Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Adding weight to wheels
Old 02-03-2020, 09:32 AM   #1
Default Adding weight to wheels
Should I do all four or just front two?
I have wheel wheel weights and extenders on all four.
bryan.hamm0nd1981 is offline   Reply With Quote
Old 02-03-2020, 11:44 AM   #2
Default Re: Adding weight to wheels
I added weight to all my wheels. I used the scale to somewhat balance my front and rear end weight to be equal. Not just the tires. I would put the front end on the scale, then the rear end until whatever wheel weights matched front to back.
BIGW0RM is offline   Reply With Quote
Old 02-03-2020, 12:20 PM   #3
After writing this post I realized my front
Is already slightly heavier so it would make sense to add new weight front and back and keep it close to more in front
Old 02-04-2020, 05:07 AM   #4
I added weight to both the front and rear. 3 wraps on the front, and 2 wraps in the rear
rob5059 is offline   Reply With Quote
Adding weight to wheels - Similar Threads
Adding weight to wheels? RICrawler Redcat Crawlers 15 03-13-2011 05:15 AM
How much weight are you guys adding to your wheels? BigB_117 Axial SCX-10 9 07-22-2009 08:21 PM
What are you guys doing about adding weight to the wheels Happy_trucker Team Losi Comp Crawler 4 06-04-2009 06:32 PM
adding weight the wheels. msd44 Newbie General 23 02-19-2008 09:47 AM
Adding Weight 93yj6044 General Crawlers 11 05-23-2006 08:42 AM
