Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Carisma updated the MSA1-E !
Old 10-10-2019, 02:02 PM   #1
spoo76's Avatar
Default Carisma updated the MSA1-E !
Firstly I know nothing other than the information I'm sharing from Facebook.
They are supposedly available now.
"Ahhh the patter of Tiny Tyres!
Meet our latest release, the New MSA-1E 1/24th 1976 Ford F-150. New gearing, new Motor with protection circuit, new Servo Saver and new Fully Licensed Ford Body."
https://youtu.be/5oZNvWadVoU
When they say new motor and gearing I have a suspicion that's"marketing talk" and it will have the same sized motor. IMO the N20ish sized motor is way too small. Gearing is likely a pinion Chang or hopefully a different spur/idle gear replacement. I hope it's better than expected, because the first version had a nice soft suspension, but the lack of power was disappointing.
Either way it's awesome to see so many micro trucks out and getting updated! Hopefully this is a sign the market is taking micros seriously.
Sent from my Pixel 3 XL using Tapatalk
spoo76 is offline   Reply With Quote
Old 10-10-2019, 02:12 PM   #2
Default Re: Carisma updated the MSA1-E !
That’s awesome. I wonder if they’ll release an unpainted body, too.
Had a buddy with one with the 390ci.
Brake Weight is offline   Reply With Quote
Old 10-10-2019, 02:34 PM   #3
spoo76's Avatar
I would assume they will, I believe I saw the previous versions available separately and clear.
After looking at it more closely it definitely looks like the same undersized motor. It's basically a long can N20, but now it has a "protection circuit" I guess since the others would burn out even with a heat sink...which I find odd for a slow crawler.
Updated gearing im willing to bet is just a smaller pinion, because that weird spur gear,shaft, idler gear would likely be to expensive to replace. If that's the case it will pretty disappointing and not much better than V1, time will tell however. I probably won't pick this one up, which is a first for me haha.
It's crazy that we have so many currently available scale/crawler Micro trucks.
The Redcat Sumo/HBX Devastator/FTX Ibex are of course still available.
ECX Temper, garbage electronics and wonky link geometry but cheap and decent for axles in a custom build
WPL 24438 & 24438B which look like a Temper, but are slightly different. Same meh quality
RC4WD Mini Gelande is still available
The ECX Barrage/RGT Adventurer/FTX Outback
Which were nearly identical other than bodies and tires.
The RGT V2 has that's front mounted motor,
The FTX 2.0 is a rebadged HobbyPlus CR-24
HobbyPlus CR-24, which now has a body updated with plastic molded parts and more to come
HobbyPlus CR-18 which has widened axles & longer chasis, stronger links & stronger plastic driveshafts with metal universals
The Carisma MSA1-E which got some minor updates.
The SCX24 which already has an updated body and unsurprisingly is killing it in popularity and somewhat in aftermarket
The Panda Hobby Tetra X1 which has lots of details and feels premium
That's 12 RTR micro trucks with 1.0" wheels and 7mm hexes excluding the Barrage clones, but counting the new RGT.
Old 10-10-2019, 02:43 PM   #4
That's mind blowing.And couple years ago you had redcat and losi.Is harder and harder to justify"scaling up"
bolo79 is online now   Reply With Quote
Old 10-10-2019, 07:20 PM   #5
The great thing with the better designed models is that they are pretty reliable and you can find challenges everywhere inside and out. Best money spent in the hobby IMHO.
Sent from my Moto G (5) Plus using Tapatalk
scaled is offline   Reply With Quote
Old 10-10-2019, 09:49 PM   #6
spoo76's Avatar
So the motor is definitely the same size, the pinion has been confirmed to be a 9t instead of a 14t. Should make a noticeable difference, but IMO still not enough with that puny motor
Old 10-12-2019, 04:55 PM   #7
Agreed
Sent from my SM-G955U using Tapatalk
Jackalo626 is offline   Reply With Quote
Old 10-13-2019, 12:39 PM   #8
Voodoobrew's Avatar
Thanks, this list is great!
Sent from my SM-N950U using Tapatalk
Voodoobrew is offline   Reply With Quote
Old 10-14-2019, 12:08 AM   #9
Talking Re: Carisma updated the MSA1-E !
Don't forget the basher rocksta from hobbyking!
Although it's not scale, it's fun as well!
Bennie98 is offline   Reply With Quote
Old 10-14-2019, 12:39 AM   #10
spoo76's Avatar
I didn't forget it, I specifically was mentioning scale trucks that are similar, with compatible parts. Though it is fun
Old 10-15-2019, 02:09 AM   #11
Oh, okay, I didn't notice you meant your list like that. Sorry!
Old 10-15-2019, 02:21 AM   #12
spoo76's Avatar
No worries. This is the scale section so I was just keeping with the theme. The Rocksta is so much more capable it takes completely different lines haha
Carisma updated the MSA1-E ! - Similar Threads
Teaser Carisma.... Frank211 General Scale Talk 31 03-07-2019 05:10 AM
No spot for Carisma? HKSkook Chit Chat 6 12-29-2018 04:00 PM
1/24 carisma?????? Frank211 Micro Scale Rigs 26 12-19-2018 03:13 AM
Carisma 1/24 Crawler sethstiles Micro Scale Rigs 0 11-12-2018 02:42 PM
A kit.... CARISMA ?? Frank211 General Scale Talk 27 07-25-2018 12:11 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
