07-02-2019, 08:23 PM | #1 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| HobbyPlus CR-24 aluminum shocks |
07-02-2019, 08:34 PM | #2 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
| Re: HobbyPlus CR-24 aluminum shocks
Interesting... wonder how much better the new spring rate is. Good find Spoo76!
07-29-2019, 02:46 PM | #3 |
Rock Stacker Join Date: Nov 2005 Location: Orange County
Nice! Just ordered some for my ECX Barrage 1/24. https://www.asiatees.com/display?id=...lus&model=CR24 |
07-29-2019, 08:40 PM | #4 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
Just put some on my SCX24. Unfortunately they're a bit stiff. Need to find softer springs or cut a few rings down. Nice shocks otherwise for sure. Last edited by punkindrublik; 08-01-2019 at 05:14 PM. |
07-31-2019, 10:40 AM | #5 |
Let me 3D Print that... Join Date: Jun 2007 Location: Concord
I was able to get these to work on my SCX24 with some modification. The lower ends don't work with the SCX24 ball studs, and as mentioned the springs are kind of stiff. I ended up drilling out the SCX24 lower perch/ball cup with a 1.6mm drill bit and threading them on to the 2mm CR24 shafts. Then I was able to use the SCX24 springs. Full articulation, and smooth as butter. |
08-01-2019, 05:07 PM | #6 |
Awesome!!
08-01-2019, 05:20 PM | #7 |
Nice work! I just ended up putting a sheath of shrink tube over the balls and the shocks seem to be staying on just fine so far. Looks like I may be trying to fit some those stock springs on myself. |
08-02-2019, 09:26 AM | #8 | |
| Re: HobbyPlus CR-24 aluminum shocks Quote:
Go for it! The soft springs work nice. | |
10-26-2019, 06:14 PM | #9 |
Newbie Join Date: Aug 2019 Location: Albuquerque
What did you use for the upper mount?
10-27-2019, 10:17 AM | #10 |
A piece of heat shrink over a m1.4x10mm screw. I have since changed that to just using the stock shock cap threaded onto the aluminum body.
HobbyPlus CR-24 aluminum shocks - Similar Threads | ||||
1/24 HobbyPlus CR-24 & new 1/18th scale!! | spoo76 | Micro Scale Rigs | 210 | 12-10-2022 03:13 AM |
HobbyPlus RC 1/18 CR-18 Crawler Ready-To-Run | BashNSlash | Micro Scale Rigs | 41 | 04-13-2020 06:58 PM |
Hobbyplus rc 1/18 CR-18 | Frank211 | General Scale Talk | 3 | 10-20-2019 07:17 AM |
Parts for the HobbyPlus CR-24 | BashNSlash | Micro Scale Rigs | 19 | 04-30-2019 07:41 PM |
Losi Aluminum shocks versus HR Aluminum shocks? | dave m | Losi Mini-Rock Crawler | 18 | 02-11-2009 01:33 PM |
