12-08-2022, 10:55 AM | #1 |
Quarry Creeper Join Date: Dec 2007 Location: Central Florida
| FMS FCX24 Smasher and Power wagon same drivetrain?
Hi, Anyone know if they have the exact same drivetrain or one have metal gears in some areas vs the other? I was planning on getting the smasher and later on getting the wagon body but it seem they don’t sell the rear cage. Also anyone tried fitting the Axial or Traxxas Bronco body? would they fit? Could someone post photos. Thanks Sent from my iPhone using Tapatalk |
12-08-2022, 12:17 PM | #2 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Re: FMS FCX24 Smasher and Power wagon same drivetrain?
I know the Smasher comes with the metal portal gears, not sure on any of the other questions. They are both fun little rigs!!! Although I do not have them in front of me at the moment. Rear Cage Last edited by AK KRAWLER; 12-08-2022 at 01:00 PM. |
12-08-2022, 01:30 PM | #3 |
Rock Stacker Join Date: Feb 2014 Location: Canada
Kind of hijacking this a bit with a question related to the two models he mentioned. I like the idea of trying to turn the Traxxas into a little 1/18 monster truck, but it seems like the fms smasher comes with so many extras (bearings, portal axles, 2 speed transmission, etc…) is it even worth it to try to convert the Traxxas? I’d probably have to put a decent amount of money into it but I’ve always had good luck with Traxxas, even on weird projects I made. What do you guys think?
12-08-2022, 09:34 PM | #4 |
Pebble Pounder Join Date: Feb 2022 Location: Brooklyn
Fcx24 wheel base is about an inch shorter then the trx4m. With extended links it will fit trx4m body. Sent from my LG-V521 using Tapatalk |
12-09-2022, 04:46 AM | #5 |
Rock Stacker Join Date: Nov 2005 Location: Orange County
Max Smasher has open diffs. FCX24 is locked.
12-09-2022, 09:54 AM | #6 | |
| Re: FMS FCX24 Smasher and Power wagon same drivetrain? Quote:
Was not aware they offer more parts than their official FMS page that were I was looking at. Thanks Sent from my iPhone using Tapatalk | |
12-09-2022, 10:07 AM | #7 | |
| Re: FMS FCX24 Smasher and Power wagon same drivetrain? So besides that they pretty much the same. Is hard to know for sure as they don’t show the portal photo of the wagon being metal like they do in the smasher. Quote:
Hmm that might be more complicated that it seem finding the right linkage and driveshaft. Sent from my iPhone using Tapatalk | |
12-09-2022, 10:27 AM | #8 | ||
Extended trailing arms are available online, as well as it just uses an SCX24 driveshaft. Although I cannot remember which one, but I believe it was that Gladiator. | ||
12-12-2022, 06:38 PM | #9 | |
Quarry Creeper Join Date: Sep 2021 Location: Buffalo
the butcher comes with metal portal gears now, it was only the first so many that didn't, even so fms sent everyone who got plastic portal gears metal ones for free | |
12-25-2022, 09:53 PM | #10 |
Newbie Join Date: Dec 2021 Location: SoCal
Do we know if the fcx24 has metal trans gears or not? Sent from my iPhone using Tapatalk |
12-26-2022, 08:22 PM | #11 |
| Re: FMS FCX24 Smasher and Power wagon same drivetrain? |
01-16-2023, 11:21 AM | #12 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
Anyone 100% confirm if the smasher has metal tranny gears or not? I seem to think a recent review said they did? Trying to find it...
01-18-2023, 11:31 AM | #13 |
Confirmed. The transmission does NOT have metal gears. Be warned. The facory metal gear set included a metal shift fork. All the aftermarket solutions require you to reuse your PLASTIC shift fork. So you want the factory gear set vs aftermaket for now.
05-06-2023, 06:26 PM | #14 |
Quarry Creeper Join Date: Apr 2023 Location: NW Connecticut
I have the factory metal transmission gear set on the way , I have seen a few You Tube videos where there was fitment issues with the gears being to thick . I wrote FMS/FCX/FairRC about this fitment issue to see if it was resolved but they never responded . I have a dremel tool on hand just in case .
05-08-2023, 05:51 AM | #15 |
I received a response from FMS . Greeting from FMS, Yuki is at your sincere service. We are very sorry that due to our recent internal system update, we did not reply you in time. We apologize for the inconvenience caused. You can upgrade your Smasher drive with metal drive gear part C3062. Regarding the problem of gear installation, we have previously reported to the R&D department and it has been resolved. Thank you for your patience and understanding. If you have any questions, please feel free to contact us. We will get back to you as soon as possible. Thanks and best regards, FMS |
05-26-2023, 02:36 PM | #16 |
I installed the metal transmission gears along with the high speed motor , heat sink and battery kit from Fair RC . The trans gears seemed to install with no binding but after a few minutes of run time the power cuts out . The battery that came with the high speed kit is not supposed to do that , the stock battery will . I suspect something isn’t right . I fully charged the new battery before use . This high speed motor is fast , almost too fast .
05-26-2023, 05:45 PM | #17 |
I ordered the Treal set of gears , but a heads up , there may have been some changes in the shift gears . The FairRC clutch dog has 4 points of engagement , the Treal shift gear only has 3 . I’m sure I will be installing a hybrid transmission gear set .
05-27-2023, 07:29 PM | #18 |
I swapped in the Treal spur and drive gears , kept the FairRC shift gears . It runs much quieter, no gap in transmission case and run time went from 7 minutes to 25 . FMS needs to look into their aftermarket fitment . Treal needs to update the shift gears . |
FMS FCX24 Smasher and Power wagon same drivetrain? - Similar Threads | ||||
New FMS 1/24 power wagon | Oscillat0r | Micro Scale Rigs | 63 | 05-06-2023 06:32 PM |
FMS Max Smasher - Bigfoot | AK KRAWLER | Non Crawler RC's | 19 | 05-06-2023 04:09 PM |
Project B.A. Power Wagon (Bad A** Power Wagon) | freetimecrawler | 1.9 Scale Rigs | 1 | 12-30-2018 07:19 AM |
1964 Dodge Power Wagon Town Wagon | bodean | 1.9 Scale Rigs | 32 | 05-29-2015 11:02 AM |
