Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Micro Hardware
Old 09-14-2020, 11:47 AM   #1
Default Micro Hardware
I found a couple places selling screw kits, but I can't find the tiny ball studs (for the steering links, shocks, etc) anywhere.
Does anyone know where to source some? Do you guys have a go-to hardware kit for your micros and minis?
Bray D is offline   Reply With Quote
Old 09-15-2020, 10:16 AM   #2
Let me 3D Print that...
RexRacer19's Avatar
Default Re: Micro Hardware
For the SCX24 the best source I've found for the $$$ is to buy the shock set. You get 8 ball studs.
RexRacer19 is offline   Reply With Quote
Old 09-15-2020, 11:38 AM   #3
That's what I was worried about.
McMaster is usually my go-to for hardware. They have 1.4mm stuff but it's crazy expensive; $1 per screw in some cases! They also don't have ball studs that small.
Sounds like buying OEM is the best bet right now. Thanks for the insight.
Old 09-20-2020, 04:51 PM   #4
M1.4 hardware is inexpensive from UXCell via Amazon
shiggy is offline   Reply With Quote
Old 09-21-2020, 12:32 PM   #5
Nice. I did a quick search but didn't find an assortment. Do you have a link?
Looks like HR offers a decent 1.4mm screw set. I'm pondering picking up one of these:
https://www.amainhobbies.com/hot-rac...14mss/p1224218
Old 09-22-2020, 11:51 AM   #6
The HR set is out of stock.
No assortment packs from uxcell. I bought several bags of 20-50 bolts, washers, or nuts. The bolts in 3-4 different lengths. Total cost was still under $15.
I needed to poke through the search results and double check they are actually the correct size.
Also, get a proper 1.3mm wrench. I tried a .05” (1.27mm) I had and stripped a couple of bolt heads.
Old 09-22-2020, 11:55 AM   #7
uxcell M1.4x12mm Alloy Steel Hex Socket Head Knurled Cap Screw Bolt Black 20pcs https://www.amazon.com/dp/B01MXJJ52P..._pPJAFbGNWQX45
Wera - WER118064 05118064001 Kraftform Micro 2054 Hexagon Electronics Precision Screwdriver, 1.3mm Head, 40mm Blade Length https://www.amazon.com/dp/B003ES5MDU..._WQJAFbE5WK5DT
Old 09-22-2020, 09:38 PM   #8
Solid info. Thanks shiggy.
Good to know about the .050” driver failing you, too. I’m using a machined .050” tool at the moment and it even seems snug at times. I may pick up a proper 1.3mm wrench just for the sake of SI purity.
Old 09-23-2020, 09:08 AM   #9
I have both a MIP 1.3mm & a .050" the 1.3mm seems a little to big I get a much better fit with the .050" (1.27mm) sometimes you have to wiggle the .050" to get a good tight fit.
Gramps is offline   Reply With Quote
Old 09-23-2020, 04:26 PM   #10
My experience is the opposite.
.05 is looseish no matter what.
1.3 is snug and secure.
Micro Hardware - Similar Threads
Yeti Stainless Hardware Kit from Team KNK Hardware Team KNK Axial Yeti 23 07-03-2016 11:35 AM
Team KNK Hardware Stainless Steel BULK Hardware and kits Team KNK Tools and supplies 23 02-15-2016 04:41 PM
Stainless Hardware Kits from Team KNK Hardware NOW AVAILABLE for the Ascender Team KNK Vaterra Ascender 4 04-03-2015 07:00 PM
NOW AVAILABLE Twin Hammers Stainless Steel Hardware Kit from Team KNK Hardware Team KNK Vaterra Twin Hammers 5 01-15-2015 10:17 AM
Team KNK Hardware Stainless Steel Bulk Hardware and Kits Team KNK Vendors Market 17 01-15-2015 10:11 AM
