07-24-2019, 10:35 AM | #1 |
Newbie Join Date: Jul 2019 Location: Cleveland
| Scx24 gearing
Hello, I am new to the forum but have been creeping around on it for quite awhile. I have been looking slower gearing for the scx24 and can’t seem to find anything. Bacially my end goal is to be able to really crawl over bigger obstacles instead of having to floor it and fly over things. Ideally full throttle will be nice and slow and have plenty of torque to crawl over things nice and easy. I want it to be smooth crawling instead of having to go so fast to make it over obstacles. Any help would be appreciated |
07-24-2019, 11:42 AM | #2 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Scx24 gearing Quote:
You can technically fit a larger Spur gear from a Losi micro Rally/SCT, but you'd need to come up with something better than the available options for a slipper. My Losi slippers don't seem to hold the gear in its center. The biggest i could fit was 57t, 59t wouldn't fit even with a fair amount of grinding on the output shaft. I ended up going back to a stock spur gear you'll also need a motor with higher turns (more wire wound on the armature) Stock is 88t, RC4WD is supposedly 90 or more. A longer motor from a barrage/RGT/ftx may also work, as well as mounting a 90t 130 "big block" motor. You can buy or make a motor mount for those. If you have an old Losi motor laying around you could also have it rewound by Dan. I have a 110t motor with 9t pinion and love it. Above all that the stock setup is much better than cheaper RCs like the Barrage, but a good programmable ESC will give you much better throttle control. Something like the Tekin B1R, or the Castle creations Micro Sidewinder, or micro Sidewinder V2, a Holmes mini would also work well Sent from my LGMP450 using Tapatalk | |
07-24-2019, 01:32 PM | #3 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
| Re: Scx24 gearing
The easiest way to accomplish this is to buy an RC4WD micro motor and slap it in there. It has a smaller pinion and offers a lot more torque. It wont stall with this motor. ANd its night and day. It plugs right in. You might have to switch the motor leads. But overall its cheap and highly effective without having to buy a lot of parts.
07-24-2019, 01:38 PM | #4 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
| Re: Scx24 gearing
Sumo or hbx trans swap is what your looking for.
07-25-2019, 12:35 AM | #5 | |
Quarry Creeper Join Date: May 2019 Location: North Highlands
07-25-2019, 10:00 AM | #6 | |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
07-25-2019, 10:18 AM | #7 | |
07-25-2019, 01:49 PM | #8 |
| Re: Scx24 gearing
What I'd like to know is where to get the planetary gearbox on the Rascal or one similar https://store.rc4wd.com/124-Rascal-A...et_p_7486.html I did a bit of searching and couldn't find anything besides larger gearbox's or smaller ones that come with motors spec'd at 3v. I dont know if the gearbox will only handle a 3v load or if its the motor they supply thats limited (I'm guessing its the motor). https://www.ebay.com/i/192342952964?...iABEgKagPD_BwE EDIT: digging a bit more and found this site with micro planetary gearbox's and a section for RC even! theres just a minimum order of 500... shoot http://www.microplanetarygearbox.com...rc-car-gearbox Last edited by HumboldtEF; 07-25-2019 at 01:59 PM. |
10-06-2019, 11:01 PM | #9 |
| Re: Scx24 gearing |
Scx24 gearing - Similar Threads | ||||
Whittling on a SCX24 | HumboldtEF | Micro Scale Rigs | 94 | 08-09-2021 07:42 PM |
Jeepin's SCX24 | JeepinOR | Micro Scale Rigs | 12 | 05-09-2020 08:30 PM |
Battery for SCX24 | Duramarks | Micro Scale Rigs | 3 | 05-17-2019 10:49 AM |
