FIRST EVER IFS SCX24 crawler kit 20 Attachment(s) So after my recent Jeep LJ builders kit endeavor I decided to of course test my CAD capabilities again with the wild hair of designing an IFS kit for the SCX24... again cause why not:lmao: So having no idea where to even start something like this, I just parted out one of my other chassis designs in CAD, took out all the components and parts of the chassis I wouldn't need in the program and most of the front half and started designing. the chassis I threw in there was just to help me gauge space and where I had room to put things, it wasn't permanent. I would later get rid of that chassis and start designing around the new front end components. I designed the front end to be 120mm outside tire to outside tire which we've found to pretty much be the sweet spot. I wasn't quite able to get the front suspension travel I wanted out of the front end but its still more than a stock scx24 plus the rear end has WAY more travel than stock so the rear makes up for what I was trying to get out of the front due to the trailing arms in the rear. Another thing that I wanted was an all flat belly pan and a little wider to give more space in the cab for electronics. The car has just about the same steering ratio as stock which I felt like should be close to the same cause they steer pretty good once you throw an emax servo at it. Steering travel will be the same as stock or slightly more since I designed CVD axles for the front just like the bigger cars. I also designed this to take a brushless system just like my U4 build that I posted up on here a few months back, this will use the same brushless system and a fan bolts to the bottom of the interior above the motor to help keep the motor cool. I was just about to pull the trigger on getting everything printed then a guy on fb sent me a pair of cvd axles he found for another little car that were steel that were within a couple MM length of what I had designed. the axles I designed to get 3d printed then polished would cost about $115 so if I can make these work it would save myself and everyone else that gets one about $95. So I put a hold on ordering my kit until I get the axles in the mail, take some measurements and see if they're anything I can use, worst case I just bite the bullet for the 3D printed CVD front shafts I already have designed. Enjoy some of these pics of the design process let me know what you guys think! |
Re: FIRST EVER IFS SCX24 crawler kit Super rad. What is limiting the front travel right now? I've played around with IFS (and IRS in this case) in CADland too. This is a 1:1 mini buggy that I've yet to build in real life, haha. https://scontent-ort2-2.xx.fbcdn.net...43&oe=5FACCA2F |
Re: FIRST EVER IFS SCX24 crawler kit This is awesome, super keen to see how it turns out. I plan on trying to whip up something along these lines, using micro sct front suspension, tweaked to get more travel along with longer shocks, along with an ecx barrage rear diff as they're a traditional crown and pinion so it'll handle a little more rpm. |
Re: FIRST EVER IFS SCX24 crawler kit thats awesome! cant wait to see how it performs |
Re: FIRST EVER IFS SCX24 crawler kit Wow, making that happen in 1/24 scale is impressive! |
Re: FIRST EVER IFS SCX24 crawler kit It’s a fascinating project, to be sure. I really like the design of your articulating arms and your plan to leave room for quality electronics. Any plans yet for the shocks? Seems like the mini world needs some help in that department |
Re: FIRST EVER IFS SCX24 crawler kit Quote:
Re: FIRST EVER IFS SCX24 crawler kit Haven't posted many updates here as I mainly just put them up on the Facebook groups but finally able to say this project is finished, tested, and totally rad! Been a lot of changes since the OG if you look closely some are pretty clear and some are minor from the beginning stages to the final product. LOTS of bumps along the road and learned a lot during the project and its a blast to drive. Here's some pictures of the process that I put together along the way. |
Re: FIRST EVER IFS SCX24 crawler kit 15 Attachment(s) Tried to put these in order |
Re: FIRST EVER IFS SCX24 crawler kit awesome. great CAD work. get a video of that beast."thumbsup" |
Re: FIRST EVER IFS SCX24 crawler kit Impressive work all around. It sounds like you sent these out to be printed somewhere, do you know what material they used? Was it ABS? |
When can I put my order in? Sent from my iPhone using Tapatalk |
Re: FIRST EVER IFS SCX24 crawler kit I am interested in a kit for sure! That’s amazing cad work!!! |
Re: FIRST EVER IFS SCX24 crawler kit Put me down for a kit as well. Very well done. |
Re: FIRST EVER IFS SCX24 crawler kit This is supercool, but wont the worm burn up with a fast motor youd probably want on this setup? |
Thanks for the heads up! Now Im motivated to go faster. Thank you! "thumbsup" |
