09-23-2020, 10:01 PM | #21 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: FMS ROC Atlas 6x6 Quote:
I also have many Barrage and scx24 motors as well as other 030 and 050 motors, I also have lots of brass pinions all with 1.5mm holes and swapped the same pinions between motors and many others have as well. The actual official measurement of the gear teeth is called "mod 0.3" it's what it's sold as when listed. The equivalent in "pitch" is close but I don't think it's exact as it's a different way to measure and not even common or easy to find last I looked, either way if you want to find a pinion that works it's going to be "mod 0.3" with a 1.5mm motor shaft hole. Some have used 8t and have had them break. I prefer 9t for the smallest for a 1.5mm shaft as it has a little more material. Sent from my Pixel 3 XL using Tapatalk Last edited by spoo76; 09-23-2020 at 10:08 PM. | |
09-24-2020, 12:55 AM | #22 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
0.3 modulus is a 85pitch ;) https://helihack.co.uk/modulus But what about the spur gear ? Is there any chance to put a bigger than stock in it? I found this --> https://de.aliexpress.com/item/32861...24745131DDrTI3 Would that fit ? Last edited by themountain; 09-24-2020 at 01:05 AM. |
09-24-2020, 09:30 AM | #23 | |
Rock Stacker Join Date: Jul 2020 Location: Dead Center WA
The SCX24 press-on pinion “fits” on the Barrage but just spins under power. My main frustration is I can find ZERO aftermarket pinions. Searches return nothing. I really want a few 9-10t pinions and am coming up dry. Last edited by shiggy; 09-24-2020 at 10:56 AM. | |
09-25-2020, 06:42 PM | #24 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
I dont get email notifications anymore!! Yes my pinions were from Poland microantrieb.com. I bought 10 of them a couple years ago. Very hard to find. Micro heli and slot car resources are sometimes effective sources. If you get brass ones, make sure to heat them with a lighter before pressing them on, otherwise they could split because of the thin wall. |
09-25-2020, 06:45 PM | #25 |
Also, I think that spur gear may have come out of an SCX24
10-01-2020, 11:25 AM | #26 |
Ok I have found the ultimate micro crawler gearbox setup. I used the stock Atlas gearbox and mated it to a divorced transfer case from an RGT Adventurer. The RGT transfer case is ~2.5:1 ratio so it basically cuts my final ratio in half. This is the perfect combination of low voltage torque and wheel speed IMO, and works excellent on the Atlas 6x6 and should work on any micro crawler. To do it, I cut away some of the radio platform above the front axle to make room for the low platform I printed. The output shaft and drive dog cups from the RGT are 2mm instead of the 3mm like on most gearboxes. Instead of drilling out one of the cups to 3mm, I just modeled one with a 3mm hole with a D flat then printed it. Also printed a new radio platform that sits between the motor and the battery tray. Ill try to get some video of the crawl speed. |
10-01-2020, 04:13 PM | #27 |
| Re: FMS ROC Atlas 6x6 Last edited by Shape_Shifter; 10-01-2020 at 04:35 PM. |
10-01-2020, 06:08 PM | #28 | |
Also got a couple of RC4WD FF-030 micro motors with 10t brass pinions. | |
10-01-2020, 06:10 PM | #29 |
| Re: FMS ROC Atlas 6x6 Quote: Not sure what I am looking at without a pic of the stock truck for comparison. |
10-01-2020, 08:26 PM | #30 | |
Those FF-030 motors are great for 1/24 stuff but will struggle with the 6x6. Good to have for other projects though. | |
10-01-2020, 08:29 PM | #31 | |
Good point. That's because my installation is so awesome, it looks stock The Atlas is basically a CR-18 with an extra axle. I didnt take any "before" pics but if you look for Spoo's CR-18 threads, Ill bet he has some stock pics. | |
10-01-2020, 11:33 PM | #32 |
| Re: FMS ROC Atlas 6x6 |
10-08-2020, 10:08 PM | #33 |
10-08-2020, 10:30 PM | #34 |
| Re: FMS ROC Atlas 6x6 So, did you move the stock transmission/motor to the front and install the “new” transfer case in the middle?
10-10-2020, 02:25 PM | #35 | |
Yes, that is exactly what I did. The new transfer case mount holes are the same as the stock motor/tranny so it bolts right up. Its an easy way to "bolt on" higher ratio gears. | |
10-10-2020, 05:42 PM | #36 |
10-10-2020, 11:14 PM | #37 |
| Re: FMS ROC Atlas 6x6 No, a higher ratio is slower and has more torque. For example: 4:1 is a high ratio, but slower - 1:1 is a low ratio, but faster. When people talking about drive trains use the term "lower gears" they actually mean a higher gear ratio. |
10-11-2020, 08:38 AM | #38 | |
1:4 would be high, with output four times faster than input. In a full size vehicle first gear is “low” gear. Fifth gear is “high”. You gear down to go slower. Gear up to go faster. | |
10-11-2020, 09:35 PM | #39 | |
No. In math, science, and industry, an example of a high ratio would be 20:1 As a rule - if the difference between the two numbers is large, it is considered a high ratio. 4:1 is a higher ratio than 1:1. As I said, above, "When people talking about drive trains use the term "lower gears" they actually mean a higher gear ratio." Just because 1st gear (1) is a lower number than 5th gear (5), doesn't mean the ratio of the actual gears in the transmission is lower in 1st gear. . . | |
10-23-2020, 05:25 PM | #40 |
FMS ROC Atlas 6x6 - Similar Threads | ||||
FMS Atlas 6x6 Crawler 1/18 | donaldsneffe | General Scale Talk | 16 | 01-24-2022 04:43 AM |
FMS Atlas 6x6 | RødeDK | Multi Axle Rigs | 4 | 09-07-2020 09:22 AM |
team atlas? | a_vdk | Electronics | 18 | 02-01-2017 02:42 AM |
Ford atlas | losikid | Chit Chat | 9 | 02-10-2013 03:36 PM |
Atlas 2, kind of..... | Eritex Inc. | Chit Chat | 171 | 10-16-2008 08:14 PM |
