11-27-2020, 03:34 PM | #1 |
Newbie Join Date: Nov 2020 Location: Italy
| Brand new scx24 c10 problem
Hi all, newb here. I treated myself to a scx24 and out of the box it has a steering problem. if I turn right something binds and the truck twists left. Looking at the truck belly up I noticed that the driveshaft stops rotating at low throttle when slightly turning right, it starts again with more right steering, or with more throttle(although you can hear it straining). No problem with no steering or left steering inputs. Tried removing the wheels, it helps, but occasionally it binds anyway, I tried swapping them, same problem. I then tried looking at the axle shafts, following some suggestions in some other thread, I couldn’t see anything wrong, swapped the left with the right one just to be sure and nothing changed. This is my first rc car and I’m way out of my depth here. Any suggestions? Keep in mind I’m not too familiar with the jargon, I’m just getting into surface rc, and as for real size cars, other then drive them, I can barely tell a wheel for a door handle Thanks in advance for any help! |
11-27-2020, 04:28 PM | #2 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
| Re: Brand new scx24 c10 problem
Sounds to me like you need to try and exchange it where you bought it or contact Horizon Hobby for warranty exchange.
11-27-2020, 08:46 PM | #3 |
Newbie Join Date: Jun 2020 Location: Uvalde
Double check the pins at the dogbone. I believe one or two members here have had the pins slip out a bit and bind inside the c-hub.
11-28-2020, 02:34 AM | #4 |
| Re: Brand new scx24 c10 problem Thanks for the suggestion! I read that thread and I did in fact check. They don’t move and they don’t seem tu rub on the cup. I even swapped them to see if the problem would change side, but now that I think about it if something binds somewhere around the front the axle would still spin in the same direction, I imagine is the direction the front driveshaft turns. I’ll try removing the axles and spinning and the transmission to see if I can isolate the problem to a major area.
11-28-2020, 02:35 AM | #5 |
| Re: Brand new scx24 c10 problem Yeah, I’m waiting for their response, I just thought I would mess around a bit and learn something in the process, seems like half the fun is messing with these things anyway! |
11-28-2020, 09:39 AM | #6 | |
| Re: Brand new scx24 c10 problem Quote:
Nothing wrong with trying to figure it out. Makes a good learning experience. Just had a thought, is the front driveshaft out of phase? | |
11-28-2020, 01:33 PM | #7 | |
Edit: from the link seems like they would be aligned. I’ll try that. Is it the same for the rear driveshaft too? Last edited by MizuNoLorien; 11-28-2020 at 01:46 PM. | |
11-28-2020, 03:39 PM | #8 | |
The picture in the link is actually an axle shaft but it the same for driveshafts. All driveshafts should be in phase. This might make it clearer | |
11-29-2020, 09:21 AM | #9 | |
Anyway while I was happily noticing that the problem was gone, the stock servo decided to die. I guess I stripped the gears while tightening the servo horn. Emax servo coming in the next few days. | |
11-29-2020, 03:44 PM | #10 |
First off happy to hear that you got your problem solved. Don't know why but you can't tighten the wheel nuts down tight like on a 1/10 scale. I tighten mine till the nut bottoms and then quit. Haven't lost a wheel yet. On my Jeep the servo crapped out the 2nd time I ran it. Horizon sent me a new one and I put a Emax in instead. FYI I and others have had the Emax make a hard right or left turn and stop and not return. Power off the truck & transmitter. Turn both back on wheels will center and you can continue. Think it has happened only 3 times for me on 2 vehicles. I bought mine in a 4 pack so it's possible they are knockoffs. |
11-29-2020, 04:26 PM | #11 | |
Thanks for the support! | |
11-30-2020, 02:41 PM | #12 |
| Re: Brand new scx24 c10 problem Mine came today and it’s definitely a knock off, came in a plastic bag with no packaging. I guess it’ll have to do for now, gotta stop using Amazon for this stuff. I also bought a servo extender and moved the leds to the headlights from the bumper. Looks cool. |
11-30-2020, 04:02 PM | #13 | |
That's where I got my 4 pack too. I opened mine up and shortened the leads. Pretty easy with a small tip iron. Even if it's a knockoff still better than the stock servo which is junk. | |
Brand new scx24 c10 problem - Similar Threads | ||||
C10 SCX24 in the woods | waqr | Videos! | 0 | 05-23-2020 11:40 PM |
SCX24 C10 Body | DJJorel | Micro Scale Rigs | 3 | 05-20-2020 05:49 PM |
Axial SCX24 C10 on the rocks | waqr | Videos! | 0 | 05-11-2020 11:38 PM |
Scx24 C10 First run | Unclelee | Micro Scale Rigs | 6 | 05-02-2020 12:36 AM |
Scx24 c10 | JMHZ2401 | Micro Scale Rigs | 0 | 04-03-2020 08:04 PM |
