11-15-2013, 11:27 AM | #101 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
| Re: Szczerba's Tow Rig
Are you going to run all the axles locked? If so, and the front will be the only steer axle, it's going to turn like poop. Especially with the spacing of the three rear axles. Aside from that, this is pretty cool, looking forward to some more progress. Oh, and I also agree with the drop axle idea. Keep posting updates! |
11-15-2013, 11:33 AM | #102 | |
| Re: Szczerba's Tow Rig Quote:
I had thought about a drop axle a few weeks ago but I didn't think about running smaller tires on said drop axle. I will be able to do some more decision making when these 10, 2.2 MilSpecs get unhung from the USPS grapple hold. Last edited by Szczerba; 11-15-2013 at 11:35 AM. | |
11-15-2013, 12:00 PM | #103 | |
10 2.2 MilSpec tires you say? Yikes, that's some coin right there. | |
11-15-2013, 01:02 PM | #104 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
No worse than we all spend on our toys.... And some say scale is cheaper than comp. yeah buddy!!!! |
11-15-2013, 01:21 PM | #105 | |
This rig is around $1,200 or so. I had alot of the parts laying around. And yea, the first time I built a nice IFS Wraith setup it was around $1,200. | |
11-15-2013, 04:31 PM | #106 |
Rock Crawler Join Date: Aug 2013 Location: Central Coast
8x8x8x8!! I'd love to see a huge double decker flatbed too Starting to remind me of this Tomy Mad Masher Monster Truck - YouTube |
11-16-2013, 01:29 PM | #107 | |
The ten RC4WD 2.2 Mil Spec tires are MIA. Last scanned at a PO on last Monday. Maybe they'll show this Monday. So, Front axle mostly done for now. Still need some upgrades. Integy HD Ring and Pinion gear, 13/38 Bronze bushings for pinion GripFab ARB Locker Vanquish bearing caps Vanquish axle housing Integy C-Hubs Dinky R/C Wraith 4-link servo mount Plastic diff, knuckles and lower mounts for now and mock up steering link. Mocked up the 4 other rear dampeners. Twin hammer springs, cups, rod ends and some all thread. Sent from my computer-phone. Last edited by Szczerba; 11-16-2013 at 01:34 PM. | |
11-16-2013, 02:34 PM | #108 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: Szczerba's Tow Rig Excellent idea on the stretch, that will really pull off the drop axle/tire look.
11-16-2013, 06:02 PM | #109 | |
Anywho, spent some time today regearing the rear three axles with underdrive gears and RCP lockers. Two pass throughs and one rear steer. Then I got to the rearmost axle and started scratching my head. Need the rear lower mounts the output case offers to mount up to the trailing arms but need the servo posts the smooth diff side offers. So, I started cutting. Lower link mounts cut off and added back to smooth diff case. Future beef tubes will help secure the backside lower mounts. Holla! Problem solved. Sent from my computer-phone. | |
11-16-2013, 06:17 PM | #110 |
Nice move in the axle chop!
11-16-2013, 06:30 PM | #111 |
| Thanks. I was going to use another output case out back and use a piece of delrin to cap it off. Would have been ok but no servo posts! See pic below... My pops is visiting this weekend and I started showing him what I was doing. He mentioned chopping up the two cases since beef tubes would be used and since the main point was to retain the lower twin hammer arms so all the three rears looked the same. And those lower arms need the two mounting points. Sent from my computer-phone. |
11-20-2013, 06:15 PM | #112 |
The good news. Some more parts showed up from Amainhobbies. Vanquish Wraith knuckles for wraith front axle and rear ax10 longer beef tubed axle Vanquish Wraith steering link for wraith axle STRC wraith C-Hubs for rear ax10 longer beef tubed axle 4 sets of xr10 straight rear axles for the two pass through longer beef tubed axles Longer beef tubes, MIPs, two 1.9 mil specs in the mail. The bad news, still no sight of my ten 2.2 tires from RC4WD. Ok, USPS, its been 7 business days, quit playing around. This shipment is holding up major progress! Sent from my computer-phone. |
11-20-2013, 07:24 PM | #113 |
Newbie Join Date: Nov 2013 Location: Arkansas
Wish those tires would get there. I'm ready to see it going together lol.
11-20-2013, 07:31 PM | #114 | |
And I do not want to start the chassis without the tires mounted on the axles. There is only one way to build a chassis and that is chassis rails at full bump with axles, wheels and tires. No other way, unless you want subpar geometry. | |
11-21-2013, 12:37 AM | #115 |
| Re: Szczerba's Tow Rig True that - really looking forward to seeing the chassis come together |
11-21-2013, 08:39 PM | #116 | |
Got a small parts order from RppHobby Two sets of MIPs (1 pictured) to be cut down for pass throughs and to be extended for wraith and first rear axle. Needed some more narrow hexes 1.9 MilSpecs for testing the front drop axle concept. Stretched over 2.2 wheel Sent from my computer-phone. | |
11-22-2013, 04:45 PM | #117 |
2.2 Mil Specs on 2.2 Axial Trail Ready's Frame construction soon. Sent from my computer-phone. |
11-22-2013, 06:15 PM | #119 | |
| Re: Szczerba's Tow Rig Quote: Speaking of looks, I may go back to a scratch built M1070 cab. 11" wide and 15.5" long. Got some help from a board member . We'll see how it goes. | |
Szczerba's Tow Rig - Similar Threads | ||||
f350 tow truck/ tow rig | bbnate804 | 1.9 Scale Rigs | 13 | 11-19-2012 07:15 PM |
Big Rig tow rig | codycodeman16 | General Crawlers | 1 | 02-05-2010 09:43 PM |
Tow rig # 2 | braceysdad | 1.9 Scale Rigs | 58 | 06-27-2007 01:08 PM |
Tow rig #1 | braceysdad | 1.9 Scale Rigs | 46 | 06-11-2007 11:06 AM |
New Tow Rig | Will | Chit Chat | 10 | 07-22-2005 12:02 PM |
