05-30-2023, 01:56 PM | #1 |
Rock Stacker Join Date: Sep 2011 Location: UK
| Trx4m springs
I want to change the spring on my TRX4M defender and can't work out which ones are the stronger type, can anyone enlighten me please, I want to do this to try and eliminate the torque twist that the truck suffers from, I also fitted the bearing upgrade kit in the axles and when I put the wheels back on I backed out the nut by a 1/4 turn
05-30-2023, 07:30 PM | #2 |
Pebble Pounder Join Date: Apr 2023 Location: NW Connecticut
| Re: Trx4m springs https://www.amainhobbies.com/traxxas...a9758/p1452047 I don’t have a Trx4m but maybe the above link will help , the spring rates are in the description. |
05-31-2023, 12:00 PM | #3 | |
| Re: Trx4m springs Quote:
06-01-2023, 03:33 AM | #4 |
Pebble Pounder Join Date: Feb 2022 Location: Brooklyn
| Re: Trx4m springs
This is the traxxas chart for trx4m springs. Soft on the left hard on the right. Different color dots are for color coded springs. Sent from my LG-V521 using Tapatalk Last edited by Ynad; 06-01-2023 at 03:37 AM. |
06-03-2023, 02:51 AM | #5 |
| Re: Trx4m springs
thanks for the information, I will be getting a pair of the 0.155 rate springs for the truck and use them in the rear right side and the front left side to try and eliminate the torque twist.
06-03-2023, 06:43 AM | #6 |
| Re: Trx4m springs |
06-03-2023, 09:23 AM | #7 |
| Re: Trx4m springs |
06-03-2023, 11:23 AM | #8 |
| Re: Trx4m springs
I had the same problem with my Axial AX 24 after I added larger tires and brass knuckles. I changed the shocks and springs , with the stiffer spring on the right rear . I also installed lower gears to push the weight I added and not the body . I only get the left front tire wanting to lift twist on inclines at just around 55 degrees. It’s nice you can order the springs . |
06-04-2023, 05:29 AM | #9 | |
I've got the 0.155 rate springs on backorder from model sport in the UK, so hopefully they will eliminate the torque twist | |
07-01-2023, 07:58 AM | #10 |
| Re: Trx4m springs
the .155 rate springs arrive this morning and the truck does not torque twist as much as it used to do, I will have to adjust the spring tension a bit more
07-05-2023, 08:09 PM | #11 |
| Re: Trx4m springs |
Trx4m springs - Similar Threads | ||||
Another trx4m in the works. | chevy55 | Micro Scale Rigs | 13 | 02-13-2024 10:14 AM |
trx4m Esc help | ratmloud | Traxxas Crawlers | 1 | 04-26-2023 06:44 PM |
TRX4m bodies | braceysdad | Micro Scale Rigs | 3 | 12-31-2022 10:21 PM |
Phyro’s TRX4m | Phyro | Micro Scale Rigs | 8 | 12-09-2022 11:17 AM |
