Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: My Scx24 Yota
Old 04-11-2021, 05:16 PM   #1
Default My Scx24 Yota
I Guys,
New project .. Scx24 plus Hilux 1:20 body from AMT
I moved the 'attacks of the front shock using a bracket of a servo fixed in 2 points
I have relocated the rear shock absorbers, now they work much better .. I used 2 mm forex that gives support to the frame.
I left the original springs adding some springs, cut very short, harder .. we will see with the weight of the bodywork how they behave ..
I have added brass spacers
Tire change .. I have inside some nice Super Swamper TSL Bogger mounted on Micro Losi plastic beadlock rim painted .. They are at 20gr full wheel against 10gr of the stock ones.
I placed the battery in the center
To lock the body, I added Velcro to the rear and magnets to the front hidden in the engine compartment that grip directly on the iron of the frame.
I changed the bumper .. Now ARB style.
After removing some material, the bodywork now sits as low as possible and rests on the chassis, both front and rear.
Color .. I chose a Tamiya Mica Red, I wanted something metallic ..
I replaced the servo with an Emax ES08MD
I finished the bumper, painted semi gloss black, added spotlights
That's all for now..
Peppe_rock is offline   Reply With Quote
Old 04-11-2021, 07:35 PM   #2
Default Re: My Scx24 Yota
Very nice build.
Sent from my SM-N970U using Tapatalk
06ToasterBox is offline   Reply With Quote
Old 04-16-2021, 01:36 AM   #3
More details..
I found the space for the LED cables, now I have the lights
I added some shackles to the bumper
Old 04-17-2021, 08:28 PM   #4
Looks great!
GChambers is offline   Reply With Quote
Old 04-22-2021, 09:33 AM   #5
GChambers
Looks great!
Thanks a lot!
New rims ..
I put the Super Swampers, they are narrower and a couple of mm smaller than the Mickey Thompsons ..
A few more details ..
I created the lightest possible interior, used 2mm forex, 0.5mm styrene, static kit pieces, the body and arms from a Fujimi kit and the helmet from the Deadbolt. Still to be painted and defined ..
Defined the roll-bar with lights and aluminum clamps for both the lights and the fire extinguisher ..
Added some stickers ..
That's all for now ..
Old 04-22-2021, 05:25 PM   #6
Looking really good! I really love that Toyota kit. My first real build was a Toyota like that, but on a Losi trail trekker platform. Nice job!
R.Billy Rob is offline   Reply With Quote
Old 04-23-2021, 03:37 AM   #7
Looks pretty great man, good job.
SurlyBurly is offline   Reply With Quote
Old 04-26-2021, 07:18 AM   #8
I painted the interior, added the windshield and wipers .. I would say the project is over ..
upload images to web
Outdoor test. Very satisfied, it moves well and the shocks have a very realistic movement thanks to the weight.
Old 04-26-2021, 02:31 PM   #9
Like
Shape_Shifter is offline   Reply With Quote
Old 04-26-2021, 03:51 PM   #10
Originally Posted by Shape_Shifter
Like
Thanks A lot!!
Old 05-01-2021, 10:03 AM   #11
Fantastic build. Makes me want to do one.
