07-20-2021, 11:35 AM | #1 |
Newbie Join Date: May 2021 Location: Sacramento
| Trimming 1.0 tire foams
Just a curiosity: do y’all trim your foams in the 1.0” tires? Seems like most people are running RC4WD tires, do you find the foams to be adequate as is? I have a few sets of tires, and I feel like they all need something different. Bfg KM3 are un-trimmed, on a nearly stock truck. The tires hook up, but they feel bouncy and “over inflated”. Falken Wildpeaks were star trimmed, but still felt like the deep lugs didn’t allow them to flex much, even on a heavier(brass’d) truck, plus they packed up with sand real bad. Now running the Milestar Patagonia tires, I star trimmed one pair, and immediately decided they’re too soft. This tire has much thinner/softer case than the others I’ve used so far. So now I’m running the un-trimmed Patagonia’s on the front, and the trimmed ones on the back where it’s lighter, and actually pretty satisfied so far. |
07-20-2021, 12:22 PM | #2 |
Rock Crawler Join Date: Dec 2013 Location: Nevada City
| Re: Trimming 1.0 tire foams
I personally don’t run foams in my tires. They are just too stiff and don’t hook up as well with foams. With the small size of the micros there really isn’t much need for foams, unless you’re running one of the larger diameter tires like scramblers or the old school Miclaws.
07-20-2021, 02:52 PM | #3 | |
Quarry Creeper Join Date: Jul 2020 Location: US
| Re: Trimming 1.0 tire foams Quote:
Other wise, what ^^^he^^^ said, i find this rings true for my scx24 betty, even WITH minor weight added (recently converted to 4-wheel-steer, and dont know the numbers, but I'm confident when you put a front axle under the rear of this vehicle, it basically now with servo weighs the equivalent I've rather a factory plastic with brass cover and brass hexes etc, or even an aluminum rear with all brass additions. Also, the final drive changes a bit as you now have "higher" (front axle) gearing out-back...and i personally have o.d. up front. I digress. I have a servo on axle front and rear, 1/4oz wheel weights on top each servo (furitek tegu, surpass outrunner, gamyrc mount, etc), brass front diff cover, HR extended stub axles-front, and stock width (front) with extended brass hexes on the rear. Alu. Steering links, oh yeah, aluminum front axle housing (i feel like its lighter than stock housing), anyways....not a WHOLE lotta weight, so i prefer no foams, try for yourself with some amazon beadlocks if necessary, see if you get the traction you need? Read-Up! Mod-On! Crawl EXCESSIVELY! Last edited by 23drumerboy; 07-20-2021 at 03:01 PM. | |
07-20-2021, 03:22 PM | #4 | |
Rock Crawler Join Date: Apr 2012 Location: NewHampshire
Wtf does any of this mean? Sent from my iPhone using Tapatalk | |
07-20-2021, 04:58 PM | #5 |
| Re: Trimming 1.0 tire foams I. Have. A. Slightly-weighted.... Scx24Betty... I prefer NO foams. My truck is now 4wheel steering....it has overdrive on front axle, and a stock front axle in place of the rear axle (only stated this for sake of comparing the NEW rear axle weight, versus a stock rear axle with aluminum link mount and brass cover. Maybe i was using speak-2-text and the translation was rough?? Anyone else have trouble understanding my post?? * Read-Up! Mod-On! Crawl EXCESSIVELY! |
07-20-2021, 08:52 PM | #6 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
I run Crawler Innovations foams in both my minis with the tires properly vented. Usually soft front and rear though the RC4WD MT/R needed mediums in the front for sidewall support. The foams that come with RC4WD tires are really stiff, the ones that came with the Injora 1.0 tires I bought recently are as stiff or worse. IMO if you're not going to vent your tires the foam you put in them isn't going to make enough difference to worry about it, they're always going to be too stiff. For less than 4 bucks a set the CI foams are a no brainer if you're the least bit interested in tuning your tires. |
07-21-2021, 03:18 PM | #7 | |
08-24-2021, 02:40 PM | #8 |
Newbie Join Date: Sep 2013 Location: RI
I didn't realize the level of tuning with these little trucks even down to the foams. I might have to experiment a bit to see which I prefer. Would type of tire matter with running foams or not? I am currently running rc4wd mudslingers with foams.
08-25-2021, 02:28 AM | #9 |
Yes, I think tire selection influences foams, just like bigger trucks. I notice a difference in stiffness and sidewall support between the RC4WD 1.0" tires that I have. Since this thread, I've vented my Milestar Patagonia tires with a hot wire, but still the stock foams. I notice the foams have started to break down from water saturation, especially the cut rears. The tires almost seem flat, and sometimes the tire wads up in a pinchy situation. Still need to try some Crawler Innovations... |
09-25-2021, 10:26 PM | #10 |
Newbie Join Date: Sep 2021 Location: US
I'm running RC4WD Goodyear Wrangler M/TR on their Stamped Steel wheels. Currently no foam and vented front, foam no-vent rear. I think i will vent the rear soon but happy with it overall. Sent from my SM-G973U1 using Tapatalk |
Trimming 1.0 tire foams - Similar Threads | ||||
Pro-line swampers xl 2.2s...trimming these gigantic foams | mwe-maxxowner | Tires and Wheels | 11 | 06-07-2015 09:20 PM |
trimming deuces wild foams for weights | atf300 | Tires and Wheels | 3 | 03-08-2015 08:58 AM |
Tire trimming - Pullers | TwistedXT | Tires and Wheels | 8 | 05-20-2013 10:39 PM |
trimming memory foams??? | newbcrwlr76 | Newbie General | 6 | 02-01-2009 07:14 PM |
