Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Where are you guys getting spare SCX-24 batteries?
Old 12-28-2019, 09:10 AM   #1
mtm
Default Where are you guys getting spare SCX-24 batteries?
I am having trouble finding spare batteries for my SCX24. I can't find the correct size battery with the JST PH 2.0 2 pin plugs already installed. I can make adapters but I'd rather just buy them already ready to go. Where are you guys getting them?
mtm is offline   Reply With Quote
Old 12-28-2019, 09:18 AM   #2
Default Re: Where are you guys getting spare SCX-24 batteries?
You can order from eBay
I found a lot of upgraded packs with higher mah ratings for longer run time
https://rover.ebay.com/rover/0/0/0?m...2F193153172032
Just search for dynamite battery
I would stay at 30c burst or under imo
But youíll have the plug you need with these batteries unless you want to change your terminal
I also donít use the crap usb charger.
I have a balance charger I use and I charge the stock battery at .30 amp takes about 1 hour compared to 2 hours with the 350mah on the USB if it even works. I had two usb failed so axial sending new ones
bryan.hamm0nd1981 is offline   Reply With Quote
Old 12-28-2019, 09:22 AM   #3
Check my thread
jimbo74 is offline   Reply With Quote
