07-27-2013, 06:17 AM | #1 |
Rock Stacker Join Date: Dec 2011 Location: Canada, Quebec, Saint-Constant
| New build - SCX10 6x6 Unimog Flatbed
I receive my new Dingo kit and I start a 6x6 Unimog Flatbed project - Servo : Hitec HS-5955TG (Liquid Tap) - ESC : EZrun 35A (whitout fan + Epoxy) - Motor : Trackstar 17.0T I want a MudBasher |
07-28-2013, 05:59 PM | #2 |
| Re: New build - SCX10 6x6 Unimog Flatbed
Hi, The rear shaft is too short. With big flex they pull out |
07-28-2013, 08:49 PM | #3 |
| Re: New build - SCX10 6x6 Unimog Flatbed http://www.youtube.com/v/Pol8mdFv5zI What do you think about Traxxas Stampede or du T-Maxx drive shaft ? |
07-29-2013, 04:32 AM | #4 |
I wanna be Dave Join Date: May 2010 Location: The east coast
those driveshafts could work fine. the real question is how much flex do you have and what is the distance between the axles. if you have huge flex with closely spaced axles there isn't much you can do to keep the shafts from pulling apart. it's a balance. i had to work that awhile on my 6x6. in the end i wanted the axles close together because of the look so i did limit the flex.
07-29-2013, 06:07 AM | #5 |
distance between the axles (135.5mm - 5.33 inch) : Max flex : Yes, it's closely spaced axles. I need just a little bit longer inside the shaft. I trying Traxxas shaft. If 'is not OK, I limit flex... Thanks jebster Last edited by patoff; 07-29-2013 at 07:09 AM. |
07-29-2013, 07:25 AM | #6 |
you might want to try different shafts. if you look at post #22 in my build thread (jebster's 6x6) it seems like i have a similar axle spacing but the shafts i use seem to have a longer engagement than yours. i believe mine are stock scx10 driveshafts i cut down.
07-29-2013, 07:58 AM | #7 |
Nice project jebster With two front directional axles you have better steering than 2 fixed rear axles |
07-29-2013, 08:26 AM | #8 |
| Re: New build - SCX10 6x6 Unimog Flatbed |
07-29-2013, 08:40 AM | #9 |
Cool because my 6x6 have a poor steering. If Santa is generous.... next winter I thinking six wheels sterring |
07-29-2013, 01:10 PM | #10 |
Quarry Creeper Join Date: Jul 2007 Location: Hangtown Ca.
WOW what a process! That's really cool some day I will belly up and give the 6x6 a shot. Cool build so far cant wait to see it take shape! Strong work |
07-29-2013, 08:19 PM | #11 |
Thanks fly, The Traxxas 4628 need to drill the parts: 13/64" My hobby shop do not have the Traxxas 1951 parts I receive the TRA1951 friday or saturday.... The big job it's to fit the Unimog body and make the flatbed Last edited by patoff; 07-29-2013 at 08:23 PM. |
08-07-2013, 06:55 AM | #12 |
Unimog prototype : I looking for two mud flaps and wood to build the flatbed. How to make a gas tank under the bed ? Last edited by patoff; 08-07-2013 at 06:58 AM. |
08-24-2013, 09:23 PM | #13 |
The new Traxxas shaft 5.5lbs with Lipo Hardcase 2S 6500mah. *without body, flatbed, leds and driver Now the first plywood proto flatbed: @doudou: Thanks for the driver |
08-26-2013, 08:51 PM | #14 |
I put some colors on this Mog: Next step: Gaz tank and Mud flaps Last edited by patoff; 08-26-2013 at 08:55 PM. |
09-06-2013, 04:41 PM | #15 |
Quarry Creeper Join Date: Sep 2013 Location: New Zealand
That is one very nice 'mog. I reckon it'd look good on either RC4WD 1.55 Desert Kings stretched over Gmade VR01 1.9 rims or RC4WD Mickey Thompson 1.9 MTZs on RC4WD Pro10 1.9 rims. Also, are you going to put an interior in because if you do, PLEASE hook the steering wheel up to a servo. It would finish the build off perfectly. But that's just my few cents worth!
09-07-2013, 06:36 PM | #16 |
Hi TrilloThrillo110, It's a low cost build : No new tire and no rotated steering... maybe next year... I make chain for snow: I assembled 94 chains FAIL : I remove 2 chain meshes on front wheels : And a new yellow beacon light : I wait two Bullhead gaz tanks Last edited by patoff; 10-02-2013 at 04:14 AM. |
09-07-2013, 06:48 PM | #17 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
subscribed
09-07-2013, 09:00 PM | #18 |
snow chains in September?? Is it already snowing up there?
09-07-2013, 09:21 PM | #19 |
| Re: New build - SCX10 6x6 Unimog Flatbed No snow before december. I would like to try chain in mud and dirt road. |
09-07-2013, 09:30 PM | #20 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
I'm really liking that teal color Mr. Patof |
New build - SCX10 6x6 Unimog Flatbed - Similar Threads | ||||
Scale Desert Trail - 8 RC trucks offroad RC Adventures scx10 unimog u300 honcho 6x6 | boolean21 | Scale Videos! | 0 | 07-01-2013 07:02 AM |
8 Scale trucks offroad RC Adventures scx10 wraith rc4wd unimog u300 honcho 6x6 defend | boolean21 | Scale Videos! | 0 | 05-27-2013 11:52 AM |
[Video] 14 trucks Crawling - CC01 SCX10 Unimog 6x6 Man Truck RC4WD Timberwolf Honcho | boolean21 | Scale Videos! | 0 | 11-15-2011 10:04 AM |
Broke MoFo scx10 6x6 unimog build | igotit | Axial SCX-10 | 11 | 04-03-2009 08:27 PM |
