Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Got my tires on
Old 02-04-2020, 08:45 AM   #1
Default Got my tires on
Added 6g of weight to each wheel inside. Super swampers with foam.
Handle side hill and uphill inclines no problem. My phone level said 45 degrees but that may be a degree or two off from the buttons in the phone.
Just waiting on my new SUV body post from shapeways as the first one I ordered broke.
bryan.hamm0nd1981 is offline   Reply With Quote
Old 02-04-2020, 09:09 AM   #2
Default Re: Got my tires on
Looks great. Aftermarket tires make a huge difference on this truck
waqr is offline   Reply With Quote
Old 02-04-2020, 09:11 AM   #3
For sure. I canít wait to get it in real world but it handled well on some broken cinder blocks thrown around.
Iím not sure if I should of left the foam out but too late now. Worse case I order another set in future when these wear out.
Old 02-04-2020, 09:29 AM   #4
Also noticed one tire was backwards so just re glued it the correct way
Old 02-04-2020, 10:25 AM   #5
I run all my micros foamless.
Brake Weight is offline   Reply With Quote
Old 02-04-2020, 10:39 AM   #6
Doh....
Next time.
I do switch inbetween a heavier body tho so I was worried the tires would just fold.
Maybe Iíll order another set. Donít want to try and take these off and ruin them.
Old 02-04-2020, 10:59 AM   #7
These are out of stock now but may come across fleaBay. Not as good as the RC4WD tires but better than the little ATs.
https://www.asiatees.com/display?id=...RER&in=1&pid=1
Old 02-04-2020, 11:00 AM   #8
I have these already.
Too small for me but super sticky
I put them on the kids truck
Old 02-04-2020, 11:09 AM   #9
Look at getting some Scramblers if you want them big. Theyíre AT but sticky and conform well foamless on lighter rigs.
Old 02-04-2020, 11:42 AM   #10
I have tall scramblers and without foams, I could not sidehill much at all. I went with the softest micro wheel foam I could find.
https://www.amainhobbies.com/crawler...xoCrdsQAvD_BwE
Almost as soft as foamless. But with some support for side hilling. But Im using a very tall and flimsy micro tire.
BIGW0RM is offline   Reply With Quote
