Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** Edited the original post.. lost the pics from my old Photobucket..... scroll down to see updates on my scratch built Man Kat 6x6 |
Still playing around with the cnc ... Decided to design a replica of a MAN-KAT this time.. getting better .. http://i131.photobucket.com/albums/p...k/SAM_0484.jpg http://i131.photobucket.com/albums/p...k/SAM_0485.jpg Played around with the chassis a bit too... Originally I was going to use a bruder Actros cab http://i131.photobucket.com/albums/p...k/P2260270.jpg Started on the rear suspension http://i131.photobucket.com/albums/p...k/P2160221.jpg Mocking up some bracing to be brazed http://i131.photobucket.com/albums/p...k/P2160223.jpg http://i131.photobucket.com/albums/p...k/P2260274.jpg |
looks great.."thumbsup" whats that tool called. i want one. |
Been making a lot of progress with the cnc ... Here is what i have put together so far on the scratch made cab .. I have reworked the design a number of times but have been using a system of cutting a base and top layer for each panel to add some depth in the detail. Too bad I dont have a pic of all the panels layed out before i assembled them but i got a bit impatient after cutting them all out and didnt stop to take any pics. http://i131.photobucket.com/albums/p...10712-2305.jpg http://i131.photobucket.com/albums/p...10712-2305.jpg http://i131.photobucket.com/albums/p...10712-2306.jpg Next Ill be finishing up the area for the spare and making a some inner supports and roof. I am trying to come up with something ingenious for mounting the roof so that it can open, I plan to include some sealed compartments for the elctronics to sit inside the cab. |
looks really good!"thumbsup""thumbsup" |
WOW thats looks cool! Nice attatchement for the dremel tool :ror: |
Simply amazing!!!"thumbsup" I love seeing scratch builds like this! |
awesome! where did you get the cnc dremel cutting table? |
WHat is and where did you get that Dremel setup? |
I built the cnc machine. It took a lot of work to get it to cut styrene. It isn't really an ideal material for milling. It melts far to easy. Its really a prototyping machine, its slow to cut and takes a while to set up. I'm making it work for me though. I am really just happy to be learning cnc I have always wanted to give it a try and am having a blast learning it on my own. |
CNC and 6x6, freakin nutz. I like it."thumbsup""thumbsup""thumbsup". |
You should market the CNC. Awesome. |
Made a little more progress... cut out pieces for the roof and fender, they are resting on top for now cause im trying to come up with a removable roof setup. http://i131.photobucket.com/albums/p...10715-1234.jpg http://i131.photobucket.com/albums/p...10715-1234.jpg http://i131.photobucket.com/albums/p...10715-1235.jpg |
Got a bit more work done ... cut out and built the roof and cut out some plexiglass for the windows. roof is just resting on for now, there wont be a gap once I figure out a good way to mount it so its removable ... any suggestions? .. but the supports work well i notched them so it lines things up easy. http://i131.photobucket.com/albums/p...t/SAM_0520.jpg http://i131.photobucket.com/albums/p...t/SAM_0519.jpg Fisrt cut with Plexiglass ... not easy stuff to machine... http://i131.photobucket.com/albums/p...t/SAM_0522.jpg Kinda hard to see but one side is fitted ... coundt ask for anything more as far as how well it fit http://i131.photobucket.com/albums/p...t/SAM_0524.jpg Heres the body so far resting on the chassis.. http://i131.photobucket.com/albums/p...t/SAM_0529.jpg Im waiting on a package from RPP to see if I can use a GD-600 to get the 3speed to fit correctly... right now the offset between the trans and the transfer case is to much.. so im waiting until I igure that out before cutting the floor parts. I hope I can keep the 3 speed. |
I want to see if I can mount the 3 speed upside down to keep the weight of the motor low and tucked between the frame rails. I was having trouble getting the outputs to line up so I thought id see about attaching a GD-600 to the back of the trans for gear reduction but also to lower the output. I took the prop shaft the GD-600 came with and spun it down on my lathe to make it into an adapter for the pinion. not sure if its going to be strong enough but if not ill make another out of steel. http://i131.photobucket.com/albums/p...t/SAM_0539.jpg Then I drew up a new backing plate to mount the GD to the trans on and cut it out of Derlin http://i131.photobucket.com/albums/p...t/SAM_0535.jpg Here is the cut plate mounted to the trans http://i131.photobucket.com/albums/p...t/SAM_0543.jpg http://i131.photobucket.com/albums/p...t/SAM_0547.jpg I am going to mount the GD-600 using the adjustable holes so I have options to change out pinions going forward if I need to. http://i131.photobucket.com/albums/p...t/SAM_0549.jpg Hopefully this will let me mount the trans upside down and allow for good driveline angle. |
