06-29-2019, 06:07 PM | #21 | |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
| Re: Scx24 4 linked front end Quote:
Thanks Adam! Can’t wait to see some future shit you bring to the table. I miss the good old micro days! Well this old turd got a big block new servo & kicks. Sent from my iPhone using Tapatalk | |
06-29-2019, 06:08 PM | #22 |
| Re: Scx24 4 linked front end |
06-29-2019, 11:52 PM | #23 | |
Rock Crawler Join Date: Apr 2012 Location: NewHampshire
ADAM **** YA! SO GLAD TO SEE YOU HERE! Sent from my iPhone using Tapatalk | |
06-30-2019, 06:43 PM | #24 |
Quarry Creeper Join Date: Mar 2011 Location: OrangeVale
Glad to see some OG’s builders posting Sent from my iPhone using Tapatalk |
07-05-2019, 12:05 PM | #25 |
Quarry Creeper Join Date: Jul 2015 Location: Menifee
07-05-2019, 01:06 PM | #26 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
07-05-2019, 01:40 PM | #27 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
07-05-2019, 01:49 PM | #28 | |
No gamyrc going on here but the brass brings the beef! Spoo spotted the OG tech | |
07-05-2019, 03:41 PM | #29 |
07-11-2019, 01:13 PM | #30 | |
You should be able to fit the 050. This is a 130 so it’s a mm or two longer & larger diameter than the 050. Well cms is almost done just have to lengthen the drag link. Sent from my iPhone using Tapatalk | |
07-12-2019, 05:25 PM | #31 |
| Re: Scx24 4 linked & cms
Got the cms & 3 link with panhard bar almost done. Sent from my iPhone using Tapatalk |
07-12-2019, 07:57 PM | #32 |
I just mentioned a cms the other night cause my servo is too big. That look great. Good work
07-12-2019, 08:56 PM | #33 |
Awesome as always Don! Sent from my LGMP450 using Tapatalk |
07-13-2019, 02:51 AM | #34 |
Newbie Join Date: Dec 2015 Location: Granite City
Are those Dubro 2-56 swivel ball eyelets on the steering control rod? What size tap is that? Sorry for all the questions
07-13-2019, 07:16 AM | #35 |
More pics!! Like how you mounted the servo and the Panhard Was going to run the 4 link in front. It’s my understanding that you don’t need a Panhard bar if you have a triangulated 4 link? Never had a cms |
07-13-2019, 10:51 AM | #36 |
07-13-2019, 11:04 AM | #37 | |||
Thanks John! Quote:
If you do a 4 link with cms you will have major bumpsteer. Last edited by chevy55; 07-13-2019 at 11:07 AM. | |||
07-14-2019, 08:41 AM | #38 |
| Re: Scx24 4 linked & cms I meant to ask you before. I know the steering link ends are sumo but what size all thread is that? And on the steering connecting rod did you just cut the brass tube and braze it on the end? It looks like you brazed up those Panhard mount too. Again great job. |
07-14-2019, 01:00 PM | #39 | |
| Re: Scx24 4 linked & cms Quote:
2-56 all thread. The track bar is 1/8 tube with 5/32 tube soldered on each end. Soldered up the mounts for the panhard bar too. I use a weller 8200 & .032 rosin core solder. Servo is mounted to a stock sumo servo mount then I used some brass strip to bend up a channel to fit between the rails. Panhard on the chassis side is screwed in & the axle side is epoxied on. I used some rectangle tube & made the mount fit into the pocket on the axles shock mount. Sent from my iPhone using Tapatalk | |
07-14-2019, 02:06 PM | #40 |
Thanks for the pics I was thinking that I could cut the back of the stock servo mount out and goop it to the back of my long servo about 8 mm longer than stock. Get some brass tube and cut them to the right lengths and just glue in the stock ends But I really like the cms you did will probably do that when I get home at the end of the year when I got tools |
Scx24 4 linked front end - Similar Threads | ||||
SCX24 3D printed Front battery mount | HumboldtEF | Micro Scale Rigs | 4 | 06-08-2019 09:59 AM |
Reworked front end in aluminum. Now with fastback style rear end. | Plush | Axial Wraith | 7 | 01-03-2018 12:04 AM |
Rear End Linked | LiftedSuzuki | General Crawlers | 21 | 05-29-2006 03:46 PM |
