09-13-2022, 06:11 AM | #1 |
Newbie Join Date: Jun 2020 Location: Wisconsin
| Traxxas TRX4M 1/18 Scale Crawler Just Announced! |
09-13-2022, 06:13 AM | #2 |
| Re: Traxxas TRX4M 1/18 Scale Crawler Just Announced!
Seems like a reasonable price. If it is true 1/18th scale then it should only be a little larger than an SCX24, as the SCX is larger than true 1/24th scale.
09-13-2022, 12:03 PM | #3 |
Landing Page: https://traxxas.com/products/landing/trx-4m/ Accessory Page: https://traxxas.com/landingpages/trx4m-accessories |
09-13-2022, 12:27 PM | #4 |
Size is just slightly bigger than SCX24. Wheelbase: 6.1" / 155mm (SCX24 is 5.2" / 132mm, and 6.1 / 155mm for the gladiator) Track width: 4.9" / 124mm (SCX24 is 3.9" / 99mm) Height: Bronco 4.6" / 117mm and Defender 5.3" / 135mm (SCX24 is from 3.6" / 91mm to 4.4" / 112mm) 4 link front and rear (betting it s an axle mounted servo then) The amount of accessories looks pretty decent right off the bat. 4 different springs available and spring preload spacers available for tuning. Low range and "speed" transmission options (Stock transmission will be between the speed and low range options, so 3 transmission options total!) From the pictures it looks like the stock transmission and axles have bushings instead of bearings. But of course they sell a $40 bearing set, shocker... Ring and pinion axles (2:1 ratio) Edit: updated/corrected transmission options Last edited by TheseusOfTroezen; 09-15-2022 at 09:29 AM. |
09-13-2022, 12:52 PM | #5 |
Quarry Creeper Join Date: Feb 2020 Location: Bakersfield
I really didn’t want to spend anymore $$$ on new vehicles but…
09-13-2022, 02:26 PM | #6 | |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
| Re: Traxxas TRX4M 1/18 Scale Crawler Just Announced! Quote:
Still, though....pretty cool little truck and finally a small scale from Traxxas. Better late than never I suppose. | |
09-13-2022, 02:43 PM | #7 |
Newbie Join Date: Jun 2020 Location: Uvalde
With a 155mm wheelbase, that puts it in the same range as the FMS/Eazy RC and Hobby Plus 1:18 scale trucks.
09-13-2022, 03:45 PM | #8 | |
Rock Crawler Join Date: Jan 2022 Location: st louis
Main stream rc companies have a really hard time with scale for some dumb reason. Really not hard to figure out, 1:1 vehicle dimensions divided by the scale, so 10, 18, 24. I have true to scale printed 1/10 and 1/24 bodies. They are substantially smaller than rc 1/10 and 1/24 bodies. Sent from my SM-S906U using Tapatalk | |
09-13-2022, 04:06 PM | #9 |
Rock Stacker Join Date: Aug 2020 Location: US
That looks really nice. I like the price point too
09-13-2022, 04:40 PM | #10 | |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
RC companies need to sell product and make money. To sell product they have to appeal to the most amount of customers possible. A true scale 1/10 version of most modern trucks/SUV’s would come with 3.1”-3.3” tires, which is not an accepted standard 1/10 crawler tire size. I’ve also seen losi comment on the hammer rey that 1/10 is more of an electronics classification, which makes sense to me. FWIW In this case a 1:1 bronco has a 116” wb, and the trx4m ends up being close to 1/19 at 6.1”. At the same time, the 2.2” tires scale out to a 41.8” at 1/19 or 39” at 1/18. The scx24 bronco ends up closer to 1/22 at 5.2” wb. I certainly wouldn’t want to see this on a true to scale 1.8” tire… and that’s assuming you’re basing it off a 1:1 trim level with 35’s stock. Short story long, scale is tricky to make things look good while still appealing to the masses, and not having to make an entirely new chassis, axle width, and tire size for every body change. | |
