06-25-2020, 03:38 PM | #1 |
Pebble Pounder Join Date: Aug 2014 Location: Merrimack
| Brushless motor
Cariama 8000kv = broken drive shaft & bent axle. Pics and video once it’s up and running again. Sent from my iPhone using Tapatalk Last edited by PFongemie; 06-25-2020 at 04:04 PM. |
06-25-2020, 03:48 PM | #2 |
Rock Crawler Join Date: Apr 2012 Location: NewHampshire
| Re: Brushless motor
You should probably add some context to this random post Sent from my iPhone using Tapatalk |
06-25-2020, 03:51 PM | #3 |
| Re: Brushless motor |
06-25-2020, 04:54 PM | #4 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Brushless motor
It's not surprising parts broke. It's an 8000kv brushless motor on a worm gear crawler, with what looks like a large pinion and small spur offering less gear reduction than stock.
06-25-2020, 05:30 PM | #5 | |
| Re: Brushless motor Quote:
Stock spur just the .05 mod. 15t pinion. New pinion arriving tomorrow. It only broke when I started doing doughnuts. With throttle control I can crawl as slow as stock. Sent from my iPhone using Tapatalk | |
06-25-2020, 07:45 PM | #6 |
| Re: Brushless motor
If it's mod 0.5 and the same tooth count, then it's not the same gearing as the stock mod 0.3. Different gear pitch has physically larger teeth, which makes larger gears. It helps to think of them as pulleys rather than gears in this case. You have the same gearing as going to a bigger pinion and smaller spur which makes it really fast, as well as a fast high KV motor. It's not a good setup for a crawler as it's going to lack low speed throttle control, but it will be fast and break parts. Keep an eye on motor and ESC temps with that gearing. Sent from my Pixel 3 XL using Tapatalk |
06-25-2020, 07:50 PM | #7 | |
I ran 2 a full through a full battery crawling with my son and his stock Scx24 had no issues all that is needed is throttle control. Yes it is fast if I choose. But I only did this to see if I could. Also after a battery and a half the motor was cooler then the stock set up. Esc was also fine. The sidewinder micro can handle it. Sent from my iPhone using Tapatalk | |
06-25-2020, 07:54 PM | #8 |
Rock Stacker Join Date: Feb 2014 Location: Canada
| Re: Brushless motor
I think the problem is the worm gears. If you put that motor into a crawler with normal gears in the axle you’d have a fast little rig going.
06-25-2020, 07:57 PM | #9 | |
It’s fast even with the worm gears. Like I said the axle broke when I was doing doughnuts. The rear axle broke at the steering knuckle. Looks like the t bone popped out of the cap. Bent the pin. I’m going to play with the gearing to see what I can change. Sent from my iPhone using Tapatalk | |
07-08-2020, 06:05 PM | #10 |
Rock Stacker Join Date: Apr 2020 Location: San Francisco
| Re: Brushless motor
Stock esc? I might grab one now.
07-08-2020, 06:12 PM | #11 |
| Brushless motor |
07-08-2020, 06:28 PM | #12 | |
You might also check that the pins on the ends of the dogbones are secured as they do pop loose. I've used CA to fix them. If those pop loose the pin does a lot of damage to the knuckle, it may even break it. | |
07-09-2020, 06:57 PM | #13 | |
That’s exactly what happened. The pin came out slightly, ground into the brass hub and twisted till the axle snapped Sent from my iPhone using Tapatalk | |
03-09-2021, 09:33 AM | #14 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
