11-06-2019, 05:03 PM | #1 |
Newbie Join Date: Oct 2019 Location: Michigan
| Cariama MSA-1E vs Axial SCX24 - anyone have both?
I’m looking at picking up a 1/24 crawler Anyone have both the Carisma MSA-1E and the Axial SCX24? Looking for which one would be better Pros and cons for each? Last edited by Hoyle; 11-06-2019 at 05:09 PM. |
11-06-2019, 05:23 PM | #2 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Cariama MSA-1E vs Axial SCX24 - anyone have both? Quote:
This may not bother you, but I'm not a fan of the ugly non scale looking chasis, but it works fine and the truck handles well. The biggest complaint I have is the undersized motor that lacks torque and has the motor stall out when the wheels are loaded or in a bind. The plastic is also MUCH better and stronger than almost any micro/mini crawler other than the Panda Hobby Tetra X1, however unless it's for a child that's bashing it, the plastics are strong enough on the SCX24. The SCX24 on the other hand performs much better with it's worm drive axles that offer more gear reduction, and more axle clearance, as well as taller tires. Though you say you're not planning to modify it much, there's better stock and upgrade parts support for the SCX24 It's also nice that the SCX24 has auxiliary LED ports and a working 3rd channel. Another plus for the SCX24 is that it comes with a 350mah 2s lipo instead of the tiny 7.2v NIMH pack in the Carisma which gives pretty short run times. I and most will say get the SCX24 for the same money, but it's not like the Carisma MSA1-E is bad. If you're planning on slow crawling the SCX is the way to go. Sent from my Pixel 3 XL using Tapatalk | |
11-07-2019, 12:37 AM | #3 | |
Newbie Join Date: Jun 2015 Location: South Korea
I completely agree with Spoo76. I have both. MSA has such an underpowered motor and it died a week ago. So I ordered a new motor and bought SCX24 too. With a weak motor, MSA performs more like a trail truck, while SCX24 crawls like 1:10. And scx comes with 2cell lipo battery that allows more than 1-hr of run time. MSA comes with really small Nimh battery. Moreover, scx24 has a lot more after-market parts such as 3d printed hop-ups at Shapeways, which allows you to use bigger motors, cage-type hard bodies, new steering links. Sent from my iPhone using Tapatalk Last edited by makemehi2; 11-07-2019 at 12:41 AM. | |
11-07-2019, 12:47 AM | #4 |
The smaller pinion in the Carisma with the Ford body should help noticably considering how big it was already. I think it was 14t which is oddly large for a crawler with an undersized motor. (Also odd there is a heat sink) However I still think the motor is to small. Sent from my Pixel 3 XL using Tapatalk |
11-07-2019, 12:51 AM | #5 |
050 barrage left Carisma which is a long can N20 middle 030 Losi motor, but the same size used in almost every other micro crawler like the SCX24 right Sent from my Pixel 3 XL using Tapatalk |
11-08-2019, 09:53 AM | #6 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
I did the 050 motor conversion in one of my rc4wd gelande crawlers I have only bench tested it mounted to the tranny but it sounds way better so far.
Cariama MSA-1E vs Axial SCX24 - anyone have both? - Similar Threads | ||||
SCX24 ESC/Rx in a Charisma Coyote Pup (MSA-1E)? | MrSquiggles | Micro Scale Rigs | 3 | 07-19-2019 10:58 AM |
Axial SCX24 Battery Question | 13thwarrior | Electronics | 4 | 06-09-2019 07:05 PM |
Axial SCX24 deadbolt first run! | shenlonco | Scale Videos! | 0 | 06-07-2019 04:51 PM |
Axial SCX24 Trail Honcho | WAFFLE | General Scale Talk | 4 | 01-24-2014 04:42 PM |
