10-30-2020, 05:38 AM | #1 |
Quarry Creeper Join Date: Sep 2008 Location: South Glens Falls
| 1/20 Toyota Body
This seems to fit perfectly! Got to make some new cross members on ends of frame. Got some cool plans for this rig. Sent from my SM-G930VL using Tapatalk |
10-30-2020, 05:40 AM | #2 |
| Re: 1/20 Toyota Body
I do have to lower body a bit. This is the Lindberg model. Sent from my SM-G930VL using Tapatalk |
11-04-2020, 04:39 AM | #3 |
Rock Stacker Join Date: Nov 2020 Location: US
I'm interested in seeing how low you can get this body to sit. Do you think it's possible to get the bottom of the body even with the frame rail in the center? Sent from my Pixel 3 XL using Tapatalk |
11-04-2020, 12:03 PM | #4 |
Newbie Join Date: Sep 2020 Location: ABQ
Wheel base looks really good, hope you can get it down a bit.
11-04-2020, 12:24 PM | #5 |
It is a great fit for the SCX24 I ended up with this, I didnt want to adjust the wheelbase or use tiny tires I have a build thread on this (page 3 is where I start on the Yota body) Whittling on a SCX24 The skid/belly is still 10-15mm below the bottom of the body and thats as low as I could go without major tire rub from the MT-R's. I also had to push the body back a bit to get the front axle forward so the tires clear while steering and cycling the suspension |
11-04-2020, 12:30 PM | #6 | |
| Re: 1/20 Toyota Body Quote:
Sent from my Pixel 3 XL using Tapatalk | |
11-04-2020, 01:32 PM | #7 | |
Yeah i dont think the battery will fit in the stock location. I have a front battery mount linked somewhere in that thread if you have a 3D printer. So the battery is now up front and the ESC/receiver box sits between the frame rails. | |
11-04-2020, 01:39 PM | #8 | |
11-06-2020, 08:53 PM | #9 |
Pebble Pounder Join Date: Dec 2006 Location: Irvine, CA
| Re: 1/20 Toyota Body Here’s mine the rears sits on the frames with magnets Sent from my iPhone using Tapatalk |
11-06-2020, 09:08 PM | #10 |
| Re: 1/20 Toyota Body |
11-07-2020, 01:53 AM | #11 | |
Thanks man. They are RGT wheels and tires I believe. They’re cheap and smaller than rc4wd. It does run slightly. I shaved as much as I could from the fenders to keep the shape. Sent from my iPhone using Tapatalk | |
11-07-2020, 04:48 AM | #12 | |
11-23-2020, 11:12 PM | #13 |
Newbie Join Date: Nov 2020 Location: PNW
