04-11-2020, 11:10 PM | #1 |
Rock Stacker Join Date: May 2015 Location: North Lakes, QLD
| Easy SCX24 Wheel Track Wideningering.
Hey guys, bit of a random discovery when I was looking at my RCs this afternoon - you know, looking for a project while I wait for parts and a couple of new kits. I looked at the SCX24, and thought about it's most disappointing characteristic - top heavy (Deadbolt) and tips fairly easily - I then happened to look at the small push-rod "things" I had out when I put a brushless system in a tiny H100 boat and... then my brain actually worked for a change. It was enough to move the wheels out noticeably, the internal tire to tire measurement is now 81-82mm ish. I left the standard hex in place as the spacer holds it there so the pin won't pop out, these use the standard nylock nut as well. Used a small amount of loctite to keep em on and have been out wheeling on my little pile of stay at home rocks, better performance, looks better, easy to do and easily reversible - good times. I was hunting for a standoff from a motherboard but I didn't have any luck so I am unsure if they would accomplish the same thing. (They don't, although the hex matches the thread itself is larger). Of course, if you get into a bind situation or don't use loctite you will have a wheel come off as forward movement would loosen the wheel/spacer assembly off the hub, not a perfect solution but until hot-racing make brass spacers and sell them for $40USD it will do haha. Last edited by Chicken Man; 04-13-2020 at 12:02 AM. |
04-11-2020, 11:14 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Easy SCX24 Wheel Track Wideningering.
Cool low buck find! As far as "until HR makes a brass spacer" there are brass Milstone spacers available on eBay. Sent from my Pixel 3 XL using Tapatalk |
04-12-2020, 01:31 AM | #3 |
| Re: Easy SCX24 Wheel Track Wideningering. Ah, I just hadn't searched for the right thing. They are stupid expensive to get to Australia but definitely cool.
04-12-2020, 11:32 AM | #4 | |
| Re: Easy SCX24 Wheel Track Wideningering. Quote:
Sent from my Pixel 3 XL using Tapatalk | |
04-12-2020, 04:31 PM | #5 |
It's all good, I added an Oring to fill out the hex and put some thick solder in the front and back rims - about 7 in each of the fronts and 3 in each of the backs. Totally different beast, was really quite disappointed out of the box but you can actually call it a crawler with a couple of mods. The next iteration is going to be drilling out a M4 nut for the hex and press fitting it to the push rod thingy. Definitely on the hunt for a new servo though, fairly weak unit stock. |
04-12-2020, 05:03 PM | #6 |
The servo itself isn't the best, but I've noticed the servo saver and steering tie rod are bigger steering issues. The servo saver is weak, and even with an upgraded servo the steering tie rod has slop and the bar will bend and flex in a bind. When upgrading the servo a home made tie rod from metal tube would be a worthwhile upgrade IMO Sent from my Pixel 3 XL using Tapatalk |
04-12-2020, 05:09 PM | #7 | |
Pebble Pounder Join Date: Jan 2020 Location: Kent, UK
If aus is like the uk, on imported goods we get, item price, postage, customs duty, VAT and customs duty surcharge, I ordered a set of the spacers, the millstones were not listed then, and I think it totalled £50+.. that was half way to a new truck. I am currently trying to find a way to add non rotating weight to mine, because I keep reading that the rotating weight is not good. Element Sendero 1/10. Crawler/Trailer. Scx24 crc. Crawler 1/24. Wltoys a212. Shortcourse 1/24. Wltoys k969. Drifty 1/28 | |
04-12-2020, 06:08 PM | #8 |
Rotational weight isn't the best for various reasons, but there's always a balance of pros and cons with everything. Weight in the knuckles is better, because it's non rotational. however at this scale with limited space and size things get tricky. There's also the issue of cost vs value. It's best to play around with what works for you. Sometimes the cons are so minimal while true, you may not notice. Sent from my Pixel 3 XL using Tapatalk |
