Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: I am looking for custom driveshafts with 3mm hole
Old 06-13-2019, 06:03 PM   #1
Default I am looking for custom driveshafts with 3mm hole
I got a project I am working on that needs driveshafts with a 3mm hole. The shafts need to be 70-80mm long
Does anyone have any idea where I can find some? Ive searched the internet high and low and cant seem to find anything.
TheSubaruJunkie is offline   Reply With Quote
Old 06-13-2019, 06:27 PM   #2
The Orlandoo has some that 3mm size as well as the WPL.
Brake Weight is offline   Reply With Quote
Old 06-14-2019, 07:52 AM   #3
Default Re: I am looking for custom driveshafts with 3mm hole
There are no drivelines advertised for the WPL that are 60-80mm, unless you know of one that I don't. If so, please provide a link.
Also I just searched for the Orlando replacement driveshafts and those are way too large. No way that thing uses a 3mm hole. Unless there is another Orlando I am not seeing. Please provide a link if you know of something I do not.
Thanks.
Old 06-14-2019, 08:15 AM   #4
Thanks.
F.F.S. Please link the oversized Orlandoo shafts you found.
The Orlandoo shafts will be too short. I knew that when I posted but they do have some with 3MM holes.
https://www.amainhobbies.com/orlando...350-33/p568572
These max out at your minimum 70mm. They're pretty much all you're gonna find with that small 3mm output.
https://www.banggood.com/Racerstar-2...p-1380740.html
Old 06-14-2019, 09:35 AM   #5
Yeah you pretty much found the same stuff I found.
I am looking for custom driveshafts with 3mm hole - Similar Threads
Custom length driveshafts? corwin Losi Mini-Rock Crawler 3 09-16-2017 11:34 AM
custom driveshafts? xiteamxi General Crawlers 7 08-30-2011 01:30 AM
replacment driveshafts? or custom nissan7 Tamiya XC/CC01 1 09-12-2010 11:14 AM
Custom long driveshafts? Grind General Crawlers 4 04-09-2009 12:52 AM
