07-10-2019, 10:21 AM | #1 |
Rock Stacker Join Date: Sep 2018 Location: cocoa
| SCX24 steering upgrade
So since i have stuck on some wide wheels theres a bit of an issue with turning .. like it doesn't want to turn at all lol any kind of load on it just hinders it from doing anything whats the solution for this ? |
07-10-2019, 10:32 AM | #2 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
| Re: SCX24 steering upgrade
The stock servo is probably too week to turn the wheels with wideners. The servo saver doesnt help that either. I bought this servo off amazon and its 27oz or torque. IT will MOVE the truck if hung on something. This servo WILL turn the wheels with wideners and wheel weights. Last edited by BIGW0RM; 07-10-2019 at 10:37 AM. |
07-10-2019, 10:35 AM | #3 |
RCC Addict Join Date: Feb 2006 Location: ccxc
I did that same servo. Fits pretty well. I want to upgrade the steering links somehow. They flex way too much. I am thinking 4-40 rod maybe.
07-10-2019, 10:36 AM | #4 |
Awesome ill check it out thank you
07-10-2019, 10:37 AM | #5 | |
| Re: SCX24 steering upgrade Quote:
Look closely, you will see black o rings around my ball ends. You an see one showing on the bottom left. Huge difference! Last edited by BIGW0RM; 07-10-2019 at 10:39 AM. | |
07-10-2019, 11:04 AM | #6 |
I did do the O ring additions. Just seemed to me that the bar itself is flexy while playing with it.
07-10-2019, 11:34 AM | #7 |
| Re: SCX24 steering upgrade |
07-10-2019, 12:29 PM | #8 |
I tried the O-ring mod and I guess mine were just a bit too thick, they added resistance due to being so tight. I even tried to oil them up and it was still sticking. I've also upgraded my servo but left the stock links alone. I'm afraid if the linkage and servo are both strong something has to give, so yeah its a sort of servo saver. I'd wager with solid links whats likely to give then is the C-hub mounting holes and considering the size of the fasteners (anyone know what size?) I really dont want to stress them. Plus to fix this I think you'd end up needing a new front axle as they dont sell the little bits by themselves. @Alexg89 you could try removing the servo saver although I have no clue what the tooth count is, I know its smaller than most. I suppose worst case scenario you could try to glue the servo saver together so its solid. |
07-10-2019, 12:46 PM | #9 |
07-10-2019, 12:59 PM | #10 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
The only flex on my crawlers better be coming from the suspension not the steering setup. Servo savers are for go fast & basher rigs. How many people you see running servo savers & flexible linkage on a 1/10 crawler? Make it as solid as you can & keep your end points adjusted as not to put stress on your knuckles. Sent from my iPhone using Tapatalk Last edited by chevy55; 07-10-2019 at 01:10 PM. |
07-10-2019, 02:48 PM | #11 |
If it were a 1/10 scale I would absolutely agree but I just dont trust these tiny servos to be able to handle that. Servo savers are gone but I'm keeping the flimsy links. The link you made looks nice Last edited by HumboldtEF; 07-10-2019 at 02:54 PM. |
07-10-2019, 03:06 PM | #12 | |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
07-10-2019, 05:37 PM | #13 | |
I like what you did there. I thought about making my own links. But the c hub or whatever you call it that you put your long bolt through looks so thin. I worried the leverage from that long bolt would fatigue the c hub and stopped. Its my thinking they put the servo link to the offset to lesson the strain on the thin c hub. I dont know. But Im just saying I was going to do that too and stopped once I saw how thin the C hub is. Sounds like yours works just fine? If so i might revisit that. | |
09-16-2019, 10:08 PM | #14 |
Pebble Pounder Join Date: Jun 2008 Location: Modesto
Have you thought about the brass knuckles? That would alleviate your concerns for sure! They seem pretty beefy!
10-01-2019, 02:50 PM | #15 |
Pebble Pounder Join Date: Dec 2013 Location: NorCal
I just ordered new steering links from shapeways. They look to get rid if that play. A bit spendy @ $10, but I don't have a 3d printer or the knowledge to do it myself
10-01-2019, 06:53 PM | #16 |
Let me 3D Print that... Join Date: Jun 2007 Location: Concord
| Re: SCX24 steering upgrade Hey, at least you get two sets for that price. But seriously, I think you will be happy with the parts. A lot of folks have been using them.
12-06-2019, 06:01 PM | #17 | |
RCC Addict Join Date: Sep 2007 Location: Port Orange
12-06-2019, 09:24 PM | #18 |
I have the milstone wideners and rc4wd wheels. The oe servo can't turn them statically
12-07-2019, 12:23 PM | #19 |
| SCX24 steering upgrade Yes. It sticks out a couple mm though. You’ll need longer screws I believe. And you might have to trim bumper back side if using for the front. Look close. You’ll see how far forward the mount tabs on the servo are from the servo mount on the axle. Sent from my iPhone using Tapatalk Last edited by BIGW0RM; 12-07-2019 at 12:25 PM. |
12-07-2019, 05:38 PM | #20 | |
SCX24 steering upgrade - Similar Threads | ||||
BIGW0RM's SCX24 steering slop fix. | BIGW0RM | Micro Scale Rigs | 5 | 08-10-2020 05:32 AM |
SCX24 Shock upgrade ??? | JLOC | Micro Scale Rigs | 42 | 05-06-2020 12:38 PM |
SCX24 ESC Upgrade/Replacement | punkindrublik | Micro Scale Rigs | 22 | 04-09-2020 10:21 PM |
Steering upgrade | Satheddal | Axial SCX-10 | 8 | 05-22-2014 08:00 PM |
upgrade steering help. | jeremyfowler33 | Vaterra Twin Hammers | 15 | 03-30-2014 12:00 AM |