04-12-2020, 07:44 PM | #9 |
In the time of reeeaaaallly long postage delays I think it's about making the most of what you actually have on hand. Rotational weight is fine for micros imo, a little goes a long way as well, I would love to have the Hot Racing upgrades but they are at least a month away if I ordered now .. hell, perhaps two or more with all the restrictions. I replaced the servo with an Emax I originally ordered for the Autorc 1/24. It's fine for now but I am about to head into the garage and look at making some custom links out of copper tube, I knew buying heaps of random stuff from Hobbyking when it was on sale was a good idea haha. I definitely think one of the best little upgrades is full orings, takes all the slop away and almost offers a bit of damping. The video is really rushed, anyone with kids will understand >.> I didn't get any side hill action, maybe later. https://www.youtube.com/watch?v=njGw...ature=youtu.be Last edited by Chicken Man; 04-12-2020 at 07:56 PM. |
04-13-2020, 12:07 AM | #10 | |
This is before I swapped things around but just for anyone browsing, the two o-rings elevate the tie-rod and remove any play without restricting steering. I put them on almost every joint on the rig but if you only do two.. it's these two. Last edited by Chicken Man; 04-13-2020 at 12:11 AM. | |
04-13-2020, 12:36 AM | #11 |
You could also use a tube, pinch the ends, drill through the pinched ends to screw into the knuckles Sent from my Pixel 3 XL using Tapatalk |
04-13-2020, 04:34 AM | #12 |
| Re: Easy SCX24 Wheel Track Wideningering. |
04-13-2020, 08:06 AM | #13 |
Very clever mod! |
04-13-2020, 08:32 AM | #14 |
Quarry Creeper Join Date: Aug 2018 Location: Toronto, Canada
What's the part number of the stuff you used? I came on this morning wanting to ask about where to get barrel nuts to make my own wheel wideners and this came up so I'm interested! |
04-13-2020, 10:28 AM | #15 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
Those almost look like motherboard stand off screws? Are they just tighten onto the threaded axle and then use the wheel nut on the stand off thread? https://www.staples.com/StarTech-com...SABEgIEOfD_BwE |
04-13-2020, 10:32 AM | #16 | |
04-13-2020, 10:59 AM | #17 | |
Yeah, I do not like wheel widener kits. Having to drill the wheel hole out for the barrel nut to fit bugs me. I had to drill my RC4WD beadlocks to work with the milstone kit. Meh. This is one of the reasons I use the HBX monster truck wheels. No adapters and you get the same output stance. But you are limited on tire choice due to there wideness. Last edited by BIGW0RM; 04-13-2020 at 11:02 AM. | |
04-13-2020, 11:09 AM | #18 |
Ah, my computer stand offs are 6/32th. Not metric. Though there seem to be metric ones out on amazon. But I still dont understand how the tires will not spin freely if the hex hub nut is not there. Unless Im missing something...
04-13-2020, 02:45 PM | #19 | |
Now for the expensive allow wheels I might be hesitant to drill into them. Sent from my Pixel 3 XL using Tapatalk | |
04-14-2020, 06:37 AM | #20 |
Standoffs aren't the right fit, the push rod things I used were a random purchase ages ago - was pretty hard to find where I got them from haha. These are them: Here Not in stock currently but yeah, should be able to find something similar. It's just a fluke that they have exactly the same thread diameter etc as the SCX24 axles. |
Easy SCX24 Wheel Track Wideningering. - Similar Threads | ||||
Wheel and tire options for the SCX24 | chino | Micro Scale Rigs | 21 | 07-05-2021 09:56 PM |
Scx24 - adding wheel weight. | Exalted85 | Micro Scale Rigs | 4 | 08-15-2020 08:04 PM |
SCX24 sealed wheel bearing size? | narr8or | Micro Scale Rigs | 2 | 01-23-2020 06:04 PM |
Scx24 wheel nuts | dirtman71 | Micro Scale Rigs | 4 | 07-07-2019 08:30 AM |
ecx barrage 1/12 gen 2 WIDE TRACK WHEELBASE MOD EASY! | shenlonco | Scale Videos! | 0 | 07-27-2018 02:28 PM |
