07-17-2020, 06:59 PM | #21 |
Quarry Creeper Join Date: Jul 2020 Location: Lincoln
| Re: What's breaking on your SCX24's?
I have 2 of the little guys. The only real broken part I have seen so far was the stock motor which burnt up. I have doing mini comps with the little guy before the COVID shut those down.
07-18-2020, 02:48 PM | #22 | |
Rock Stacker Join Date: Jun 2020 Location: Gresham
| Re: What's breaking on your SCX24's? Quote:
I'm just burned out on people burning the messenger/carriers for their inconveniences. | |
07-20-2020, 06:09 AM | #23 |
Newbie Join Date: May 2020 Location: Lake Worth
Yes the servos are crazy weak. My pending upgrades will be the servo, steering linkage, and servo mount. They are currently There is also a 3d printed servo mount on shapeways. Only $2 cheaper than the aluminum, but a good option if you want to keep the weight down. Not a bad spot for some weight being axle mounted though. Shapeways also carries the upgrade steering linkage. I'm running stock and haven't broken anything, but my truck has the easy life. It is my bad weather only run indoors car.
07-23-2020, 09:07 PM | #24 |
Newbie Join Date: Jun 2016
I bought two of them and the throttle stopped responding on both of them about two days in. My son played with them pretty hard, but nothing is broken or wrecked. It was like the battery died, put a new battery in and no throttle response. I've tried 4 different batteries in both vehicles but neither will respond. Axial support suggested it was the ESC stuck in a low voltage cutoff and said I should send them both in under warranty. What do you guys think the issue is?
07-23-2020, 10:48 PM | #25 | |
That sounds like the servo most likely, unplug it or swap with a known good servo (even if its the wrong size) and re-test. A bad servo can do some odd stuff back feeding voltage to the ESC or in this case preventing the ESC from powering up. Last edited by HumboldtEF; 07-23-2020 at 10:52 PM. | |
07-23-2020, 11:12 PM | #26 | |
Is there a way to tell if the motor is dead? Or is it more likely a power issue on the ESC? | |
07-24-2020, 10:47 AM | #27 | |
You could test the motor by sending power directly to it. Take a few AA batteries and tape them end to end so they connect, tape some wires to the exposed ends (+ & -) then touch these to the terminals on the back of the motor (where the wires are soldered). You'll have to pull back the heat shrink protecting these to make contact. If 3 volts from the 2 AA's isnt enough to spin the motor try adding more batteries. Keep in mind this will spin the motor up to full speed (for this voltage) so be ready for that. | |
08-27-2020, 06:51 AM | #28 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
my ESC died after the 3rd or 4th run, and I haven't touched the truck since. What ESCs are you guys using?
08-27-2020, 01:10 PM | #29 | |
Newbie Join Date: Aug 2020 Location: Vienna
Sarkis | |
09-05-2020, 11:35 AM | #30 |
Quarry Creeper Join Date: May 2013 Location: no-water-no-trees-country
| Re: What's breaking on your SCX24's? |
05-19-2021, 11:13 PM | #31 |
Newbie Join Date: May 2021 Location: .
I have a HiTec HS-5065 laying around and I'm hoping that I can use it in the SCX24. Does anyone know if the HR EMax servo mount is also compatible with the HiTec? I saw some mention of cross compatibility on Shapeways, but nowhere else. Is it safe to assume that the EMax is the go to servo due to it's price point? The specs on the HiTec are a little better and am curious as to why no one is using it. |
05-20-2021, 12:56 AM | #32 | |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
05-20-2021, 01:50 AM | #33 | |
Sorry didn't mean to question the quality of the EMax, it seems solid and if that's what I end up with I'm cool with that, I'm just trying to use what I have on hand to fix the shortcomings of the SCX. | |
05-20-2021, 05:44 AM | #34 | |
Pebble Pounder Join Date: Aug 2020 Location: Ohio
Yes, since the Emax is about $10, gives way better performance that the stock servo, and kind of fits into the stock servo tray, it is the most recommended servo upgrade. Other servos can be used with custom trays. Savox, Reefs, AGF-RC, NSDRC | |
05-20-2021, 07:15 AM | #35 |
| Re: What's breaking on your SCX24's? To be honest, if I still worked for a hobby shop and had a variety of servos to look over easily, I would have started with a HiTec or Savox as a comparison, since I do not, I went with the EMax since it’s known to work and Hot Racing offers a metal servo mount made to put them on these trucks.
05-20-2021, 10:10 AM | #36 |
My JLU should arrive by Saturday, I’ll try and put the 5065 in and report back. EMax's website shows that from the back of the ear to the bottom of the spline is 9mm and the measurement I just took of the HS5065 is 8.75mm, so it should work. Does the HR EMax mount move the servo forward and if so by how much? Last edited by _e_w_; 05-20-2021 at 11:10 AM. |
05-20-2021, 04:26 PM | #37 |
Rock Stacker Join Date: Jun 2019 Location: Fishers, In.
The EMax servo doesn't suck but the upgrade to a Savox is well worth the money. I have one with an EMax, one NSDRC and 2 Savox. The Savox are outstanding. Haven't got a chance to try the NSDRC yet but I'm expecting good things. Motors suck. Barrage motor is a bit better. Personally, I'd go brushless. |
05-20-2021, 05:04 PM | #38 | |
I ordered an HR Emax mount, which I should have next week. Good to know about the Savox servos, I'm considering one or two for something else. Eventually I will go brushless, since I plan to add some brass, but will stick with the stocker until it burns out. | |
06-27-2021, 06:47 PM | #39 |
Rock Stacker Join Date: Aug 2020 Location: Philadelphia
killed a emax servo, and even a reefs servo and a barrage motor
07-03-2021, 03:31 PM | #40 |
Newbie Join Date: Aug 2007 Location: home
What's breaking on your SCX24's? - Similar Threads | ||||
Outdrives keep breaking | sixhundred71 | Axial Wraith | 8 | 02-29-2012 06:17 PM |
breaking the barrier | eric113 | Chit Chat | 2 | 07-21-2011 09:06 PM |
Breaking Down | house_Fly | Chit Chat | 5 | 12-12-2009 08:53 AM |
