03-09-2020, 07:34 AM | #1 |
Quarry Creeper Join Date: Dec 2016 Location: Sweden
| RGT Adventure V2 change gearing
Hi! This truck seems very nice but the gearing looks to be a bit high. Is there any way to change the gearing or is there an aftermarket motor that fits directly without any modification that will give the truck more controllable low end? |
03-10-2020, 06:42 PM | #2 | |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
| Re: RGT Adventure V2 change gearing Quote:
You could buy the RC4WD micro motor and snag its smaller pinion to swap onto your rgt motor. I didnt know what size they where to order just a pinion, so that's how I got a smaller one on mine. And or, you can also buy the RC4WD micro transmission and motor combo for 29 bucks and then order the 10 dollar shapeways brackets needed to mount it to the RGT frame. When I had my RGT, I did the RC4WD tranny/motor combo with the shapways brackets. I then removed the small RC4WD motor (FF030) and I think used the RGT long can motor (FF050) WITH the smaller pinion that WAS on the RC4WD motor if that makes sense. Good luck! Last edited by BIGW0RM; 03-10-2020 at 06:44 PM. | |
03-11-2020, 09:19 PM | #3 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
I haven't opened up my RGT V2 to inspect the transmission yet, but I'm sure the pinion is the same 12t most are using. Swapping to a 9t pinion would help a little. Not sure on the spur tooth count. I'd bet it wouldn't be hard to get a bigger spur, but I think swapping to a Mini Gelande V2 transmission wouldn't be ideal since it has a motor mounted to it and the RGT V2 has a front mounted motor Sent from my Pixel 3 XL using Tapatalk | |
03-12-2020, 09:45 AM | #4 | |
Doh! Thank you Spoo76. My bad. I missed the V2 part. Sorry gentlemen. | |
RGT Adventure V2 change gearing - Similar Threads | ||||
SXC10 ii new build di i need to change gearing | stewartcjones | Axial AX10 2nd-gen | 1 | 12-21-2020 08:39 AM |
1/24 RGT scaler out on a adventure | shenlonco | Scale Videos! | 0 | 06-03-2019 12:32 PM |
New motor. Change gearing? | coldfire | Axial AX10 2nd-gen | 3 | 04-29-2015 08:49 AM |
Montana Scale Adventure Club Adventure Series | montana.matt | Montana | 9 | 03-17-2010 09:22 AM |