Re: Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** Well it spent a lot of time on the shelf... but here are some updates on the styrene work Built up the underside http://i131.photobucket.com/albums/p...k/SAM_1008.jpg http://i131.photobucket.com/albums/p...k/SAM_1011.jpg and the inside of the cab, im trying to modify the interior of a tamiya semi to hopefully work with the Kat http://i131.photobucket.com/albums/p...k/SAM_1007.jpg http://i131.photobucket.com/albums/p...k/SAM_1010.jpg http://i131.photobucket.com/albums/p...k/SAM_1006.jpg http://i131.photobucket.com/albums/p...k/SAM_1023.jpg http://i131.photobucket.com/albums/p...k/SAM_1025.jpg http://i131.photobucket.com/albums/p...k/SAM_1021.jpg |
Re: Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** Nice build, definitely need to learn some machining, have a mill and lathe (manual), need to get my stuff set up someday. You might need to get a dashboard stretcher kit.:ror: |
Re: Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** I LOVE the 3 speed work, and the cab is fantastic. keep it up, its bound to be a beast. Have you thought about wheels and rubber yet? |
Re: Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** Thanks sfor the comments.. for wheels, at the moment I have a set of Tamiya hummer rims and rock crushers.. i think i am going to stick with them until I pick sometihng else up.. got to get over the sticker shock of picking up a set of those sweet rc4wd militants and some military tires .. X 7 ! Finally got the oppertunity to work on this rig over the weekend.. Now that the cab has taken shape I decided to get to work on the bed.. I cut out the base for the floor and sides on the cnc.. notice the holes in the bed.. they are there to allow for the mounting of some body protection im working on... so many hours in the styrene work i got to protect my investment http://i131.photobucket.com/albums/p...k/IMG_0066.jpg Made a simple hinge for the tailgate... well see if it holds up, i might be changing it up http://i131.photobucket.com/albums/p...k/IMG_0068.jpg http://i131.photobucket.com/albums/p...k/IMG_0069.jpg A few cnc cut mounts to hold it to the chassis http://i131.photobucket.com/albums/p...k/IMG_0065.jpg then it was time to start with some detail Got the floor and sides cut http://i131.photobucket.com/albums/p...k/IMG_0070.jpg http://i131.photobucket.com/albums/p...k/IMG_0071.jpg Glued on http://i131.photobucket.com/albums/p...k/IMG_0073.jpg Got some more done .. just need to load the pictures .. so check back soon! |
Re: Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** PAINT!! and a lot of it.. got a bunch of stuff painted this weekend Body, Frame Axles, shocks, are all getting the military treatment http://i131.photobucket.com/albums/p...k/IMG_0038.jpg Started putting the rig back together after paint.. for some reason i am missing pictures of the frame being built up when i was cutting all the various mounts and test fitting.. but you kinda get the idea since i am basically rebuilding the whole thing after paint. http://i131.photobucket.com/albums/p...k/IMG_0041.jpg Here is a couple shots of the front suspension and motor mount setup http://i131.photobucket.com/albums/p...k/IMG_0042.jpg I went with a planitary gearbox to keep things compack under the cab, cut out a mount plate for the motor and servo on the cnc along with mounts for the transfer case.. (servo is only temp till i get a more powerful one) http://i131.photobucket.com/albums/p...k/IMG_0044.jpg http://i131.photobucket.com/albums/p...k/IMG_0046.jpg I have since lowered the front to correct that awful driveline angle. I Assembled the rear suspension .. took me a while to find a design that worked well.. it is using the semi leaf with a highlift spring and is linked to keep things straight.. http://i131.photobucket.com/albums/p...k/IMG_0081.jpg Also painted the cab and added some more detail to the bed http://i131.photobucket.com/albums/p...k/IMG_0080.jpg http://i131.photobucket.com/albums/p...k/IMG_0077.jpg http://i131.photobucket.com/albums/p...k/IMG_0082.jpg |
