06-18-2020, 01:27 PM | #1 |
Newbie Join Date: Jun 2020 Location: Central PA
| SCX24 motor swap require capacitor?
Hi guys, been lurking. Now working... on my Deadbolt. Burned out the stock motor in two days, Axial replaced it, but I also just got the RC4WD 030 based on the recommendations here. Old stock motor had a blue capacitor(?) attached, but the new replacement Axial/Dynamite motor does not. Though it does have some big old coils of some kind under the shrink wrap tubing. I'm not familiar with what those might be. I really just want to wire up the RC4WD unit and drop it in to check out the difference in torque, but do I need to include a capacitor or other component of some kind? I swear I searched, but didn't see that specific issue on the many motor swap threads. Apologies if I missed it. |
06-19-2020, 07:44 AM | #2 |
| Re: SCX24 motor swap require capacitor?
Ok, I did some homework and found that capacitors are added to brushed motors to reduce interference between the transmitter and receiver. So now that I'm up to speed, is that a standard practice, are you guys doing that when you drop a new (unwired) motor into the SCX24? Any tips or recommendations on components or technique? Wonder where I can pick up capacitors with no more Radio Shacks around. Last edited by TrickyMickey; 06-19-2020 at 07:44 AM. Reason: Formatting |
06-19-2020, 12:50 PM | #3 |
Pebble Pounder Join Date: Aug 2014 Location: Merrimack
I’m running the barrage motor in mine with no capacitors and have had zero interference. I’m not sure what would happen if the truck was far away, I’m usually not more than 6 feet away. Sent from my iPhone using Tapatalk |
06-22-2020, 01:31 PM | #4 | |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: SCX24 motor swap require capacitor? Quote:
06-22-2020, 02:05 PM | #5 |
Cool, thanks for the input, guys. Won't worry about it then!
06-24-2020, 07:52 AM | #6 |
Newbie Join Date: May 2020 Location: Lake Worth
How does the RC4WD motor stack up against the barrage?
Tags |
rc4wd, scx24 motor |
SCX24 motor swap require capacitor? - Similar Threads | ||||
motor capacitor | Jstalker | Electronics | 2 | 05-25-2010 04:12 PM |
Motor Capacitor question | dj23gsx | Electronics | 0 | 01-27-2009 05:49 PM |
Tekin FXR motor capacitor. | customclodcrawler | Electronics | 4 | 01-22-2009 05:50 AM |
novak motor capacitor | aljeann | Axial AX-10 Scorpion | 9 | 07-14-2008 08:37 AM |
