Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: jimbo74's SCX24 Deadbolt
Old 10-29-2019, 12:49 AM   #21
Default Re: jimbo74's SCX24 Deadbolt
Originally Posted by Itali83 View Post
Thank you. I mean I wanted to search connectors to make an adapter something like you bought. Either solder new ends on aftermarket battery or just make an adapter harness. Thanks again.
Ben
Yes, the plug is a ph 2.0
Honestly, I don't advise making your own. I tried. And it worked. But was not fun. The crimper is like $25 on it's own.
That pack of 6 harnesses was $8.99
Sent from my SM-G965U using Tapatalk
jimbo74 is online now   Reply With Quote
Old 10-30-2019, 01:51 AM   #22
Harnesses and new batteries.
Old 11-05-2019, 08:23 PM   #23
Test
Old 12-09-2019, 03:32 AM   #24
ok, so long term update.....
I put my mil stoone spacers back on....
I did notice that my RC4WD wheels inside of the hub rubs on the rear screws sticking out of the backing plate face
also noticed becaue I am running the mil stoens with the barrel nuts that I had to make sure to properly enlarge the axle hole in my wheels. they weren't enough, and actually made my wheels not sit flush on the hub and they wobbled like crazy. I reamed them out, and they are much better
and I realize I really need to upgrade my servo, I can't turn if it isn't moving
Old 12-10-2019, 02:26 AM   #25
so, I just trimmed my body quite a bit
anyways, while I was in there, I was looking @ some stuff.....
has anyone mounted the shocks directly to the frame and not to the shock towers?
Old 12-10-2019, 07:48 AM   #26
has anyone mounted the shocks directly to the frame and not to the shock towers? I realize it will raise my cog..... but.....
Raising the height that much would change geometry enough you'd probably want to lengthen your links. I've seen it done, but I don't recall how it performed on stock links
Sent from my Pixel 3 XL using Tapatalk
spoo76 is offline   Reply With Quote
Old 12-10-2019, 11:54 AM   #27
MEOW
Natedog's Avatar
I got that .050" RPM driver. So nice
Love my RPM drivers! Great looking truck Jimbo, but I like the look better without the wheel wideners.
Originally Posted by scaled View Post
These work.
Wiha and Wera drivers have been good tools ime, here's a great place to buy them if they arent' available locally.
https://www.kctoolco.com/Wera/
Well, just ordered some new batteries and adapter harnesses. Will be running jst plugs. they are floureon and larger capacity
Nice, wondering which lcg battery setup is better this size battery mounted up front or the longer skinny lipo mounted out back?
I've got a nice set of ratcheting crimpers that I've used many times, well worth the money. HOwever, smallest connector I've made is JST, the ph2.0 is smaller and will be more of a challenge, but I'd try it just buy bunch of the parts and give it a shot. Don't bother with cheaper non-ratcheting crimpers, I had a set that I gave away. It's hard enough holding wire, conductor and crimpers and keeping all lined up while crimping.
X2
Old 12-10-2019, 12:17 PM   #28
I did it with the rear shocks, moving the upper mounting point forward, but not the front
Sh0rtBus is offline   Reply With Quote
Old 12-10-2019, 12:53 PM   #29
ok, so I did some more modding based off of responses I got on FB..... truck has like no compression up front now, it's all droop. rear still has a little bit. I moved the top of the shock mounts even mroe inward toward the center
Old 12-10-2019, 02:50 PM   #30
Just ran it outside. It crawls way better.
I am rubbing the middle link with my driveshaft though up front, it chewed into the Y link on 1 side.
And my tires still rub like crazy @ the back of the front wheel well @ the firewall. So I want to trim that back some more. Maybe to the door. The fronts are going to look like a flat fender Jeep, lol
Old 12-11-2019, 07:46 AM   #31
Looks great man! A little tire rub never hurt anyone. Hell, I had rub on the front frame rails with my 1:1 Jeep and it never hurt anything. I relocated the rear shocks on my SCX24 the way you did but haven't done the fronts yet. I think I tried but something was preventing me from being able to. I just don't remember what. I did swap places with the battery mount and ESC mounts so I could distribute more weight up front, but I don't remember why I couldn't leave my front shocks mounted to the frame rather than the shock mounts. Glad to know it works, though.
Old 12-13-2019, 08:30 PM   #32
I have heard of adding an o ring or 2 to my shock body above the collar and spring to get a little more pre-load, what size?
And also adding an o ring to the shock eyelets to help cut some of the slop, what size there as well?
Old 12-13-2019, 11:02 PM   #33
So I ordered an rc4wd motor and es09 servo....
Old 12-14-2019, 01:27 AM   #34
new trim
Old 12-15-2019, 12:21 AM   #35
Rc4wd motor should be here tomorrow and es09md should be here on friday
EDIT: Got the motor!!!
Old 12-16-2019, 01:05 AM   #36
so, I am noticing on my stock motor that the black wire is soldered to the + terminal..... is this correct? does it matter?
Old 12-16-2019, 01:07 AM   #37
Mine was that way and I had to solder the Rc4wd in that way too. No big deal.
Ben
Itali83 is offline   Reply With Quote
Old 12-16-2019, 02:19 AM   #38
I got lucky, looks like mine is actually being delivered. Tomorrow too. Also getting the shapeways ES08 mount tomorrow so Iíll see how it all mounts up.
noel2 is offline   Reply With Quote
Old 12-16-2019, 08:26 PM   #39
got my new motor in, did not put the capacitor from the oe motor on the new one, I couldn't get it off without destroying it
don't really notice a speed or torque difference
oh well
Old 12-16-2019, 09:59 PM   #40
My experience as well
Sent from my Moto G (5) Plus using Tapatalk
scaled is offline   Reply With Quote
jimbo74's SCX24 Deadbolt - Similar Threads
Mod19RC SCX24 Deadbolt Build RexRacer19 Micro Scale Rigs 16 10-06-2019 11:00 AM
Axial SCX24 deadbolt epic dusk run shenlonco Scale Videos! 0 07-25-2019 08:40 AM
Axial SCX24 deadbolt special test..... shenlonco Scale Videos! 0 06-17-2019 02:44 PM
Axial SCX24 deadbolt first run! shenlonco Scale Videos! 0 06-07-2019 05:51 PM
Pre-Order Now - New Axial SCX24 Deadbolt 1/24 Scale 4WD RTR RPP Hobby RPP Hobby 0 05-16-2019 01:03 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
