Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: SCX24 “Bomber”
Old 09-26-2019, 07:07 PM   #21
Default Re: SCX24 “Bomber”
Originally Posted by redmike View Post
Attached is a link to the main STL files for this build. I would love to see pictures and/or hear feedback on here or through Thingiverse if you end up making one!
https://www.thingiverse.com/thing:3882295
Thanks for sharing the file. Hoping to print one out this weekend. Great job. Any other 3d printed stuff that you have done for the scx so far?
I started modeling the whole truck to try and come up with a cms setup, did some sliders, etc. but nothing too fancy yet.
tgh117 is offline   Reply With Quote
Old 09-26-2019, 07:33 PM   #22
Talking Re: SCX24 “Bomber”
Been working on an Oshkosh MATV MRAP body for it, but I’ve gotten distracted from that with a 1/16 MATV static model to rc conversion.
redmike is offline   Reply With Quote
Old 09-28-2019, 07:05 PM   #23
I have a bomber and an scx24 but this is cool!
Sent from my SM-G955U using Tapatalk
Jackalo626 is offline   Reply With Quote
Old 11-08-2019, 05:22 PM   #24
I'm printing the cage up as we speak, could I get a few more closer pictures.
roadrashracing is offline   Reply With Quote
Old 11-09-2019, 11:38 AM   #25
I just got done putting mine together. It went fairly easy but I did notice the holes for the shocks are to large and I ended up changing shock location. Any plans to put the newest version on thingaverse.
Old 11-10-2019, 08:49 PM   #26
The uploaded version is the last one I worked up. I was running aftermarket shocks, so I believe that was why the holes were larger diameter than the stock shock screws. Would love to see pics of yours once it’s all assembled.
Old 11-11-2019, 02:24 PM   #27
Damn thats so cool! I was just in here researching the best 1/24 to buy so that I could design and print and cage to make a sick little rock racer!!!
nedmo is offline   Reply With Quote
Old 11-19-2019, 04:08 PM   #28
I extended the cage to fit stock wheelbase and give a little more room for electronics.
Old 12-05-2019, 12:20 PM   #29
what does everyone use for hardware on this? the sock screws ? for mounting the skid onto the cage?
Toadady is offline   Reply With Quote
Old 12-20-2019, 11:08 AM   #30
Thanks for sharing this!!!
printed one to go with the JLU I got the kiddo for Christmas.
everything came out pretty well, but the lower chassis had alot of fleshing / extra on the 45* left and right. the Screw holes for the lower links are non existent.
can you post a photo of the lower part and how you put the screws into the links?
I'll post up some progress photos once he opens it and we start getting extra parts.
Thanks! - Buckshot
bdt00buckshot is offline   Reply With Quote
Old 07-21-2020, 04:41 PM   #31
Just printed one for my daughters C10 and its awesome! All the screw holes turned out to be the perfect size!
What did you use for the spare tire carrier on the back?
rknaub is offline   Reply With Quote
Old 07-22-2020, 02:46 AM   #32
Lol..finished my 3rd version of the cage. Made some changes so that I could fit a 600mah 1s lipo behind each “door” to basically make a 2s saddle pack as I didn’t like the way the 2s fit and was so visible..
That is ingenious. I was staring at mod19's super low cg battery tray, now i got to check side panel clearances!
Dogahn is offline   Reply With Quote
Old 07-22-2020, 08:47 AM   #33
great job on this build, Im so tempted to buy a 1/24 scale crawler, one of those things that I don't need it but I really want it
antigacho is offline   Reply With Quote
SCX24 “Bomber” - Similar Threads
Whittling on a SCX24 HumboldtEF Micro Scale Rigs 92 04-18-2020 01:20 PM
Scx24 gearing Cbake417 Micro Scale Rigs 8 10-06-2019 11:01 PM
SCX24 wb question halfcab Micro Scale Rigs 0 06-29-2019 10:01 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