09-13-2022, 05:39 PM | #11 | |
A 1.9 wheel is a 19" wheel in 1:1 on 1/10 scale. 1/10 scale numbers are easy to figure out, move the decimal 1 point to the left. 2.2 is 22 and so on. Offroad in 1/10 to be appealing? Element hit that nail almost dead center on the head with the Knightrunner. Wheelbase is exactly 1/10 of a 1:1 Tacoma (I have a 1:1 and a knightrunner). Proportions from there are a bit off, mainly width. Width goes almost 1/8 scale. The stock tires are 3.85 which means 38.5 in 1:1, very realistic numbers for a heavily modified offroad tacoma. Straight axle swapped and 4 link guys have done are on 40s, so a 4" tire in 1/10. Class 1 tires fall in pretty close and not an unrealistic mod for 1:1 to have 42" tires (class 1 4.19" tire) Rc has never had it right but people couldn't handle the switch to be accurately scale labeled, get too confusing. Sent from my SM-S906U using Tapatalk | |
09-13-2022, 06:27 PM | #12 | |
I don’t claim to be good at math, but if you multiply 5.2 by 22.327 to be exact, you get 116.1”… which is the 1:1 bronco 4 door wb. Would that not be 1/22:1? Either way, my only point was manufacturers typically have logical reasons to not make things exact 1/10 scale replicas. And to not derail this thread too much, I’m pretty excited about this release and most likely will pick one up… in November Sent from my iPhone using Tapatalk | |
09-13-2022, 07:47 PM | #13 | |
09-13-2022, 07:50 PM | #14 |
Rock Crawler Join Date: Apr 2020 Location: Drums
Out of the box with oil filled shocks. Game changer right there. |
09-14-2022, 06:52 AM | #15 |
After watching the Traxxas videos of this new release and seeing all of the optional parts and accessories that will be available, I'm excited now to pick up one of these when there become available in November. Looks like Traxxas did their homework and is offering a well thought out mini rig! |
09-14-2022, 07:24 AM | #16 |
If this is anything at all like the TRX4 I just bought I'm excited to see how this little truck performs. May have to pick one up for my daughter because she's been wanting to drive my son's TRX4 '21 Bronco and he's not comfortable with that. Guess for now I'll give her my lightly modded SCX24 Deadbolt. But definitely interested in this truck!
09-14-2022, 09:20 AM | #17 |
Quarry Creeper Join Date: Mar 2021 Location: SOCAL
these look great and very scale like... love the fact that they sit on straight axles ... i love my trx4 as it was what brought me to crawling so this little guy (defender) will likely make it home on the release date.
09-14-2022, 10:40 AM | #18 |
Rock Crawler Join Date: Nov 2008 Location: CO
Well great, I was about to pull the trigger on a SCX24 Bronco to get back into this hobby and now I don't know. Do I wait 2 months for this or just go with the SCX? Hmm, decisions...
09-14-2022, 12:29 PM | #19 | |
09-14-2022, 03:20 PM | #20 |
Quarry Creeper Join Date: Jan 2009 Location: WA state
| Re: Traxxas TRX4M 1/18 Scale Crawler Just Announced! Do you get everything in the first delivery package for preordering? or do you have to pay extra? I was also thinking about preordering a blue Defender.
Traxxas TRX4M 1/18 Scale Crawler Just Announced! - Similar Threads | ||||
Traxxas TRX-4 Scale & Trail Crawler - Restocked! | RPP Hobby | RPP Hobby | 0 | 08-09-2017 01:08 PM |
Traxxas TRX-4 Scale and Trail Crawler - Now In Stock! | RPP Hobby | RPP Hobby | 0 | 07-10-2017 11:12 AM |
Traxxas TRX-4 Scale Crawler Full Review and Test Drive! | driftomaniacs | Scale Videos! | 1 | 05-23-2017 06:32 PM |
Traxxas TRX-4 Scale and Trail Crawler - Open for Pre-Order! | RPP Hobby | RPP Hobby | 0 | 05-03-2017 10:57 AM |
