Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: How heavy is to heavy ?
Old 03-01-2022, 01:01 PM   #1
Default How heavy is to heavy ?
With all the upgrades available for a SCX24 in plastic, aluminum and brass, is there a point where to much brass is to heavy. You certainly want as much weight down low as you can, MOFORC even has full brass diffs. At what point is it just overkill and starts to become counter productive. A lot of weight down low does help to offset all of those scale add ons up top.
72blazerdude is offline   Reply With Quote
Old 03-01-2022, 03:33 PM   #2
JC3
Default Re: How heavy is to heavy ?
It's "overkill" when it isn't necessary. Been there done that. The objective shouldn't be to just add weight because you can. Rather, it should be to obtain the best weight bias. Generally 60/40 but that differs by preference I'd say. Additionally, once you reach that preferred bias, you can tune your tires/foams to work best with the weight added. Low cg trumps almost everything else in the broad sense. If you're just adding weight down low to keep your top heavy rig from rolling over then I'd say that's a bad idea. In my opinion, you either have performance or scale realism. If you want both then something has to give. When you raise the cg, performance suffers. Track width can also help, but again, it comes with it's own compromises.
JC3 is offline   Reply With Quote
Old 03-01-2022, 03:35 PM   #3
I think that with the scx24 you can get too heavy pretty quick... mainly due to the size/ power of the motor. I would only upgrade parts down low with this rig as well since it gets a little tippy pretty easily when putting weight up top. In terms of actual #s I dunno in oz. what would be considered too much but I'd only add weight around the wheels/ axle area and I wouldn't throw a lot of weight at this rig all at once. Upgrade to brass/ steel parts sparingly and then drive to evaluate performance gains.
high plains drifter is offline   Reply With Quote
Old 03-01-2022, 07:21 PM   #4
Tiny Truck Hoarder
HumboldtEF's Avatar
Typically all any rig needs is weighted knuckles. I add weight to get to the F/R weight bias to where I want it and no more.
HumboldtEF is offline   Reply With Quote
How heavy is to heavy ? - Similar Threads
Heavy or not? Banjoblue Axial Wraith 8 07-14-2016 05:02 PM
How heavy is heavy?? JonehRC Newbie General 20 05-02-2010 12:27 PM
Can you say heavy! FrankyRizzo Chit Chat 10 08-17-2006 09:45 PM
