07-11-2021, 03:04 PM | #1 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
| A "Comp-ish" SCX24
I already have one super scale micro truck, this is its very performance oriented counterpart. Chassis: Team Garage Hack TGH-24X rails, cross members are a mix of stock and sleeved M2 threaded rod. 3D printed high clearance links, laid down stock shocks with no springs. 1oz of lead on top of the servo for some forward weight bias. Sliders/electronics trays are .060" aluminum. Hot racing steering links. Drivetrain: Furitek 1400kV with their motor plate and pinion/spur and Treal overdrives, otherwise it's stock down to the driveshafts. Tires/Wheels/Body: RC4WD MT/Rs on SSD Beadlocks, Crawler Innovations medium foams up front, soft in the rear. The body is a Carisma F150 meant for their 1/24 scale truck, little shorter and a lot narrower than the original C10 body. Stock body posts up front, magnet mounted in the rear. Electronics: Furitek Lizard, FlySky 3 channel, EMax ES08MA. I run these small "Pulse" brand 2S lipos mostly 'cause they were on sale for next to nothing but they do fit well. |
07-17-2021, 11:31 PM | #2 |
Newbie Join Date: May 2021 Location: Sacramento
| Re: A "Comp-ish" SCX24
looking real good! I like the little slider/trays. Simple, but effective.
07-18-2021, 04:14 PM | #3 |
| Re: A "Comp-ish" SCX24 I originally set out to make sliders that would come out and stick up the sides of the rockers on the body but despite several cardboard models I had a hell of a time trying to get the bends in the right place to tuck them in nicely and have them be flat with the body while lining up with the angled skid plate on the TGH chassis. I decided on what I've got now out of frustration but they do work well and they don't disrupt the looks of the truck. I've got a couple more of these bodies on the slow boat from HK, once they're here I may try mounting to the sliders instead of the body posts since I've cut so much out of the stock mount, it's a little floppy.
07-22-2021, 11:29 PM | #4 |
4 linked the front to get rid of the Y-link. This thing had several issues with binding in the front due to both my setup and the nature of the y-link design. Front drive shaft was rubbing at the diff end, upper and lower links were hitting each other etc... I cut the ends off some stock lower links and drilled them for M2 threaded rod. Used the metal ball studs out of the stock steering linkage at the diff end and standard stuff at the chassis. No more clearance issues and the bind is minimal now. I did roll a little more caster in than stock too to try and help tighten up the turning radius, added bonus of a teeny bit more steering link ground clearance. Last edited by Trike Kid; 07-22-2021 at 11:31 PM. |
07-25-2021, 05:13 AM | #5 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
Very nice! Lou |
09-25-2021, 07:36 PM | #6 |
Making some changes. Added Hot Racing emulsion shocks, still full droop up front, just a tiny bit of up travel in the rear for a little more clearance and to take the bounce out when bumping the rear axle up ledges. I picked up some spares of the Ford body a while back and cut the hell out of this one then abandoned it because I couldn't come up with a way to close the back of the cab in nicely. Then I came across the bed from the 1/24 ECX Barrage. Still needed some trimming but this is where I'm at so far. Trimmed the big awkward spare tire location off the bed and the faux shock towers to clean it up a bit. Waiting on paint and some final fit/finish work. |
09-25-2021, 08:37 PM | #7 |
Newbie Join Date: Aug 2009 Location: san jose
Like the build . Could you post a link to somewhere to get that body?
09-26-2021, 12:35 AM | #8 |
I buy the bodies direct from Carisma, doesn't seem like they've got much of a dealer network in the US. Shipping direct from Hong Kong takes a while. Here's their spares page https://carisma-shop.com/collections/msa-1e-spares |
09-27-2021, 08:31 PM | #9 |
Got my Little Guy Racing Parts tires today, holy clown shoes! Stuffed those with some medium Crawler Innovations foams front and rear. Made a little headache rack filler for the front of the bed cage that serves both to cover the less than ideal back of the cab and as a point to screw the cab and bed together. Last edited by Trike Kid; 09-27-2021 at 08:49 PM. |
09-28-2021, 12:33 PM | #10 |
Rock Stacker Join Date: Apr 2021 Location: Fresno
Looks like a beast!
10-04-2021, 08:37 PM | #11 |
USPS finally got around to delivering my paint. Last time I painted a lexan body it was for an original SCX10 so I'm a little rusty and it ain't perfect but it's good enough to beat on rocks. Need to figure out some kind of front bumper without giving up all the approach angle. |
02-03-2022, 09:11 PM | #12 |
Got a 3d printer so I fired off a little fuel cell to fill some of the open bed space and a front bumper. Also added deadbolt rear links to get the wheelbase out and +4mm axles to get the tires away from the shocks. Last edited by Trike Kid; 02-03-2022 at 09:14 PM. |
02-03-2022, 09:51 PM | #13 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
Looks awesome man, what a bruiser!!! I have this same body and plan to put it on my SCX24. I was considering putting some smaller tires on it and shortening the wheelbase to fit the body, but you might have changed my mind a little. Still unsure of what I want to do with it yet… Oh, my front driveshaft is binding against the y-link as well. The start to my “little one” Last edited by AK KRAWLER; 02-03-2022 at 09:54 PM. |
A "Comp-ish" SCX24 - Similar Threads | ||||
"The Kraken" build-ish thread | AkronAxial | 1.9 Scale Rigs | 0 | 03-13-2014 08:47 PM |
Campbell "ish" style w/ swaybar | gadge | 2.2 Scale Rigs | 1 | 06-06-2013 12:25 PM |
Another "Scale-ish" Makeover For My 2.2 Clod... | RANOVRU | Tamiya Clod Buster | 6 | 05-16-2006 12:51 PM |
