11-10-2021, 05:52 PM | #1 |
Pebble Pounder Join Date: Mar 2013 Location: HOOPER
| Belly Dragger
SCX24 Belly Dragger Sent from my SM-G781V using Tapatalk |
11-10-2021, 06:16 PM | #2 |
| Re: Belly Dragger
The usual build. Emax servo, brass knuckles, diff covers, 7mm hub extensions, China beadlocks, Mudslingers with no foams, Bowhouse RC low cg battery and esc tray, Atlas body. I moved the battery forward to the esc tray and mounted the esc to the batt. tray. Driving it on my foam RC course.
11-10-2021, 06:45 PM | #3 |
| Re: Belly Dragger
Also moved the front bumper to the rear
11-10-2021, 07:47 PM | #4 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Re: Belly Dragger
Looks great man! I hope to give my SCX24 a little love in the next few months.
11-11-2021, 03:53 PM | #5 |
| Re: Belly Dragger
This is my Mini Moab for the cold winter. Mater for scale. My daughter and I made gates out of flag toothpicks. Sent from my SM-G781V using Tapatalk |
11-11-2021, 11:11 PM | #6 |
Rock Stacker Join Date: Nov 2005 Location: Orange County
| Re: Belly Dragger
Very cool!
11-12-2021, 01:06 AM | #7 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
| Re: Belly Dragger
What type of paint did you use over the foam? How is everything holding up? Would you make any changes next time?
11-12-2021, 07:02 AM | #8 |
| Re: Belly Dragger
I used the textured Rustoleum. It is actually holding up really well. As of right now I wouldn't change anything. I didn't want to make it to terribly big so it was a pain to move. It doesn't weigh much at all. Sent from my SM-G781V using Tapatalk |
12-30-2021, 08:15 PM | #9 |
| Re: Belly Dragger
I've done some more mods to Mater lately. Stretched Mater quit a bit. Deadbolt rear links and Driveline. Moved the rear links of the JLU to the front as well as the female side of the driveline. I had to trim it about a 1/4 " so it wasn't bottomed out. Had to trim the body in the grill to clear the servo/horn. Also did the Injora 050 motor swap. Sent from my SM-G781V using Tapatalk |
01-01-2022, 08:14 AM | #10 |
Rock Stacker Join Date: Dec 2021 Location: Netherlands
| Re: Belly Dragger
Looking sweet. I also like how volcanic your crawler course looks |
03-23-2022, 05:44 PM | #11 |
| Re: Belly Dragger
Made some more changes to Mater. G Speed LCG carbon fiber chassis and swapped out Mud Slingers for some LGRP Trail kings. The upgrades were well worth it. Driving on my big rocks for my 1/10 trucks. Sent from my SM-G781V using Tapatalk |
03-23-2022, 06:25 PM | #12 |
Newbie Join Date: Nov 2015 Location: Raleigh
| Re: Belly Dragger
This is awesome, loving the homemade crawling course with the toothpick flags!
03-23-2022, 08:28 PM | #13 |
Quarry Creeper Join Date: Mar 2019 Location: Low CG
| Re: Belly Dragger
Nice! Let's see under the hood.
03-24-2022, 11:45 AM | #14 |
Newbie Join Date: Mar 2022 Location: Scottsdale
| Re: Belly Dragger
very nice build, got a gspeed chassis laying around waiting to be revived |
03-24-2022, 07:10 PM | #15 |
| Re: Belly Dragger
Bowhouse Rc LCG battery and servo tray Sent from my SM-G781V using Tapatalk |
03-24-2022, 07:19 PM | #16 |
| Re: Belly Dragger
Any suggestions for sliders? I bought some 3d printed ones for a Atlas however they're not going . to work Sent from my SM-G781V using Tapatalk |
04-01-2022, 03:44 PM | #17 |
| Re: Belly Dragger
New wheels for Mater Sent from my SM-G781V using Tapatalk |
04-03-2022, 05:05 AM | #18 |
Pebble Pounder Join Date: Aug 2020 Location: Ohio
| Re: Belly Dragger
How did you mount the cab? Is id just the rear magnet or do you have more holding it on? |
04-03-2022, 08:47 AM | #19 |
| Re: Belly Dragger
I used some double sided tape to mount a thin piece of sheet metal to the battery mount tray. Using the magnet on the atlas body. Then I just drilled a hole in the body and used the stock jeep body post. Sent from my SM-G781V using Tapatalk |
04-03-2022, 09:38 AM | #20 |
| Re: Belly Dragger |
Belly Dragger - Similar Threads | ||||
What goes into building a belly dragger? | Dangerfirst | General Crawlers | 10 | 04-22-2020 11:09 AM |
Belly Dragger Sawback | OSRC | G-Made Sawback | 42 | 09-09-2018 11:33 AM |
The Belly Dragger | cornsnake | Videos! | 3 | 10-02-2009 09:45 PM |
belly dragger | kurt | Axial AX-10 Scorpion | 42 | 03-25-2008 05:10 PM |
Belly Dragger Getting Closer!!!! | DirkDigler | General Crawlers | 26 | 07-29-2004 07:42 PM |
