09-17-2009, 02:36 PM | #21 |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
09-17-2009, 09:13 PM | #22 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
Ya I noticed that too. Would be cool to a show truck but very open to puncture. Guess it works for them.
09-21-2009, 07:27 PM | #23 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
Updates... -Mounted Second steering axle -Made&put 4 link brackets on a axle servo plate. -Bolted on 2nd servo(8711 :thumbsup: ) -Mounted 2 more Shocks mounts, 2 shocks -Bolted on new 35t -decided I will be using 14t pinon's To do list- -To much to list :annoy: Micro-Flex shot Finally opening up some 2 used axles I got, can you say "need new bearing" :rofl: |
09-22-2009, 05:59 PM | #24 |
Rock Crawler Join Date: Jul 2008 Location: gilbert
| Here is the rim. Sorry if this is off topic. Let me know how the tires work out, I may have to use a set for a build similar to this one but 6x6. keep us posted as to the progress! Last edited by cruiserkb; 09-22-2009 at 06:02 PM. |
09-24-2009, 01:51 PM | #25 |
Does anyone know what size this bearing is? I need to buy some new ones today. *Thanks in advance! |
09-24-2009, 02:02 PM | #26 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
12-01-2009, 02:03 PM | #27 |
Update… -Took apart the 8x8 and have decided to make a Oshkosh Striker 1500 but with a USFS paint theme. -Got in a pallet of .06” styrene yesterday :annoy: -Think about making the wheel base 18”ish, not 23.5” like 1:1….lol And here is the paint theme. Here are some specs of the Oshkosh Striker 1500 Side Slope Stability (Static): >30° Gradeability2: Ascend/descend a 60% grade Vehicle Clearance Circle: 102 ft. (31 m) Wheelbase: 234 in. (594.4 cm) Dimensions: 415 in. (1054.1 cm) length; 122 in. (310 cm) width (excluding rear view mirrors); 136 in. (345.4 cm) height without HRET; 150 in. (381 cm) with HRET CHASSIS: Cab: Aluminum construction; seating for up to five; center steering position; wrap-around, cockpit style instrument panel; easy to read backlit gauges and controls Engine: Caterpillar C-16 diesel; four cycle; in-line six; 680 bhp (506 Kw) minimum at 2,100 rpm with a peak torque of 1,950 ft. lbs. @ 1,400 rpm Transmission: Allison 4800 EVS; electronic; 7-speed; automatic Transfer Case: Oshkosh; independently mounted; with torque proportioning differential and driver selected locking mechanism Front Axle: 29,000 lb. (13152 kg); Oshkosh double reduction with bevel gear differential; driver operated differential lock Front Brakes: Dual wedge type Rear Axle: 29,000 lb. (13152 kg); Oshkosh double reduction with bevel gear differential; driver operated differential lock Suspension: Oshkosh TAK-4 independent system with dual control arms and single coil spring; up to 16 in. (40.64 cm) of wheel end travel; provides superior all-terrain mobility, improved ride quality and improved handling Tires: Michelin® 24R21 XZL FIREFIGHTING SYSTEM: Roof Turret: Non-aspirating; electric joystick control; 375/750 gpm (1419/2838 lpm) Bumper Turret: Non-aspirating; electric joystick control; 300 gpm (1136 lpm) Handlines (Foam/Water): Two preconnect type (one each side) with 150 ft. (46 m) of 1.75 in. (44 mm) ID hose and a 125 gpm (473 lpm) pistol-grip nozzle Water Tank: 1,500 gallon (5678 l) capacity; constructed of corrosion and UV resistant polypropylene Fire Pump Foam Tank: 210 gallon (795 l) capacity; constructed of corrosion and UV resistant polypropylene Fire Pump : Power divider driven Waterous CRQA; single stage centrifugal; cast iron body; brass impeller; stainless steel shaft; pumpand-roll capable; 1,950 gpm (7,381 lpm)at 240 psi (1657 kPa)Foam Proportioning System: Around the pump |
12-02-2009, 01:18 PM | #28 |
Newbie Join Date: Dec 2008 Location: Norway
Hey man, you should check out this: http://www.norcc.com/vb/showthread.php?t=471 It`s all written in Norwegian, but this guy has some serious skills!
12-19-2009, 09:23 PM | #29 |
Rock Crawler Join Date: Jun 2007 Location: Nova Scotia,Canada
Here is the build over at scale 4x4 all in english...... http://www.scale4x4rc.org/forums/showthread.php?t=17133 |
12-20-2009, 12:18 AM | #30 |
Wow, I am getting thread jacked! |
