01-17-2020, 02:29 AM | #61 |
Quarry Creeper Join Date: Dec 2016 Location: Sweden
| Re: jimbo74's SCX24 Deadbolt
Tried to find the adapter cables. Can you link? Also is the connector that goes into the ESC called PH 2.0? Skickat från min iPhone med Tapatalk |
01-17-2020, 02:33 AM | #62 |
Pebble Pounder Join Date: Dec 2013 Location: NorCal
| Re: jimbo74's SCX24 Deadbolt |
01-17-2020, 02:54 AM | #63 |
Many thanks Skickat från min iPhone med Tapatalk |
01-17-2020, 10:05 AM | #64 | |
Quarry Creeper Join Date: Feb 2015 Location: Amongst the UTards
| Re: jimbo74's SCX24 Deadbolt Quote:
Sent from my Moto G (5) Plus using Tapatalk | |
01-17-2020, 10:24 AM | #65 |
Newbie Join Date: Jun 2017 Location: The Bay
| Re: jimbo74's SCX24 Deadbolt I was considering a BEC for my setup but I'm not sure how it would be wired since the receiver and ESC are one unit, which means you can't disable the ESC's BEC. Wouldn't the external BEC and internal BEC 'fight' each other?
01-17-2020, 07:42 PM | #66 | |
01-19-2020, 01:03 AM | #67 |
OK guys, you all were right... I tried it again with the dual rate turned down. I turned it down, until it didn't brown out anymore. It wasn't much adjustment @ all, and I still have quite a bit of steering also, there is now 2 zip ties on the right front (the other 3 only have 1 zip tie), to help with the weight bias of the motor making it lean right. seems a lot more flat now in my testing |
01-23-2020, 04:03 PM | #68 |
Newbie Join Date: Jan 2020 Location: Canada
When I put some O-rings to fix the slop on the steering I noticed that the dual rate could be backed off quite a bit and reduce minor binding at full lock... it's about half or 3/4 way... can still turn the same amount just much less stress on the servo pushing it further than it wants to... On mine it looked like it was forcing the linkage to bend.
01-23-2020, 09:47 PM | #69 |
Mine was fixed with backing off the dual rate. Backed it off in little increments, and stopped when it went away. I have the shapeways linkage. It was actually causing the white plastic horn to deform |
01-24-2020, 10:40 PM | #70 |
New pic |
01-25-2020, 04:41 PM | #71 |
Pebble Pounder Join Date: Feb 2012 Location: Freakville
Did you have any issues with the hex on the axles? The hex on the SCX seems larger than that on my RC4WD wheels.
01-25-2020, 10:39 PM | #72 |
No issues. Oem fit fine. I am currently running milstone spacers, and those fit fine also Last edited by jimbo74; 01-25-2020 at 11:16 PM. |
01-26-2020, 07:21 AM | #73 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Sent from my Pixel 3 XL using Tapatalk Last edited by spoo76; 01-26-2020 at 10:36 AM. | |
01-26-2020, 10:20 AM | #74 | |
01-27-2020, 05:07 PM | #75 |
Newbie Join Date: Jan 2020 Location: LEXINGTON
Hey jimbo74, I have been looking for a good battery option for the SCX24 and wanted to know how you are getting on with the Floureon batteries. Do you like them? |
01-27-2020, 05:40 PM | #76 | |
Never had a problem with the stock batteries, other than the goofy plugs though. I did try to make my own PH 2.0 connecyors, and that was a nightmare... After I got the batteries and adapters, good to go. | |
01-27-2020, 05:44 PM | #77 | |
Never had a problem with the stock batteries, other than the goofy plugs though. I did try to make my own PH 2.0 connectors, and that was a nightmare... After I got the batteries and adapters, good to go. | |
01-27-2020, 05:47 PM | #78 |
They have been great. Never had a problem with the stock batteries, other than the goofy plugs though. I did try to make my own PH 2.0 connectors, and that was a nightmare... After I got the batteries and adapters, good to go. |
01-27-2020, 06:05 PM | #79 |
| Re: jimbo74's SCX24 Deadbolt Awesome, thanks! I just ordered my SCX24 and wanted to go ahead and get a few more batteries. I'll definitely grab those adapters too, as to save the headache of making my own.
jimbo74's SCX24 Deadbolt - Similar Threads | ||||
Mod19RC SCX24 Deadbolt Build | RexRacer19 | Micro Scale Rigs | 34 | 02-03-2022 11:53 AM |
Axial SCX24 deadbolt epic dusk run | shenlonco | Scale Videos! | 0 | 07-25-2019 07:40 AM |
Axial SCX24 deadbolt special test..... | shenlonco | Scale Videos! | 0 | 06-17-2019 01:44 PM |
Axial SCX24 deadbolt first run! | shenlonco | Scale Videos! | 0 | 06-07-2019 04:51 PM |
Pre-Order Now - New Axial SCX24 Deadbolt 1/24 Scale 4WD RTR | RPP Hobby | RPP Hobby | 0 | 05-16-2019 12:03 PM |
