11-09-2013, 09:27 AM | #41 | ||
Got a jig built. Most of the parts will be in by the end of next week. Like I mentioned, these are 4.9" mock up wheels. Probably wont be able to setup the suspension until I get the actual Mil Specs. Sent from my computer-phone. | ||
11-09-2013, 10:41 AM | #42 | |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
| Re: Szczerba's Tow Rig Quote:
--Dan | |
11-09-2013, 10:47 AM | #43 | |
Another thing Ill have to make a bracket for is the rear most axle. It's not a pass through, so there are not axle mounts on the backside. Of course this arm setup can only be used if I run pass throughs or remake a bracket for them if i dont run pass throughs. Not sure how the torque will be handled going through two axles. Sent from my computer-phone. | |
11-09-2013, 01:42 PM | #44 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
You gotta think - The real deals have no flex really. That's why they are all equipped with spring loaded driver seats. I think as long as you follow suit then it'll work fine. We are talking about a cargo hauler, not a rock bouncer. Plus it looks killer!!! |
11-09-2013, 03:51 PM | #45 |
I like where this is going. |
11-09-2013, 03:56 PM | #46 | |
Me too . Most of the parts should be in by this Thursday. Probably won't get much done to it until then. I want to have the tires in hand to make sure my rear axle separation is long enough to clear everything. | |
11-09-2013, 06:36 PM | #47 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
That's an ambitious undertaking, Shane. A definite monster at 36". Are you going to get any actual turning action from the rear axle with the middle two being so close to it? |
11-09-2013, 07:24 PM | #48 | |
Got to tinkering with some stuff in the shop. There are some slick 1/14 scale semi air ride systems but you are going to may mightly for them. So, all thread, rod end, spring cups and Twin Hammers front shock springs equals below. The nut on the top will be gone later. The spring cup will sit flush on the frame, with a hole in the frame, the all thread will go through and the nut will be on the inside of the frame. I think it may work? Sent from my computer-phone. | |
11-09-2013, 08:04 PM | #49 |
Pebble Pounder Join Date: Dec 2011 Location: On, canada
looks like it will. awesome and very ambitious project. If you run this on one motor it better be a powerful one cause with 4 axles you'll be needing a lot of it. Keep it up, that's gonna be a sweet rig man
11-09-2013, 08:41 PM | #50 | |
I just searched all of the internets and I cannot locate anymore front Twin Hammer springs | |
11-09-2013, 09:03 PM | #51 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Szczerba I have a set of shocks off my TH the I won't be using. PM me if interested.
11-10-2013, 04:06 AM | #52 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
and then... once driveline is done.. you should put a scale series 92 Detroit replica in it like the scale model picture you posted. plus you got a guy like me who works on em everyday lol. im subed |
11-10-2013, 06:52 AM | #53 | |
I may have looked it over, what you planning on for trans ? Summit ? | |
11-10-2013, 07:15 AM | #54 | ||
First thoughts are a bullet proof AX10, due to size. The frame rails will be 3.5" wide on the outsides, so I am guessing about 3" on the inside will be my clearance. Tips, thoughts, suggestions? | ||
11-10-2013, 08:21 AM | #56 | |
11-10-2013, 08:24 AM | #57 |
Stick with the axial tranny. If anything you could lay it down over top of the chassis. CG is not going to be an issue caused by the tranny and motor on this puppy.
11-10-2013, 08:30 AM | #58 |
| Re: Szczerba's Tow Rig I've seen guys use summit transmissions with axial transmissions as transfer cases as well. I am kind of skeptical of the two pass though setup but I'll go with it and test if before I decide.
11-10-2013, 09:02 AM | #59 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
What about heat shrink over the springs. Just heated at the ends to encase the the spring
11-10-2013, 09:22 AM | #60 |
| Re: Szczerba's Tow Rig |
Szczerba's Tow Rig - Similar Threads | ||||
f350 tow truck/ tow rig | bbnate804 | 1.9 Scale Rigs | 13 | 11-19-2012 07:15 PM |
Big Rig tow rig | codycodeman16 | General Crawlers | 1 | 02-05-2010 09:43 PM |
Tow rig # 2 | braceysdad | 1.9 Scale Rigs | 58 | 06-27-2007 01:08 PM |
Tow rig #1 | braceysdad | 1.9 Scale Rigs | 46 | 06-11-2007 11:06 AM |
New Tow Rig | Will | Chit Chat | 10 | 07-22-2005 12:02 PM |
