one cell of my SCX24's stock dynamite battery go below 2v. (Ended up below 1v!!) In my case I walked away for over an hour with it plugged in. Something I've never done before, but to my surprise the LVC never cut it off. The factory USB charger wouldn't recognize it, so rather than dig out my hobby charger to try and rescue the battery I tried my ambush charger hoping it was "dumb" enough to balance it. Sure enough it worked great and I now have a balanced pack again! Hopefully that will help someone that also has an Ambush or RC4WD USB charger, but no hobby charger. I was also about to solder up an adapter to go from the ESCs white JST PH 2.0 to the red JST RCY when I remembered, the RC4WD mini Gelande already has that adapter. now I can easily run my packs with JST RCY connectors. Sent from my LGMP450 using Tapatalk |
06-03-2019, 10:28 PM | #54 |
Located by the cuttters. Just cut the zip tie and unplug from the ESC Sent from my LGMP450 using Tapatalk |
06-04-2019, 07:55 AM | #55 |
06-04-2019, 07:58 AM | #56 |
I was about ready to warm up the soldering station to make an adapter when I remembered there was one already made lol Sent from my LGMP450 using Tapatalk |
06-11-2019, 07:24 PM | #57 |
Rock Stacker Join Date: Sep 2018 Location: cocoa
Any pictures of the Nissan body over the tires? How much is it actually off??
12-20-2019, 11:28 AM | #58 |
Newbie Join Date: Feb 2015 Location: Bonney lake
1/24 revell model kit with the short link set on the rear. Rc4wd steel wheels and reverse mounted baja claws Sent from my SM-N950U using Tapatalk |
01-03-2020, 09:19 PM | #59 |
Newbie Join Date: Dec 2019 Location: Augusta
is the gmc big game hunter? I like that look
01-12-2020, 11:49 PM | #60 |
SCX24 unboxing pictures - Similar Threads | ||||
Battery for SCX24 | Duramarks | Micro Scale Rigs | 3 | 05-17-2019 10:49 AM |
Pre-Order Now - New Axial SCX24 Deadbolt 1/24 Scale 4WD RTR | RPP Hobby | RPP Hobby | 0 | 05-16-2019 12:03 PM |
Axial SCX24 Trail Honcho | WAFFLE | General Scale Talk | 4 | 01-24-2014 04:42 PM |
