11-06-2013, 08:14 AM | #21 |
| Re: Szczerba's Tow Rig Not sure just yet, whatever you think will push it around. I plan on using a bulletproof AX10 trans but that may change. I am guessing close to the 20lbs-25lbs range after it's built. I will try to save weight where I can. All 4 axles will have underdrive gears in them. Wraith axle up front and three widened AX10 axles out back. Rearmost axle will be a steer axle as well.
11-06-2013, 08:20 AM | #22 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
I'd hook up a low kV brushless sensored setup and gear it down via two sequential transmissions. This would require a custom "shaft plate" instead of a motor plate on the second one but would be cool. J |
11-06-2013, 08:23 AM | #23 | |
| Re: Szczerba's Tow Rig Quote:
11-06-2013, 09:06 AM | #24 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
Tow Rig..... Give each axle set its own power house?
11-06-2013, 09:11 AM | #25 |
| Re: Szczerba's Tow Rig |
11-06-2013, 09:39 AM | #26 |
11-06-2013, 09:43 AM | #27 | |
I have a few ideas but won't hash them out until I get the frame rails set. Which will be soon because the 4 axles should be here today. | |
11-06-2013, 08:20 PM | #28 |
Mocked up axles with two pass throughs. The drive axles have hex wideners on them for now but will get longer beef tubes in the future. Wraith axle up front. The rearmost axle will be a steer axle. Sent from my computer-phone. |
11-07-2013, 01:55 AM | #29 |
What if you kept the ax axles stock width and ran duals instead of super singles?
11-07-2013, 02:57 AM | #30 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
Fap fap fap fap fap fap Oh sorry Shane She's looking killer man! |
11-07-2013, 07:10 AM | #31 | |
Rear super singles... 3 longer beef tube sets = $80 4 sets of xr10 rear shafts = $80 Rear duals... 3 more pairs of tires $80 3 more pairs of wheels $50 Dual adapters of some sort $ ?. I could probably use some VP DH Hubs. The rear-most axle will be a steering axle and not sure if I would like the looks of duals on a steer axle. I guess I could make the rear most axle a super single setup, with duals on the front two? Thoughts, anyone? Thanks, just waiting on more parts to show up. Last edited by Szczerba; 11-07-2013 at 07:49 AM. | |
11-07-2013, 09:09 AM | #32 | |
Quarry Creeper Join Date: Mar 2008 Location: Hot Springs
On a side note, on your second pass through axle, is the input pinion the new axle case you put on to make it a pass through? Is the rear axle upside down in relation to how it should be? I'm trying to figure out how you are getting the pinions to spin correctly so that all tires move in the same direction. Unless i'm wrong, which I could be, the pinions on the two pass through axles will be spinning opposite of each other, right? | |
11-07-2013, 09:28 AM | #33 | |
You can see on the tops of the axles where I drew arrows to remember the orientation. The middle of the three rear is "Flipped" so the input and output jive with the front and rear axles. I had to spin the first axle and see which way the rear output was turning, then flip the middle one to work and the rear one stayed the same. | |
11-07-2013, 09:32 AM | #34 |
Rock Crawler Join Date: Jul 2011 Location: north little rock
super singles
11-07-2013, 03:07 PM | #35 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
Man I can't wait to see this moving along. I'll have to see if my cad program can scale the 3d rendering of the rig I'm doing so I can get it started. As for your wheels I also am running mil spec only I'm running militants for rims. What super singles would you use? I have not seen any 2:2 military style s. Singles or duals? The tamiya ones don't quite for the bill and would require a lot of work to the tires to make them fit and look right since their 1.7s. But I also agree that duals on a steer axle wouldn't look quite right --Dan Last edited by sickcivic95; 11-07-2013 at 03:10 PM. |
11-08-2013, 09:48 PM | #36 | |
Alan Man has this rig and posted some pictures on the Wraith Facebook page in my CXT post. 2.2 Duals ! Wanted to keep this look of the rear suspension So I dug around my parts bins and found these from an HPI Mini trophy Truck. Just might do, so I ordered up 4 more. Some grinding and screwing. Sent from my computer-phone. | |
11-09-2013, 05:11 AM | #37 |
Nice, that turned out great. Now find some nice looking boots from some brake calipers and you've got the air bags. --Dan |
11-09-2013, 07:16 AM | #38 | |
11-09-2013, 08:35 AM | #39 |
That's killer - I think that's only the second time I've seen a true LR radius arm set up used.
11-09-2013, 08:57 AM | #40 |
Quarry Creeper Join Date: Nov 2005 Location: Louisville, KY
Szczerba's Tow Rig - Similar Threads | ||||
f350 tow truck/ tow rig | bbnate804 | 1.9 Scale Rigs | 13 | 11-19-2012 07:15 PM |
Big Rig tow rig | codycodeman16 | General Crawlers | 1 | 02-05-2010 09:43 PM |
Tow rig # 2 | braceysdad | 1.9 Scale Rigs | 58 | 06-27-2007 01:08 PM |
Tow rig #1 | braceysdad | 1.9 Scale Rigs | 46 | 06-11-2007 11:06 AM |
New Tow Rig | Will | Chit Chat | 10 | 07-22-2005 12:02 PM |
