05-15-2020, 01:27 AM | #1 |
Quarry Creeper Join Date: Dec 2016 Location: Sweden
| Jerky movement Orlandoo 1/35 Jeep
I am having some problems with my newly built Orlandoo Hunter Jeep. The problem is that I get a pulsing movement when applying throttle which makes it really hard to crawl in a controllable way. I have been told that this could be due to incorrect phasing of the driveshafts but I have tried to align them properly but I still get this jerky movement when going in both forward and reverse. If there is no load on the truck (tires in the air) it seems very smooth. Any ideas. Attached is a video and a picture of my driveshafts. Are they properly aligned and do you think they could cause this issue? Thanks https://www.youtube.com/watch?v=3EXcZRCvnbE Last edited by waqr; 05-15-2020 at 01:33 AM. |
05-15-2020, 06:14 AM | #2 |
Rock Stacker Join Date: Jan 2015 Location: westminster
| Re: Jerky movement Orlandoo 1/35 Jeep
I would check the gears first. Then the esc would be my next guess
05-15-2020, 06:39 AM | #3 |
The axle stubs are not clocked right. Disconnect the driveshafts and spin each axle independently by the driveshaft. You’ll find the binding. At least with the one I had built.
05-15-2020, 08:58 AM | #4 | |
| Re: Jerky movement Orlandoo 1/35 Jeep Quote:
What do you mean by this? Please explain a bit more Skickat från min iPhone med Tapatalk | |
05-15-2020, 09:27 AM | #5 | |
Same issue as what you described just different words. Disconnect the driveshaft and spin each axle independent of the transmission. Eliminate this possibility. Then spin the transmission independent of the axles. Eliminate this possibility. Then run the motor and transmission with no axles. You could also pinch the transmission output with your fingers to simulate the axles attached. | |
05-15-2020, 10:16 AM | #6 |
| Jerky movement Orlandoo 1/35 Jeep Last edited by waqr; 05-15-2020 at 10:22 AM. |
05-15-2020, 10:22 AM | #7 |
Without the wheels on it sounds normal https://youtu.be/Ia9R-7NH7hk Skickat från min iPhone med Tapatalk |
05-15-2020, 12:08 PM | #8 |
Do not tighten the wheel nuts so tight. Possibly do one wheel at a time to see where it is making contact. There is something causing friction there. Can you see anywhere external that is rubbing? Remove the axle lockouts and look for rubbing inside. |
05-15-2020, 01:42 PM | #9 |
No sign of rubbing. Strange thing is that when the wheels are spinning with no load everything is smooth but as soon I put it on the ground the pulsing motion comes back. See video https://youtu.be/3ATd0bp_cD0 Skickat från min iPhone med Tapatalk Last edited by waqr; 05-15-2020 at 11:41 PM. |
05-21-2020, 10:22 AM | #10 | |
Rock Stacker Join Date: Apr 2016 Location: U.K.
05-22-2020, 04:50 AM | #11 |
| Re: Jerky movement Orlandoo 1/35 Jeep Will have to check that but I think they are moving in the same speed.
Jerky movement Orlandoo 1/35 Jeep - Similar Threads | ||||
Jerky movement when steering left | waqr | Micro Scale Rigs | 9 | 01-23-2020 09:35 AM |
Orlandoo Jeep Lipo | Ryanf58 | Micro Scale Rigs | 3 | 10-11-2017 07:38 PM |
Orlandoo Jeep | Ryanf58 | Micro Scale Rigs | 0 | 09-30-2017 07:29 PM |
Orlandoo Jeep | AZDIGGER | Micro Scale Rigs | 12 | 10-31-2016 02:44 PM |
