05-31-2019, 12:08 PM | #1 |
Quarry Creeper Join Date: Aug 2018 Location: Toronto, Canada
| Does the usb lipo charger that comes with the SCX24 work with other lipos?
The Horizon and Axial websites haven't been too helpful, but I'm assuming that the SCX24 included USB charger will work with other lipo batteries (smaller, micro packs, not those for 1/10 scale), right? It's neat little charger. |
05-31-2019, 12:16 PM | #2 |
Rock Stacker Join Date: Feb 2019 Location: Los Angeles
| Re: Does the usb lipo charger that comes with the SCX24 work with other lipos?
I think it should - pretty sure there’s a small guide printed on the charger itself that outlines some useful stuff about the types of batteries it can charge. I have mine here at the airport, I’ll pull it out when I settle down and read it off. Charges via the balance connector so I would assume any small 2S would work. Edit - it says: input: 5V2A output: 4.2v per cell 800mA max battery size 2S I feel like if it was intended only for the stock pack it’d have some sort of warning stating that. Last edited by jessedacri; 05-31-2019 at 12:21 PM. |
05-31-2019, 12:24 PM | #3 |
Thanks for the info. I've never charged lipos through a balance plug only - seems strange to me, so I'm extra cautious.
05-31-2019, 12:35 PM | #4 |
| Re: Does the usb lipo charger that comes with the SCX24 work with other lipos? Yeah - I’ll wait for some others to weigh in here too as I’m new to micro scale stuff. I like to be able to monitor voltages and charger activity through a traditional charger but this is definitely nice to throw in the backpack and go.
05-31-2019, 03:23 PM | #5 |
Pebble Pounder Join Date: Jun 2018 Location: SD, CA
Its not a bad way of charging. My Blade 130x heli came with a Horizon 2s charger that did it through the balance plug too, the lipo didn't have a standard discharge plug, just the balance plug. It also shouldn't be charged too fast through that lead though. |
05-31-2019, 03:27 PM | #6 |
Considering this charger doesn't have a storage charge option, how are you guys managing these little lipos? Keeping them fully charged? The manual says to charge them after use.. I feel like this is the first time using LIPO batteries Without having my traditional charger, this seems so foreign. |
05-31-2019, 03:33 PM | #7 |
No way man you'll puff them. Just run it down to 3.8 or 3.9. Use a lipo checker or regular voltmeter to check. You can also use the monitor function of your high end charger and check through the balance port. |
05-31-2019, 04:34 PM | #8 |
My plan is to try to round up a plug like the battery lead (not the balance plug) and to make an adapter that I can plug into a regular charger. I've only seen chargers like this before but I assume its doing a balance charge since its hooked up the the balance lead. I too though it was odd that they say after use charge again... wait what? |
05-31-2019, 04:49 PM | #9 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Yes it charges regular 2s lipos through the balance Port just like the Ambush or RC4WD's new USB charger for the mini gelande. Just make sure the USB charger you are using for the lipo charger gives at least 2 amps of current. as far as a storage charge I mainly use this for quick charging so a storage charge isn't needed unless you know you are putting it away for more than a few days. if you plan to store it you should get a proper balance charger to do a storage charge but I suppose if it was your first rc and only charger you could just drive it for about 25% of the time it took you to empty it. I would say 10 to 15 minutes should do it. Definitely invest in a lipo cell checker big are usually less than $5 and a very valuable tool Sent from my LGMP450 using Tapatalk |
05-31-2019, 04:59 PM | #10 | |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
| Re: Does the usb lipo charger that comes with the SCX24 work with other lipos? Quote:
Just got mine. Going to try to charge and/ or store with my IMAX B6AC v2. Last edited by high plains drifter; 05-31-2019 at 05:25 PM. | |
05-31-2019, 05:21 PM | #11 | |
All I know is I've been charging for about 3 hours and its still not done, it listed a 2 hour charge time. Anyway I wont be using this charger for too long. EDIT: oh and on the subject of odd things in the manual I found this line: "never lick or place any portion of the model in your mouth as it could cause serious injury or death"......noted Last edited by HumboldtEF; 05-31-2019 at 05:28 PM. | |
05-31-2019, 05:23 PM | #12 |
| Re: Does the usb lipo charger that comes with the SCX24 work with other lipos? |
05-31-2019, 05:30 PM | #13 | |
Sent from my LGMP450 using Tapatalk | |
05-31-2019, 05:37 PM | #14 | |
I did a tiny test at lunch driving over some shoes and I felt like the throttle control was very good much better than I expected. It should be a lot of fun and I can see a second one in my future. | |
05-31-2019, 07:26 PM | #15 |
Be careful with these, I just took mine with me on my first work trip and it broke on its second charge ever. Did some hotel room course building and crawling, went to plug the micro USB in and the whole female side of the port broke off The board. RIP travel crawler fun for this weekend. I emailed horizon in hopes theyll replace it. |
06-01-2019, 04:45 PM | #16 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
it can charge any other 2s lipo. it isn't very fast at it however! the largest concern with these is be careful when charging larger packs about how HOT it gets. if it overheats it could damage the charger! |
11-07-2020, 12:03 PM | #17 |
Rock Stacker Join Date: Jan 2015 Location: London, ON, Canada
Sorry for resurrecting a zombie thread, but this seemed like a good place to post my initial experience with the SCX charging setup... I wanted to check that the battery was properly Balanced out of the box, so I began by hooking it up to my Hitec X1 AC Plus charger. On the LiPo program and auto sensing, it recognized the battery as a 2S. The cells were perfectly balanced, and it took 11min 33 seconds to charge to full. I purchased a spare battery with the Deadbolt, and it was also perfectly balanced out of the box. The Initial cell voltages were 4.17V and 4.17V for the primary battery, and 4.16v And 4.16V for the spare. The spare battery only took 2min 28sec to top up. Strangely, the capacity numbers at full charge were around 185. The Hitech manual doesn’t say what units that represents, but it seems like an odd value for a 350mAh pack... Last edited by steve_rolfeca; 11-07-2020 at 02:29 PM. |
Does the usb lipo charger that comes with the SCX24 work with other lipos? - Similar Threads | ||||
Fast Lipo Charger for new lipos? | Jaymon | Electronics | 29 | 05-17-2010 12:45 AM |
