Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Axial scx24 mathcanbefun build
Old 08-10-2019, 08:55 PM   #61
Default Re: Axial scx24 mathcanbefun build
Originally Posted by mathcanbefun View Post
Thanks boss!
The claws are amazing.. They have alot more grip than the stock tires but they are smaller. You can find them at rc4wd or Amazon. The wheels are gearhead m-12's from RPP's website. The claws fit them with no glue if you use foams. If your not using foam it will depend on the quality of the tires you get (one of my tire was significantly less stiff than the other 3 tires and wouldnt stay on the rim, luckily they are cheap).
The rc4wd motor is good so far. I'm using the brass pinion that comes with it. It's definitely a little slower than stock. But that comes with a little more control and torque, but less wheel speed. Using the stock pinion might bump the speed back up.
I am also a fan of the bumper! Found that on thingiverse, sanded the heck out of it then painted it.
darn the claws are shorter? was hoping atleast the same height atleast! alright ill check them out thanks! what about the spacer weights? i dont care much for the wheel speed as the torque would be better imo anyways so thats perfect!
resetpunk is offline   Reply With Quote
Old 08-11-2019, 08:06 PM   #62
Noticeably shorter yes. They look more scale in my opinion but I liked the look of the stock tires too. Those are the mil spec spacer weights from ebay, originally made for Losi micros. They work great, but I had to paint them because the brass stuck out too much.
Sent from my Pixel 3 XL using Tapatalk
mathcanbefun is offline   Reply With Quote
Old 08-12-2019, 12:34 PM   #63
Ahh ok gotcha, did some looking and looks like there about 1/4” shorter.
I got crafty and did the pellet trick with my wheels for now and it worked out great! What’s the chance you could make me one of them bumpers and I could buy from you?
Axial scx24 mathcanbefun build - Similar Threads
IN-STOCK NOW the Axial Racing SCX24 Deadbolt 1/24 Scale 4WD RTR! RPP Hobby RPP Hobby 1 05-29-2019 04:16 PM
Pre-Order Now - New Axial SCX24 Deadbolt 1/24 Scale 4WD RTR RPP Hobby RPP Hobby 0 05-16-2019 12:03 PM
Axial SCX24 Trail Honcho WAFFLE General Scale Talk 4 01-24-2014 04:42 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
